User 97 ارسال شده در 1 آبان، 2021 اشتراک گذاری ارسال شده در 1 آبان، 2021 سلام دوستان کتابخانه های سورس زیاد هستند و برسی کتابخانه ها زمان میبره سوال رو مطرح کردم تا اگر کسی از دوستان تجربه این مشکل رو داشته بتونم سریع تر از راهنمایی ایشون استفاده کنم . متن خطا هنگام خروجی : B4A Version: 11.00 Parsing code. (0.12s) Java Version: 8 Building folders structure. (0.03s) Compiling code. (0.17s) Compiling layouts code. (0.07s) Organizing libraries. (0.00s) (AndroidX SDK) Compiling resources (0.14s) Linking resources (1.60s) Compiling generated Java code. (6.44s) Convert byte code - optimized dex. Error Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/legacy/content/WakefulBroadcastReceiver; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/localbroadcastmanager/content/LocalBroadcastManager$ReceiverRecord; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/legacy/app/ActionBarDrawerToggle$DelegateProvider; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/lifecycle/ViewModelProvider; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/lifecycle/ViewModelProvider$AndroidViewModelFactory; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/lifecycle/ViewModelProvider$Factory; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/lifecycle/ViewModelProvider$NewInstanceFactory; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/lifecycle/ReportFragment$ActivityInitializationListener; Uncaught translation error: java.lang.IllegalArgumentException: already added: Landroidx/customview/widget/ExploreByTouchHelper$MyNodeProvider; UNEXPECTED TOP-LEVEL EXCEPTION: java.lang.RuntimeException: Translation has been interrupted at com.android.dx.command.dexer.Main.processAllFiles(Main.java:692) at com.android.dx.command.dexer.Main.runMultiDex(Main.java:366) at com.android.dx.command.dexer.Main.runDx(Main.java:291) at com.android.dx.command.dexer.Main.main(Main.java:249) at com.android.dx.command.Main.main(Main.java:94) Caused by: java.lang.InterruptedException: Too many errors at com.android.dx.command.dexer.Main.processAllFiles(Main.java:684) ... 4 more لیست کتابخانه های مورد استفاده : چطور میتونم تداخل رو رفع کنم ؟ لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ali mo 264 ارسال شده در 1 آبان، 2021 اشتراک گذاری ارسال شده در 1 آبان، 2021 سلم وقت بخیر اول کتابخونه هاتون خالی اد بزنید داخل یه پروژه دیگه بعد دونه به دونه تیک کتابخونه ها رو بردارید (البته با احتمال خودتون) بفهمید تداخل دقیقا بین کدوم کتابخونه هاست(با کمپایل کردن مجدد) بعد که فهمیدید دقیقا بین چند تا کتابخونه هاست اون کتابخونه ها رو کپی کنید داخل یه پوشه بعد داخل اون کتابخونه ها فایل xml شون رو اجرا کنید معمولا اخراش یک تگی هست به نام Dependency ببینید داخل کدام کتابخونه ها دو بار یک وابستگی اضافه شده این چیزی بود که من بلد بودم صبر کنید شاید دوست دیگه ای دقیقا از خروجی خطا تون بفهمم کدوم کتابخونه ایراد داره لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
User 97 ارسال شده در 1 آبان، 2021 سازنده اشتراک گذاری ارسال شده در 1 آبان، 2021 در ۱۴۰۰/۵/۱۰ در 06:48، ali mo گفته است: سلم وقت بخیر اول کتابخونه هاتون خالی اد بزنید داخل یه پروژه دیگه بعد دونه به دونه تیک کتابخونه ها رو بردارید (البته با احتمال خودتون) بفهمید تداخل دقیقا بین کدوم کتابخونه هاست(با کمپایل کردن مجدد) بعد که فهمیدید دقیقا بین چند تا کتابخونه هاست اون کتابخونه ها رو کپی کنید داخل یه پوشه بعد داخل اون کتابخونه ها فایل xml شون رو اجرا کنید معمولا اخراش یک تگی هست به نام Dependency ببینید داخل کدام کتابخونه ها دو بار یک وابستگی اضافه شده این چیزی بود که من بلد بودم صبر کنید شاید دوست دیگه ای دقیقا از خروجی خطا تون بفهمم کدوم کتابخونه ایراد داره بله بسیار ممنونم کتابخانه PersianRecyclerViewl با نجوا تداخل داشت در PersianRecyclerViewl.xml دو خط زیر رو از <dependsOn> حذف کردم و مشکل برطرف شد <dependsOn>androidx.legacy:legacy-support-v4</dependsOn> <dependsOn>androidx.recyclerview:recyclerview</dependsOn> لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
User 97 ارسال شده در 1 آبان، 2021 سازنده اشتراک گذاری ارسال شده در 1 آبان، 2021 این پاسخ رو نادیده بگیرید * لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
User 97
