B4A Version: 11.00
Parsing code. (0.00s)
Java Version: 8
Building folders structure. (0.05s)
Compiling code. (0.02s)
Compiling layouts code. (0.00s)
Organizing libraries. (0.00s)
(Android Support Library)
Compiling resources (0.10s)
Linking resources Error
unknown option '-A'.
aapt2 link [options] -o arg --manifest arg files...
Options:
-o arg Output path
--manifest arg Path to the Android manifest to build
-I arg Adds an Android APK to link against
-R arg Compilation unit to link, using `overlay` semantics.
The last conflicting resource given takes precedence.
--java arg Directory in which to generate R.java
--proguard arg Output file for generated Proguard rules
--proguard-main-dex arg Output file for generated Proguard rules for the main dex
--no-auto-version Disables automatic style and layout SDK versioning
--no-version-vectors Disables automatic versioning of vector drawables. Use this only
when building with vector drawable support library
--no-version-transitions Disables automatic versioning of transition resources. Use this only
when building with transition support library
--no-resource-deduping Disables automatic deduping of resources with
identical values across compatible configurations.
--enable-sparse-encoding Enables encoding sparse entries using a binary search tree.
This decreases APK size at the cost of resource retrieval performance.
-x Legacy flag that specifies to use the package identifier 0x01
-z Require localization of strings marked 'suggested'
-c arg Comma separated list of configurations to include. The default
is all configurations
--preferred-density arg Selects the closest matching density and strips out all others.
--product arg Comma separated list of product names to keep
--output-to-dir Outputs the APK contents to a directory specified by -o
--no-xml-namespaces Removes XML namespace prefix and URI information from AndroidManifest.xml
and XML binaries in res/*.
--min-sdk-version arg Default minimum SDK version to use for AndroidManifest.xml
--target-sdk-version arg Default target SDK version to use for AndroidManifest.xml
--version-code arg Version code (integer) to inject into the AndroidManifest.xml if none is present
--version-name arg Version name to inject into the AndroidManifest.xml if none is present
--shared-lib Generates a shared Android runtime library
--static-lib Generate a static Android library
--no-static-lib-packages Merge all library resources under the app's package
--non-final-ids Generates R.java without the final modifier.
This is implied when --static-lib is specified.
--stable-ids arg File containing a list of name to ID mapping.
--emit-ids arg Emit a file at the given path with a list of name to ID
mappings, suitable for use with --stable-ids.
--private-symbols arg Package name to use when generating R.java for private symbols.
If not specified, public and private symbols will use the application's package name
--custom-package arg Custom Java package under which to generate R.java
--extra-packages arg Generate the same R.java but with different package names
--add-javadoc-annotation arg Adds a JavaDoc annotation to all generated Java classes
--auto-add-overlay Allows the addition of new resources in overlays without <add-resource> tags
--rename-manifest-package arg Renames the package in AndroidManifest.xml
--rename-instrumentation-target-package arg Changes the name of the target package for instrumentation. Most useful when used
in conjunction with --rename-manifest-package
-0 arg File extensions not to compress
--split arg Split resources matching a set of configs out to a Split APK.
Syntax: path/to/output.apk:<config>[,<config>[...]]
-v Enables verbose logging
-h Displays this help menu
hoseintak 0
B4A Version: 11.00
Java Version: 8
Options:
-o arg Output path
https://www.uplooder.net/img/image/58/45135b65d50d7d023e77f1d00461e3eb/Screenshot-(2).png
https://www.uplooder.net/img/image/1/1724837370000a68fffcb823e4daf4e3/Screenshot-(1).png
