ارور در SDK
ابراهیم فارغی
B4A Version: 11.00
Parsing code.    (0.03s)
    Java Version: 8
Building folders structure.    (0.04s)
Running custom action.    (0.09s)
Compiling code.    (0.03s)
Compiling layouts code.    (0.00s)
Organizing libraries.    (0.00s)
    (Android Support Library)
Compiling resources    (0.08s)
Linking resources    (16.85s)
Compiling generated Java code.    (1.27s)
Convert byte code - optimized dex.    (0.44s)
Copying libraries resources    (0.06s)
ZipAlign file.    (0.03s)
Signing package file (debug key).    Error
java.lang.UnsupportedClassVersionError: com/android/apksigner/ApkSignerTool has been compiled by a more recent version of the Java Runtime (class file version 53.0), this version of the Java Runtime only recognizes class file versions up to 52.0
    at java.lang.ClassLoader.defineClass1(Native Method)
    at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
    at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
    at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
    at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
    at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
    at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
    at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:335)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
Error: A JNI error has occurred, please check your installation and try again
Exception in thread "main"
سلام این ارور زو چجوری برطرف کنم
سلام و درود.بیسیک رو حذف کنید و نسخه آخر بیسیک و همینطور sdk رو از سایت مرجع دریافت و نصب کنید.توی تنظیمات هم نسخه api رو روی ۳۰ بزارید.
