Private Sub DialogEditTexi(title As String, content , data As String , textformt As Boolean , tag As String, rengtext As Int)
Dim Builder As MaterialDialogBuilder
Builder.Initialize("Builder")
Builder.Title(title).TitleColor(Utils.ICONCOLORDIALOG)
Builder.Content(content).ContentColor(Utils.TEXTCOLORDARK)
If textformt = True Then
Builder.InputType(Bit.Or(Bit.Or(Builder.TYPE_CLASS_TEXT, Builder.TYPE_TEXT_FLAG_MULTI_LINE),Builder.TYPE_TEXT_FLAG_CAP_WORDS)).Typeface(Typeface.LoadFromAssets("IRANSans(FaNum)_Bold.ttf"),Typeface.LoadFromAssets("IRANSans(FaNum)_UltraLight.ttf"))
Builder.InputType(Bit.Or(Bit.Or(Builder.TYPE_CLASS_NUMBER, Builder.TYPE_CLASS_PHONE),Bit.Or(Builder.TYPE_CLASS_NUMBER, Builder.TYPE_CLASS_PHONE))).Typeface(Typeface.LoadFromAssets("IRANSans(FaNum)_Bold.ttf"),Typeface.LoadFromAssets("IRANSans(FaNum)_UltraLight.ttf"))
Builder.PositiveText("تایید").PositiveColor(Utils.M_SUCCES).NegativeColor(Utils.M_ERORR).NegativeText("لغو")
If data = ("اطلاعات این فیلد کامل نیست") Or data=("0") Then
Builder.Input("...", "").ButtonRippleColor(Utils.HANITTEXTCOLOR).WidgetColor(Utils.ICONCOLORDIALOG)
Builder.Input("...",data).ButtonRippleColor(Utils.HANITTEXTCOLOR).WidgetColor(Utils.ICONCOLORDIALOG)
Builder.Tag(tag)
If tag = "phone" Then
Builder.InputRange(11,rengtext)
Builder.InputRange(4,rengtext)
Builder.BackgroundColor(Utils.TOOLBARCOLORDIALOG)
Builder.Show
وقتی ساب بالا اجرا میشه ارور زیر چاپ میشه. چطوری این ارور رو برطرف کنم؟
Amir01 612
Private Sub DialogEditTexi(title As String, content , data As String , textformt As Boolean , tag As String, rengtext As Int) Dim Builder As MaterialDialogBuilder Builder.Initialize("Builder") Builder.Title(title).TitleColor(Utils.ICONCOLORDIALOG) Builder.Content(content).ContentColor(Utils.TEXTCOLORDARK) If textformt = True Then Builder.InputType(Bit.Or(Bit.Or(Builder.TYPE_CLASS_TEXT, Builder.TYPE_TEXT_FLAG_MULTI_LINE),Builder.TYPE_TEXT_FLAG_CAP_WORDS)).Typeface(Typeface.LoadFromAssets("IRANSans(FaNum)_Bold.ttf"),Typeface.LoadFromAssets("IRANSans(FaNum)_UltraLight.ttf")) Else Builder.InputType(Bit.Or(Bit.Or(Builder.TYPE_CLASS_NUMBER, Builder.TYPE_CLASS_PHONE),Bit.Or(Builder.TYPE_CLASS_NUMBER, Builder.TYPE_CLASS_PHONE))).Typeface(Typeface.LoadFromAssets("IRANSans(FaNum)_Bold.ttf"),Typeface.LoadFromAssets("IRANSans(FaNum)_UltraLight.ttf")) End If Builder.PositiveText("تایید").PositiveColor(Utils.M_SUCCES).NegativeColor(Utils.M_ERORR).NegativeText("لغو") If data = ("اطلاعات این فیلد کامل نیست") Or data=("0") Then Builder.Input("...", "").ButtonRippleColor(Utils.HANITTEXTCOLOR).WidgetColor(Utils.ICONCOLORDIALOG) Else Builder.Input("...",data).ButtonRippleColor(Utils.HANITTEXTCOLOR).WidgetColor(Utils.ICONCOLORDIALOG) End If Builder.Tag(tag) If tag = "phone" Then Builder.InputRange(11,rengtext) Else Builder.InputRange(4,rengtext) End If Builder.BackgroundColor(Utils.TOOLBARCOLORDIALOG) Builder.Show End Subوقتی ساب بالا اجرا میشه ارور زیر چاپ میشه. چطوری این ارور رو برطرف کنم؟
