برای استفاده از تبلیغات تپسل باید multidex فعال باشه اما مثل اینکه با AHNavigationDrawer تداخل داره و ارار زیر رو میده
نسخه بیسیک: 11.5
نسخه جاوا:8 - 14.0 - 17.0 تست کردم
نسخه تارگت: 30-31-32 تست کردم
** Activity (settings) Create, isFirst = true **
** Activity (settings) Resume **
** Activity (settings) Pause, UserClosed = true **
** Activity (main) Resume **
** Activity (main) Pause, UserClosed = true **
** Service (starter) Destroy (ignored)**
--------- beginning of crash
Copying updated assets files (1)
*** Service (starter) Create ***
** Service (starter) Start **
java.lang.NoClassDefFoundError: Failed resolution of: Landroid/support/v4/widget/DrawerLayout$LayoutParams;
at de.amberhome.navdrawer.NavigationDrawer.Initialize2(NavigationDrawer.java:82)
at ir.parsprog.takey.main._slide(main.java:801)
at ir.parsprog.takey.main._activity_create(main.java:490)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:351)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144)
at ir.parsprog.takey.main.afterFirstLayout(main.java:105)
at ir.parsprog.takey.main.access$000(main.java:17)
at ir.parsprog.takey.main$WaitForLayout.run(main.java:83)
at android.os.Handler.handleCallback(Handler.java:751)
at android.os.Looper.loop(Looper.java:154)
at android.app.ActivityThread.main(ActivityThread.java:6138)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783)
Caused by: java.lang.ClassNotFoundException: Didn't find class "android.support.v4.widget.DrawerLayout$LayoutParams" on path: DexPathList[[zip file "/data/app/ir.parsprog.takey-2/base.apk"],nativeLibraryDirectories=[/data/app/ir.parsprog.takey-2/lib/x86, /system/lib, /vendor/lib, /data/downloads, /data/priv-downloads]]
at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56)
at java.lang.ClassLoader.loadClass(ClassLoader.java:380)
at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
... 19 more
اگه مشکل قابل حل نیست لطفا یا معادل تپسل و یا معادل کتایخانه navigation رو معرفی کنید
mostafaHD 44
سلام خسته نباشید
نسخه بیسیک: 11.5
** Activity (settings) Create, isFirst = true ** ** Activity (settings) Resume ** ** Activity (settings) Pause, UserClosed = true ** ** Activity (main) Resume ** ** Activity (main) Pause, UserClosed = true ** ** Service (starter) Destroy (ignored)** --------- beginning of crash Copying updated assets files (1) *** Service (starter) Create *** ** Service (starter) Start ** ** Activity (main) Create, isFirst = true ** java.lang.NoClassDefFoundError: Failed resolution of: Landroid/support/v4/widget/DrawerLayout$LayoutParams; at de.amberhome.navdrawer.NavigationDrawer.Initialize2(NavigationDrawer.java:82) at ir.parsprog.takey.main._slide(main.java:801) at ir.parsprog.takey.main._activity_create(main.java:490) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:351) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:144) at ir.parsprog.takey.main.afterFirstLayout(main.java:105) at ir.parsprog.takey.main.access$000(main.java:17) at ir.parsprog.takey.main$WaitForLayout.run(main.java:83) at android.os.Handler.handleCallback(Handler.java:751) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:154) at android.app.ActivityThread.main(ActivityThread.java:6138) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783) Caused by: java.lang.ClassNotFoundException: Didn't find class "android.support.v4.widget.DrawerLayout$LayoutParams" on path: DexPathList[[zip file "/data/app/ir.parsprog.takey-2/base.apk"],nativeLibraryDirectories=[/data/app/ir.parsprog.takey-2/lib/x86, /system/lib, /vendor/lib, /data/downloads, /data/priv-downloads]] at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56) at java.lang.ClassLoader.loadClass(ClassLoader.java:380) at java.lang.ClassLoader.loadClass(ClassLoader.java:312) ... 19 moreاگه مشکل قابل حل نیست لطفا یا معادل تپسل و یا معادل کتایخانه navigation رو معرفی کنید
متشکرم
