من وقتی از برنامه ام اجرا می گیرم این ارر رو میده
ممنون میشم هرکس براش مقدوره راهنمایی کنه حلش کنم
B4A Version: 9.30
Java Version: 8
Parsing code. (0.02s)
Building folders structure. (0.01s)
Compiling code. (0.55s)
Compiling layouts code. (0.01s)
Organizing libraries. (0.00s)
(AndroidX SDK)
Generating R file. Error
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:5: error: Resource entry mrl_rippleColor already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:322: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:6: error: Resource entry mrl_rippleDimension already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:323: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:7: error: Resource entry mrl_rippleOverlay already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:324: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:8: error: Resource entry mrl_rippleAlpha already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:325: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:9: error: Resource entry mrl_rippleDuration already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:326: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:10: error: Resource entry mrl_rippleFadeDuration already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:327: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:11: error: Resource entry mrl_rippleHover already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:328: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:12: error: Resource entry mrl_rippleBackground already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:329: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:13: error: Resource entry mrl_rippleDelayClick already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:330: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:14: error: Resource entry mrl_ripplePersistent already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:331: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:15: error: Resource entry mrl_rippleInAdapter already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:332: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:16: error: Resource entry mrl_rippleRoundedCorners already has bag item ^l10n.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:333: Originally defined here.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:139: error: Attribute "srl_direction" already defined with incompatible format.
D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:404: Original attribute defined here.
hamedafrough 5
B4A Version: 9.30 Java Version: 8 Parsing code. (0.02s) Building folders structure. (0.01s) Compiling code. (0.55s) Compiling layouts code. (0.01s) Organizing libraries. (0.00s) (AndroidX SDK) Generating R file. Error D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:5: error: Resource entry mrl_rippleColor already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:322: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:6: error: Resource entry mrl_rippleDimension already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:323: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:7: error: Resource entry mrl_rippleOverlay already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:324: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:8: error: Resource entry mrl_rippleAlpha already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:325: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:9: error: Resource entry mrl_rippleDuration already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:326: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:10: error: Resource entry mrl_rippleFadeDuration already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:327: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:11: error: Resource entry mrl_rippleHover already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:328: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:12: error: Resource entry mrl_rippleBackground already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:329: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:13: error: Resource entry mrl_rippleDelayClick already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:330: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:14: error: Resource entry mrl_ripplePersistent already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:331: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:15: error: Resource entry mrl_rippleInAdapter already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:332: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:16: error: Resource entry mrl_rippleRoundedCorners already has bag item ^l10n. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:333: Originally defined here. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-hitex_recyclerview-63688246101805\res\values\values.xml:139: error: Attribute "srl_direction" already defined with incompatible format. D:\sdk\AndroidXSDK\tools\..\extras\b4a_local\unpacked-persianrecyclerview-63749846510880\res\values\values.xml:404: Original attribute defined here.
