امیرحسین قاسمی
سلام،
وقتی پروژه رو کامپایل میکنم و اپلیکیشن در شبیه ساز باز میشه فورس کلوز رخ میده و این لاگ چاپ میشه:
java.lang.NoClassDefFoundError: Failed resolution of: Landroidx/emoji2/viewsintegration/EmojiTextViewHelper;
	at androidx.appcompat.widget.AppCompatEmojiTextHelper.<init>(AppCompatEmojiTextHelper.java:43)
	at androidx.appcompat.widget.AppCompatTextView.getEmojiTextViewHelper(AppCompatTextView.java:132)
	at androidx.appcompat.widget.AppCompatTextView.setFilters(AppCompatTextView.java:219)
	at android.widget.TextView.<init>(TextView.java:1439)
	at android.widget.TextView.<init>(TextView.java:704)
	at androidx.appcompat.widget.AppCompatTextView.<init>(AppCompatTextView.java:108)
	at androidx.appcompat.widget.AppCompatTextView.<init>(AppCompatTextView.java:103)
	at androidx.appcompat.app.AppCompatViewInflater.createTextView(AppCompatViewInflater.java:201)
	at androidx.appcompat.app.AppCompatViewInflater.createView(AppCompatViewInflater.java:121)
	at androidx.appcompat.app.AppCompatDelegateImpl.createView(AppCompatDelegateImpl.java:1569)
	at androidx.appcompat.app.AppCompatDelegateImpl.onCreateView(AppCompatDelegateImpl.java:1620)
	at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:769)
	at android.view.LayoutInflater.createViewFromTag(LayoutInflater.java:727)
	at android.view.LayoutInflater.rInflate(LayoutInflater.java:858)
	at android.view.LayoutInflater.rInflateChildren(LayoutInflater.java:821)
	at android.view.LayoutInflater.rInflate(LayoutInflater.java:861)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:518)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:426)
	at android.view.LayoutInflater.inflate(LayoutInflater.java:377)
	at com.robohorse.pagerbullet.PagerBullet.init(PagerBullet.java:119)
	at com.robohorse.pagerbullet.PagerBullet.<init>(PagerBullet.java:40)
	at com.porya.pagerbullet.PagerBulletWrapper._initialize(PagerBulletWrapper.java:62)
	at com.porya.pagerbullet.PagerBulletWrapper.Initialize(PagerBulletWrapper.java:54)
	at com.test.myapp.main._desine_page4(main.java:1366)
	at com.test.myapp.main$ResumableSub_hd1_host_ResponseBody.resume(main.java:2040)
	at com.test.myapp.main._hd1_host_responsebody(main.java:1913)
	at anywheresoftware.b4a.BA.raiseEvent2(BA.java:213)
	at anywheresoftware.b4a.keywords.Common.CallSub4(Common.java:1085)
	at anywheresoftware.b4a.keywords.Common.CallSubNew3(Common.java:1048)
	at com.test.myapp.sadegh_lib$ResumableSub_hd_host_onNext.resume(sadegh_lib.java:200)
	at anywheresoftware.b4a.keywords.Common$13.run(Common.java:1717)
	at android.os.Handler.handleCallback(Handler.java:751)
	at android.os.Looper.loop(Looper.java:154)
	at android.app.ActivityThread.main(ActivityThread.java:6121)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:889)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:779)
Caused by: java.lang.ClassNotFoundException: Didn't find class "androidx.emoji2.viewsintegration.EmojiTextViewHelper" on path: DexPathList[[zip file "/data/app/com.test.myapp-1/base.apk"],nativeLibraryDirectories=[/data/app/com.test.myapp-1/lib/x86_64, /system/lib64, /vendor/lib64]]
	at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:380)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
	... 40 mor
