طبق سایت مرجع آموزش را پیش بردم وقتی که پروژه اجرا میشه یک خطایی میده ولی پروژه کرش نمیکنه میخواستم دلیل خطا را بدون و اینکه در آینده مشکل ساز نشه
Error occurred on line: 24 (Main)
java.lang.RuntimeException: Field: _actionbar not found in: b4a.example.main
at anywheresoftware.b4a.shell.Shell$FieldCache.getField(Shell.java:923)
at anywheresoftware.b4a.shell.Shell.setStateBeforeUserSub(Shell.java:505)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:411)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:146)
at b4a.example.main.afterFirstLayout(main.java:105)
at b4a.example.main.access$000(main.java:17)
at b4a.example.main$WaitForLayout.run(main.java:83)
at android.os.Handler.handleCallback(Handler.java:751)
at android.os.Looper.loop(Looper.java:154)
at android.app.ActivityThread.main(ActivityThread.java:6176)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783)
DexterFstone 399
Error occurred on line: 24 (Main) java.lang.RuntimeException: Field: _actionbar not found in: b4a.example.main at anywheresoftware.b4a.shell.Shell$FieldCache.getField(Shell.java:923) at anywheresoftware.b4a.shell.Shell.setStateBeforeUserSub(Shell.java:505) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:411) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:146) at b4a.example.main.afterFirstLayout(main.java:105) at b4a.example.main.access$000(main.java:17) at b4a.example.main$WaitForLayout.run(main.java:83) at android.os.Handler.handleCallback(Handler.java:751) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:154) at android.app.ActivityThread.main(ActivityThread.java:6176) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783)لینک ارسال
