این نسخه جدید B4A به طرز عجیبی داره الکی الکی خطا میده ویوها را با استفاده از دیزاینر اضافه کردم و وقتی ران میکنم خطا میده ولی خب کرش نمیکنه پروژه
دوستان راه حلی ندارن؟
Error occurred on line: 0 (Main)
java.lang.RuntimeException: Object should first be initialized (Button).
at anywheresoftware.b4a.AbsObjectWrapper.getObject(AbsObjectWrapper.java:67)
at anywheresoftware.b4a.objects.TextViewWrapper.setTextColor(TextViewWrapper.java:46)
at b4a.example.main._config_views_info(main.java:504)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:146)
at anywheresoftware.b4a.BA$2.run(BA.java:387)
at android.os.Handler.handleCallback(Handler.java:751)
at android.os.Looper.loop(Looper.java:154)
at android.app.ActivityThread.main(ActivityThread.java:6176)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783)
Error occurred on line: 49 (Main)
java.lang.RuntimeException: Object should first be initialized (Label).
Did you forget to call Activity.LoadLayout?
at anywheresoftware.b4a.objects.TextViewWrapper.setText(TextViewWrapper.java:39)
at b4a.example.main._config_views_info(main.java:436)
DexterFstone 399
Error occurred on line: 0 (Main) java.lang.RuntimeException: Object should first be initialized (Button). at anywheresoftware.b4a.AbsObjectWrapper.getObject(AbsObjectWrapper.java:67) at anywheresoftware.b4a.objects.TextViewWrapper.setTextColor(TextViewWrapper.java:46) at b4a.example.main._config_views_info(main.java:504) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:146) at anywheresoftware.b4a.BA$2.run(BA.java:387) at android.os.Handler.handleCallback(Handler.java:751) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:154) at android.app.ActivityThread.main(ActivityThread.java:6176) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783) Error occurred on line: 49 (Main) java.lang.RuntimeException: Object should first be initialized (Label). Did you forget to call Activity.LoadLayout? at anywheresoftware.b4a.AbsObjectWrapper.getObject(AbsObjectWrapper.java:67) at anywheresoftware.b4a.objects.TextViewWrapper.setText(TextViewWrapper.java:39) at b4a.example.main._config_views_info(main.java:436) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.ShellBA.raiseEvent2(ShellBA.java:146) at anywheresoftware.b4a.BA$2.run(BA.java:387) at android.os.Handler.handleCallback(Handler.java:751) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:154) at android.app.ActivityThread.main(ActivityThread.java:6176) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:893) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:783)لینک ارسال
