java.lang.NoClassDefFoundError: Failed resolution of: Lcom/google/android/gms/ads/interstitial/InterstitialAdLoadCallback;
at idea.eapp.menu._globals(menu.java:7301)
at anywheresoftware.b4a.BA.raiseEvent2(BA.java:213)
at idea.eapp.menu.initializeGlobals(menu.java:327)
at idea.eapp.menu.afterFirstLayout(menu.java:102)
at idea.eapp.menu.access$000(menu.java:17)
at idea.eapp.menu$WaitForLayout.run(menu.java:83)
at android.os.Handler.handleCallback(Handler.java:751)
at android.os.Looper.loop(Looper.java:154)
at android.app.ActivityThread.main(ActivityThread.java:6682)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1520)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1410)
Caused by: java.lang.ClassNotFoundException: Didn't find class "com.google.android.gms.ads.interstitial.InterstitialAdLoadCallback" on path: DexPathList[[zip file "/data/app/idea.eapp-1/base.apk"],nativeLibraryDirectories=[/data/app/idea.eapp-1/lib/arm64, /system/lib64, /vendor/lib64]]
at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56)
at java.lang.ClassLoader.loadClass(ClassLoader.java:380)
at java.lang.ClassLoader.loadClass(ClassLoader.java:312)
... 14 more
fun_code 222
بنده قصد دارم با کدهای لینک زیر تبلیغ تمام صفحه (Interstitial) رو در اپلیکیشن نمایش بدم:
https://www.b4x.com/android/forum/threads/firebaseadmob2-google-mobile-ads-sdk-v20.129609/
اما خطای زیر رو نمایش میده.
دلیلش چیه ؟
java.lang.NoClassDefFoundError: Failed resolution of: Lcom/google/android/gms/ads/interstitial/InterstitialAdLoadCallback; at idea.eapp.menu._globals(menu.java:7301) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.BA.raiseEvent2(BA.java:213) at idea.eapp.menu.initializeGlobals(menu.java:327) at idea.eapp.menu.afterFirstLayout(menu.java:102) at idea.eapp.menu.access$000(menu.java:17) at idea.eapp.menu$WaitForLayout.run(menu.java:83) at android.os.Handler.handleCallback(Handler.java:751) at android.os.Handler.dispatchMessage(Handler.java:95) at android.os.Looper.loop(Looper.java:154) at android.app.ActivityThread.main(ActivityThread.java:6682) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1520) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1410) Caused by: java.lang.ClassNotFoundException: Didn't find class "com.google.android.gms.ads.interstitial.InterstitialAdLoadCallback" on path: DexPathList[[zip file "/data/app/idea.eapp-1/base.apk"],nativeLibraryDirectories=[/data/app/idea.eapp-1/lib/arm64, /system/lib64, /vendor/lib64]] at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56) at java.lang.ClassLoader.loadClass(ClassLoader.java:380) at java.lang.ClassLoader.loadClass(ClassLoader.java:312) ... 14 moreلینک ارسال
