Execution failed for task ':app:extractDebugAnnotations'.
> Could not resolve all files for configuration ':app:detachedConfiguration1'.
> Could not find lint-checks-31.2.2.jar (com.android.tools.lint:lint-checks:31.2.2).
Searched in the following locations:
https://dl.google.com/dl/android/maven2/com/android/tools/lint/lint-checks/31.2.2/lint-checks-31.2.2.jar
> Could not find intellij-core-31.2.2.jar (com.android.tools.external.com-intellij:intellij-core:31.2.2).
https://dl.google.com/dl/android/maven2/com/android/tools/external/com-intellij/intellij-core/31.2.2/intellij-core-31.2.2.jar
> Could not find kotlin-compiler-31.2.2.jar (com.android.tools.external.com-intellij:kotlin-compiler:31.2.2).
https://dl.google.com/dl/android/maven2/com/android/tools/external/com-intellij/kotlin-compiler/31.2.2/kotlin-compiler-31.2.2.jar
> Could not find uast-31.2.2.jar (com.android.tools.external.org-jetbrains:uast:31.2.2).
https://dl.google.com/dl/android/maven2/com/android/tools/external/org-jetbrains/uast/31.2.2/uast-31.2.2.jar
> Could not find play-sdk-proto-31.2.2.jar (com.android.tools:play-sdk-proto:31.2.2).
https://dl.google.com/dl/android/maven2/com/android/tools/play-sdk-proto/31.2.2/play-sdk-proto-31.2.2.jar
Possible solution:
- Declare repository providing the artifact, see the documentation at https://docs.gradle.org/current/userguide/declaring_repositories.html
شکن متصل هست
حتی فایل هایی ک لینک داده را هم بصورت جدا دانلود کردم ولی نمیدونستم جدا باید قرار بگیرند
DexterFstone 399
سلام هنگام بیلد پروژه ی همچنین اروری دریافت میکنم
Execution failed for task ':app:extractDebugAnnotations'. > Could not resolve all files for configuration ':app:detachedConfiguration1'. > Could not find lint-checks-31.2.2.jar (com.android.tools.lint:lint-checks:31.2.2). Searched in the following locations: https://dl.google.com/dl/android/maven2/com/android/tools/lint/lint-checks/31.2.2/lint-checks-31.2.2.jar > Could not find intellij-core-31.2.2.jar (com.android.tools.external.com-intellij:intellij-core:31.2.2). Searched in the following locations: https://dl.google.com/dl/android/maven2/com/android/tools/external/com-intellij/intellij-core/31.2.2/intellij-core-31.2.2.jar > Could not find kotlin-compiler-31.2.2.jar (com.android.tools.external.com-intellij:kotlin-compiler:31.2.2). Searched in the following locations: https://dl.google.com/dl/android/maven2/com/android/tools/external/com-intellij/kotlin-compiler/31.2.2/kotlin-compiler-31.2.2.jar > Could not find uast-31.2.2.jar (com.android.tools.external.org-jetbrains:uast:31.2.2). Searched in the following locations: https://dl.google.com/dl/android/maven2/com/android/tools/external/org-jetbrains/uast/31.2.2/uast-31.2.2.jar > Could not find play-sdk-proto-31.2.2.jar (com.android.tools:play-sdk-proto:31.2.2). Searched in the following locations: https://dl.google.com/dl/android/maven2/com/android/tools/play-sdk-proto/31.2.2/play-sdk-proto-31.2.2.jar Possible solution: - Declare repository providing the artifact, see the documentation at https://docs.gradle.org/current/userguide/declaring_repositories.htmlشکن متصل هست
حالا موندم مشکل چیه؟
