سلام هنگام بیلد پروژه خطا دریافت میکنم
تا قبل اینکه بخوام یک پوشه به اسم aidl بسازم پروژه راحت بیلد میشد ولی بعدش ک یکم زیاده روی کردم پروژه دچار خطا شد
Starting a Gradle Daemon, 1 busy and 1 incompatible and 2 stopped Daemons could not be reused, use --status for details
> Task :app:verifyReleaseResources FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':app:verifyReleaseResources'.
> A failure occurred while executing com.android.build.gradle.tasks.VerifyLibraryResourcesTask$Action
> Android resource linking failed
ERROR: AAPT: error: resource style/Theme.AppCompat.NoActionBar (aka com.example.godotpoolakey:style/Theme.AppCompat.NoActionBar) not found.
error: failed linking references.
* Try:
> Run with --stacktrace option to get the stack trace.
> Run with --info or --debug option to get more log output.
> Run with --scan to get full insights.
> Get more help at https://help.gradle.org.
Deprecated Gradle features were used in this build, making it incompatible with Gradle 9.0.
You can use '--warning-mode all' to show the individual deprecation warnings and determine if they come from your own scripts or plugins.
For more on this, please refer to https://docs.gradle.org/8.2/userguide/command_line_interface.html#sec:command_line_warnings in the Gradle documentation.
BUILD FAILED in 1m 13s
57 actionable tasks: 57 executed
هم اکنون می توانید مطلب خود را ارسال نمایید و بعداً ثبت نام کنید.
اگر حساب کاربری دارید، برای ارسال با حساب کاربری خود اکنون وارد شوید .
DexterFstone 396
Starting a Gradle Daemon, 1 busy and 1 incompatible and 2 stopped Daemons could not be reused, use --status for details > Task :app:verifyReleaseResources FAILED FAILURE: Build failed with an exception. * What went wrong: Execution failed for task ':app:verifyReleaseResources'. > A failure occurred while executing com.android.build.gradle.tasks.VerifyLibraryResourcesTask$Action > Android resource linking failed ERROR: AAPT: error: resource style/Theme.AppCompat.NoActionBar (aka com.example.godotpoolakey:style/Theme.AppCompat.NoActionBar) not found. error: failed linking references. * Try: > Run with --stacktrace option to get the stack trace. > Run with --info or --debug option to get more log output. > Run with --scan to get full insights. > Get more help at https://help.gradle.org. Deprecated Gradle features were used in this build, making it incompatible with Gradle 9.0. You can use '--warning-mode all' to show the individual deprecation warnings and determine if they come from your own scripts or plugins. For more on this, please refer to https://docs.gradle.org/8.2/userguide/command_line_interface.html#sec:command_line_warnings in the Gradle documentation. BUILD FAILED in 1m 13s 57 actionable tasks: 57 executed
