از سمپل خود گیتهاب استفاده می کنم و مشخصات رو درست وارد میکنم اما زمان پرداخت ، مرحله قیمت و پرداخت بالا میاد . پس نشون میده که اتصال درسته اما برنامه بسته میشه و به ساب زیر گیر میده:
Private Sub Purchase_PurchaseFlowBegan
ToastMessageShow("Purchase flow began", False)
و خطای زیر رو میده :
*** Service (starter) Create ***
** Service (starter) Start **
** Activity (main) Create (first time) **
** Activity (main) Resume **
Unexpected event (missing RaiseSynchronousEvents): purchase_purchaseflowbegan
Check the unfiltered logs for the full stack trace.
** Activity (main) Pause, UserClosed = false **
Error occurred on line: 115 (Main)
java.lang.NullPointerException: Attempt to read from field 'anywheresoftware.b4a.BA com.shamimevesal.cattell187.main.activityBA' on a null object reference in method 'java.lang.String com.shamimevesal.cattell187.main._purchase_purchaseflowbegan()'
at com.shamimevesal.cattell187.main._purchase_purchaseflowbegan(main.java:709)
at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732)
at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348)
at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255)
at anywheresoftware.b4a.shell.Shell$2.run(Shell.java:321)
at android.os.Handler.handleCallback(Handler.java:958)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:230)
at android.os.Looper.loop(Looper.java:319)
at android.app.ActivityThread.main(ActivityThread.java:8919)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:578)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1103)
مشکل چیه. خسته م کرده
وقتی Private Sub Purchase_PurchaseFlowBegan رو کاملا حذف میکنم مشکل حل میشه
seyed_27 170
Private Sub Purchase_PurchaseFlowBegan ToastMessageShow("Purchase flow began", False) End Subو خطای زیر رو میده :
*** Service (starter) Create *** ** Service (starter) Start ** ** Activity (main) Create (first time) ** ** Activity (main) Resume ** Unexpected event (missing RaiseSynchronousEvents): purchase_purchaseflowbegan Check the unfiltered logs for the full stack trace. ** Activity (main) Pause, UserClosed = false ** Error occurred on line: 115 (Main) java.lang.NullPointerException: Attempt to read from field 'anywheresoftware.b4a.BA com.shamimevesal.cattell187.main.activityBA' on a null object reference in method 'java.lang.String com.shamimevesal.cattell187.main._purchase_purchaseflowbegan()' at com.shamimevesal.cattell187.main._purchase_purchaseflowbegan(main.java:709) at java.lang.reflect.Method.invoke(Native Method) at anywheresoftware.b4a.shell.Shell.runMethod(Shell.java:732) at anywheresoftware.b4a.shell.Shell.raiseEventImpl(Shell.java:348) at anywheresoftware.b4a.shell.Shell.raiseEvent(Shell.java:255) at anywheresoftware.b4a.shell.Shell$2.run(Shell.java:321) at android.os.Handler.handleCallback(Handler.java:958) at android.os.Handler.dispatchMessage(Handler.java:99) at android.os.Looper.loopOnce(Looper.java:230) at android.os.Looper.loop(Looper.java:319) at android.app.ActivityThread.main(ActivityThread.java:8919) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:578) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1103)مشکل چیه. خسته م کرده
کسی از رفقا سورس کامل پرداخت رو داره ؟
