دوستان قبلا یکی دو تا دیگه تاپیک هم ایجاد کرده بودم در مورد ذخیره کردن و لود کردن اطلاعات ولی متاسفانه به جوابی نرسیدم ممنون میشم اساتید محترم این سوال بنده رو جواب بدن الان یه هفته هستش که با همین یه دونه مشکل درگیرم....
این کد لیبل هستش که از مقدار ذخیره شده استفاده میکنه :
Dim Label1 As Label
Label1.Initialize("")
Label1.Color=Colors.White
Label1.TextColor=Colors.Black
Label1.Text=line
Label1.TextSize=Setting.FontSize
Label1.Typeface=Typeface.LoadFromAssets(Setting.FontType&".ttf")
اینم کد ذخیره ی اطلاعات هستش :
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Sub Process_Globals
Dim FontSize As String
Dim FontType As String
Private SeekBar1 As SeekBar
Private Spinner1 As Spinner
Private Label3 As Label
Activity.LoadLayout("scroll")
Activity.Title = "تنظیمات"
ScrollView1.Panel.LoadLayout("Setting")
If File.Exists(File.DirInternal,"FontType.txt") = False Then
File.Copy(File.DirAssets,"FontType.txt",File.DirInternal,"FontType.txt")
If File.Exists(File.DirInternal,"FontSize.txt") = False Then
File.Copy(File.DirAssets,"FontSize.txt",File.DirInternal,"FontSize.txt")
If File.Exists(File.DirInternal,"lineheight.txt") = False Then
File.Copy(File.DirAssets,"lineheight.txt",File.DirInternal,"lineheight.txt")
Spinner1.AddAll(Array As String("byekan","bnazanin","Rezvan"))
FontType = File.ReadString(File.DirInternal,"FontType.txt")
FontSize= File.ReadString(File.DirInternal,"FontSize.txt")
SeekBar1.Value = FontSize
Dim ts As TextSetting
ts.LabelDesign(Label3,SeekBar1.Value,"Null",FontType)
Sub Activity_Resume
Sub SeekBar1_ValueChanged (Value As Int, UserChanged As Boolean)
Label3.TextSize = Value
FontSize = Value
Sub Spinner1_ItemClick (Position As Int, Value As Object)
Label3.Typeface = Typeface.LoadFromAssets(Value&".ttf")
FontType = Value
Sub Button1_Click
File.WriteString(File.DirInternal,"FontType.txt",Spinner1.SelectedItem)
File.WriteString(File.DirInternal,"FontSize.txt",SeekBar1.Value)
ToastMessageShow("تنظیمات با موفقیت اعمال شد",False)
StartActivity(Main)
Activity.Finish()
StartActivity(Main)
Activity.Finish
فقط اکتیویتی تنظیمات به صورتی هستش که فقط برای اولین بار که برنامه نصب شد اجرا میشه و از دفعات بعدی دیگه اجرا نمیشه ولی مشکلش اینه که اگه اجرا نشه لیبل نمی تونه نوع فونت یا اندازه ی فونت رو پیدا کنه و در نتیجه ارور میده...
kavehshahedi 16
درود مجدد
با تشکر
