این سورس باید باعث بشه که وقتی کاربر روی مثلا خروج کلیک کرد ، خارج بشه.
ولی چنین اتفاقی نمی افته.
هیچی فایل هم که نمیشه پیوست کرد.
#Region Project Attributes
#ApplicationLabel: once
#VersionCode: 1
#VersionName: 1
#SupportedOrientations: portrait
#CanInstallToExternalStorage: true
#End Region
#Region Activity Attributes
#FullScreen: true
#IncludeTitle: True
#End Region
Dim listview1 As ListView
Dim Label1 As Label
Activity.LoadLayout("list")
listview1.AddSingleline2("خوش آمدید",1)
listview1.AddSingleline2("سفید رنگ",2)
listview1.AddSingleline2("زرد رنگ",3)
listview1.AddSingleline2("قرمز رنگ",4)
listview1.AddSingleline2("خروج",5)
listview1.singlelinelayout.Label.Gravity=Gravity.center
Sub Activity_Resume
Sub listview1_ltemClick(Position As Int ,value As Object)
If value=1 Then
Label1.Text="خوش آمدید"
If value=2 Then
Label1.Text="سفید رنگ"
Label1.TextColor=Colors.White
If value=3 Then
Label1.Text="زرد رنگ"
Label1.TextColor=Colors.yellow
If value=4 Then
Label1.Text="قرمز رنگ"
Label1.TextColor=Colors.red
If value=5 Then
ExitApplication
1messi 11
#Region Project Attributes #ApplicationLabel: once #VersionCode: 1 #VersionName: 1 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: portrait #CanInstallToExternalStorage: true #End Region #Region Activity Attributes #FullScreen: true #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim listview1 As ListView Dim Label1 As Label End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("list") listview1.AddSingleline2("خوش آمدید",1) listview1.AddSingleline2("سفید رنگ",2) listview1.AddSingleline2("زرد رنگ",3) listview1.AddSingleline2("قرمز رنگ",4) listview1.AddSingleline2("خروج",5) listview1.singlelinelayout.Label.Gravity=Gravity.center End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub listview1_ltemClick(Position As Int ,value As Object) If value=1 Then Label1.Text="خوش آمدید" End If If value=2 Then Label1.Text="سفید رنگ" Label1.TextColor=Colors.White End If If value=3 Then Label1.Text="زرد رنگ" Label1.TextColor=Colors.yellow End If If value=4 Then Label1.Text="قرمز رنگ" Label1.TextColor=Colors.red End If If value=5 Then ExitApplication End If End Subلینک ارسال
