آقا من SQL دارم که از id , list , matn من list روی Panel ست کردم و بعد میخوام وقتی روی Panel زده شد matn اون پنل رو تو یک اکتیویتی دیگه نمایش بده این سورس صفحه ای که توش Panel ها هست
#Region Activity Attributes
#FullScreen: True
#IncludeTitle: False
#End Region
Private Label1 As Label
Private Panel1 As Panel
Dim curtemp As Int
Dim Stop As Int = 3%y
Dim meghdar As String
Dim SQL1 As SQL
Dim cur1 As Cursor
Activity.LoadLayout("SVL")
If File.Exists(File.DirInternal,"Joke-db.db") = False Then
File.Copy(File.DirAssets,"Joke-db.db",File.DirInternal,"Joke-db.db")
SQL1.Initialize(File.DirInternal,"Joke-db.db",False)
cur1 = SQL1.ExecQuery("SELECT * FROM Mytable")
Panel1.Initialize("")
For i = 0 To cur1.RowCount-1
cur1.Position = i
meghdar = cur1.Getint("id")
Dim p As Panel
p.Initialize("p")
ScrollView1.Panel.AddView(p,0,Stop,100%x,100%y)
Stop = Stop + 15%y
Panel1.Tag = i
p.LoadLayout("InfoJK")
Label1.Text = cur1.GetString("list")
ScrollView1.Panel.Height = Stop
Sub Activity_Resume
Sub Panel1_Click
Dim iz As Panel
iz = Sender
StartActivity("InfoJK_Matlab")
اینم سورس اکیتویتی که میخوام توش مطالب باشه
#FullScreen: False
#IncludeTitle: True
#End Region
Activity.LoadLayout("InfoJK_Matlab")
Sub Activity_Resume
Assassin-Wolf 13
#Region Activity Attributes #FullScreen: True #IncludeTitle: False #End Region Sub Process_Globals End Sub Sub Globals Private Label1 As Label Private Panel1 As Panel Private ScrollView1 As ScrollView Dim curtemp As Int Dim Stop As Int = 3%y Dim meghdar As String Dim SQL1 As SQL Dim cur1 As Cursor End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("SVL") If File.Exists(File.DirInternal,"Joke-db.db") = False Then File.Copy(File.DirAssets,"Joke-db.db",File.DirInternal,"Joke-db.db") End If SQL1.Initialize(File.DirInternal,"Joke-db.db",False) cur1 = SQL1.ExecQuery("SELECT * FROM Mytable") Panel1.Initialize("") For i = 0 To cur1.RowCount-1 cur1.Position = i meghdar = cur1.Getint("id") Dim p As Panel p.Initialize("p") ScrollView1.Panel.AddView(p,0,Stop,100%x,100%y) Stop = Stop + 15%y Panel1.Tag = i p.LoadLayout("InfoJK") Label1.Text = cur1.GetString("list") ScrollView1.Panel.Height = Stop Next End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub Panel1_Click Dim iz As Panel iz = Sender StartActivity("InfoJK_Matlab") End Subاینم سورس اکیتویتی که میخوام توش مطالب باشه
#Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("InfoJK_Matlab") End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subلینک ارسال
