من یک قسمت ساختم به اسم Setting که این سورس اش هست
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim FontSize As String
Dim FontType As String
Dim LineHeight As String
Private SeekBar1 As SeekBar
Private Spinner1 As Spinner
Private Label3 As Label
Private SeekBar2 As SeekBar
Activity.LoadLayout("Setting_")
Activity.Title = "تنظیمات"
If File.Exists(File.DirInternal,"FontType.txt") = False Then
File.Copy(File.DirAssets,"FontType.txt",File.DirInternal,"FontType.txt")
If File.Exists(File.DirInternal,"FontSize.txt") = False Then
File.Copy(File.DirAssets,"FontSize.txt",File.DirInternal,"FontSize.txt")
If File.Exists(File.DirInternal,"lineheight.txt") = False Then
File.Copy(File.DirAssets,"lineheight.txt",File.DirInternal,"lineheight.txt")
Spinner1.AddAll(Array As String("byekan","bnazanin","Titr"))
FontType = File.ReadString(File.DirInternal,"FontType.txt")
FontSize = File.ReadString(File.DirInternal,"FontSize.txt")
LineHeight = File.ReadString(File.DirInternal,"lineheight.txt")
SeekBar1.Value = FontSize
SeekBar2.Value = LineHeight
Dim ts As TextSetting
ts.Initialize
ts.LabelDesign(Label3,SeekBar1.Value,"Null",FontType)
Sub Activity_Resume
Sub SeekBar1_ValueChanged (Value As Int, UserChanged As Boolean)
Label3.TextSize = Value
FontSize = Value
Sub SeekBar2_ValueChanged (Value As Int, UserChanged As Boolean)
LineHeight = Value
Sub Spinner1_ItemClick (Position As Int, Value As Object)
Label3.Typeface = Typeface.LoadFromAssets(Value&".ttf")
FontType = Value
Sub Button1_Click
File.WriteString(File.DirInternal,"FontType.txt",Spinner1.SelectedItem)
File.WriteString(File.DirInternal,"FontSize.txt",SeekBar1.Value)
File.WriteString(File.DirInternal,"lineheight",SeekBar2.Value)
ToastMessageShow("تنظیمات با موفقیت اعمال شد",False)
Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
Activity.Finish
اما نمیدونم چجوری کاری کنم که این تنظیمات در بقیه بخش ها کار کند
Assassin-Wolf 13
#Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals Dim FontSize As String Dim FontType As String Dim LineHeight As String End Sub Sub Globals Private SeekBar1 As SeekBar Private Spinner1 As Spinner Private Label3 As Label Private ScrollView1 As ScrollView Private SeekBar2 As SeekBar End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("Setting_") Activity.Title = "تنظیمات" If File.Exists(File.DirInternal,"FontType.txt") = False Then File.Copy(File.DirAssets,"FontType.txt",File.DirInternal,"FontType.txt") End If If File.Exists(File.DirInternal,"FontSize.txt") = False Then File.Copy(File.DirAssets,"FontSize.txt",File.DirInternal,"FontSize.txt") End If If File.Exists(File.DirInternal,"lineheight.txt") = False Then File.Copy(File.DirAssets,"lineheight.txt",File.DirInternal,"lineheight.txt") End If Spinner1.AddAll(Array As String("byekan","bnazanin","Titr")) FontType = File.ReadString(File.DirInternal,"FontType.txt") FontSize = File.ReadString(File.DirInternal,"FontSize.txt") LineHeight = File.ReadString(File.DirInternal,"lineheight.txt") SeekBar1.Value = FontSize SeekBar2.Value = LineHeight Dim ts As TextSetting ts.Initialize ts.LabelDesign(Label3,SeekBar1.Value,"Null",FontType) End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub SeekBar1_ValueChanged (Value As Int, UserChanged As Boolean) Label3.TextSize = Value FontSize = Value End Sub Sub SeekBar2_ValueChanged (Value As Int, UserChanged As Boolean) LineHeight = Value End Sub Sub Spinner1_ItemClick (Position As Int, Value As Object) Label3.Typeface = Typeface.LoadFromAssets(Value&".ttf") FontType = Value End Sub Sub Button1_Click File.WriteString(File.DirInternal,"FontType.txt",Spinner1.SelectedItem) File.WriteString(File.DirInternal,"FontSize.txt",SeekBar1.Value) File.WriteString(File.DirInternal,"lineheight",SeekBar2.Value) ToastMessageShow("تنظیمات با موفقیت اعمال شد",False) End Sub Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event If KeyCode = KeyCodes.KEYCODE_BACK Then Activity.Finish End If End Subاما نمیدونم چجوری کاری کنم که این تنظیمات در بقیه بخش ها کار کند
