#Region Activity Attributes
#FullScreen: True
#IncludeTitle: False
#End Region
Dim s As SQL
Dim sc As ScrollView
Dim ts As TextSetting
'Activity.LoadLayout("InfoJK_Matlab")
If File.Exists(File.DirInternal,"Joke-db.db") = False Then
File.Copy(File.DirAssets,"Joke-db.db",File.DirInternal,"Joke-db.db")
If s.IsInitialized=False Then
s.Initialize(File.DirInternal,"Joke-db.db",False)
sc.Initialize(800dip)
Dim cur1 As Cursor
cur1 = s.ExecQuery("SELECT * FROM Mytable where id="&InfoJK.fasl)
cur1.Position=0
Activity.AddView(sc,0,0,100%x,100%y)
Dim l As Label
l.Initialize("l")
l.Text=cur1.GetString("matn")
l.TextColor=Colors.Black
l.Typeface=Typeface.LoadFromAssets(File.ReadString(File.DirInternal,"FontType.txt") & ".ttf")
ts.LongText(l,l.Text,File.ReadString(File.DirInternal,"FontSize.txt"),sc,File.ReadString(File.DirInternal,"lineheight.txt"))
sc.Panel.AddView(l,10dip,0,95%x,sc.Height)
sc.Color=Colors.ARGB(255,191, 85, 236)
Dim su As StringUtils
Dim f As Float
f=su.MeasureMultilineTextHeight(l,l.Text)
l.Height=f
sc.Height=sc.Panel.Height
sc.Panel.Height=f+80%y
Sub Activity_Resume
Assassin-Wolf 13
سلام . من روی برنامم این کد رو با Lib . TExSetting اضافه کردم . بعد از اومدن به اون قسمت که کد ها اضافه شده این میاد
این هم کدی که اضافه شده
این هم سورس اون قسمت
#Region Activity Attributes #FullScreen: True #IncludeTitle: False #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. Dim s As SQL End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim sc As ScrollView Dim ts As TextSetting End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: 'Activity.LoadLayout("InfoJK_Matlab") If File.Exists(File.DirInternal,"Joke-db.db") = False Then File.Copy(File.DirAssets,"Joke-db.db",File.DirInternal,"Joke-db.db") End If If s.IsInitialized=False Then s.Initialize(File.DirInternal,"Joke-db.db",False) End If sc.Initialize(800dip) Dim cur1 As Cursor cur1 = s.ExecQuery("SELECT * FROM Mytable where id="&InfoJK.fasl) cur1.Position=0 Activity.AddView(sc,0,0,100%x,100%y) Dim l As Label l.Initialize("l") l.Text=cur1.GetString("matn") l.TextColor=Colors.Black l.Typeface=Typeface.LoadFromAssets(File.ReadString(File.DirInternal,"FontType.txt") & ".ttf") ts.LongText(l,l.Text,File.ReadString(File.DirInternal,"FontSize.txt"),sc,File.ReadString(File.DirInternal,"lineheight.txt")) sc.Panel.AddView(l,10dip,0,95%x,sc.Height) sc.Color=Colors.ARGB(255,191, 85, 236) Dim su As StringUtils Dim f As Float f=su.MeasureMultilineTextHeight(l,l.Text) l.Height=f sc.Height=sc.Panel.Height sc.Panel.Height=f+80%y End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subلینک ارسال
