#Region Activity Attributes
#FullScreen: True
#IncludeTitle: False
#End Region
Sub Process_Globals
Dim s As SQL
Dim sc As ScrollView
Dim ts As TextSetting
'Activity.LoadLayout("InfoJK_Matlab")
If File.Exists(File.DirInternal,"Joke-db.db") = False Then
File.Copy(File.DirAssets,"Joke-db.db",File.DirInternal,"Joke-db.db")
If s.IsInitialized=False Then
s.Initialize(File.DirInternal,"Joke-db.db",False)
sc.Initialize(800dip)
Dim cur1 As Cursor
cur1 = s.ExecQuery("SELECT * FROM Mytable where id="&InfoJK.fasl)
cur1.Position=0
Activity.AddView(sc,0,0,100%x,100%y)
Dim l As Label
l.Initialize("l")
l.Text=cur1.GetString("matn")
l.TextColor=Colors.Black
l.Typeface=Typeface.LoadFromAssets(File.ReadString(File.DirInternal,"FontType.txt") & ".ttf")
ts.LongText(l,l.Text,File.ReadString(File.DirInternal,"FontSize.txt"),sc,File.ReadString(File.DirInternal,"lineheight.txt"))
sc.Panel.AddView(l,10dip,0,95%x,sc.Height)
sc.Color=Colors.ARGB(255,191, 85, 236)
Dim su As StringUtils
Dim f As Float
f=su.MeasureMultilineTextHeight(l,l.Text)
l.Height=f
sc.Height=sc.Panel.Height
sc.Panel.Height=f+80%y
Sub Activity_Resume
Assassin-Wolf 13
سلام . من روی برنامم این کد رو با Lib . TExSetting اضافه کردم . بعد از اومدن به اون قسمت که کد ها اضافه شده این میاد
این هم کدی که اضافه شده
این هم سورس اون قسمت
