من یه فایل جیسون دارم میخام متنش رو به دیتابیس اضافه کنم همه چی درسته فقط هر وقت برنامه رو باز میکنم همه رکورد ها دوباره تکرار میشن
اینم سورس
Dim s As SQL
Dim json As JSONParser
Private Label1 As Label
Private ListView1 As ListView
Private Spinner1 As Spinner
Private Label2 As Label
Dim fara As Farakhani
Dim cur1 As Cursor
If File.Exists(File.DirInternal,"test.db")= False Then
File.Copy(File.DirAssets,"test.db",File.DirInternal,"test.db")
If s.IsInitialized=False Then
s.Initialize(File.DirInternal,"test.db",False)
json.Initialize(File.ReadString(File.DirAssets,"test.txt"))
Dim m As Map
m=json.NextObject
Dim bas As List
bas=m.Get("basic4android.org")
For i=0 To bas.Size-1
m=bas.Get(i)
Label1.Text=(m.Get("name"))
Label2.Text=(m.Get("family"))
s.ExecNonQuery("INSERT INTO tbl1 (onvan,matn) VALUES ('"& Label1.Text &"','"& Label2.Text &"')")
ListView1.Clear
cur1 = s.ExecQuery("SELECT * FROM tbl1")
For i = 0 To cur1.RowCount-1
cur1.Position = i
fara.SingleLineTitr("test.db",s,cur1,"SELECT * FROM tbl1 ",ListView1,"onvan","id")
majid08 266
اینم سورس
Sub Process_Globals Dim s As SQL End Sub Sub Globals Dim json As JSONParser Private Label1 As Label Private ListView1 As ListView Private Spinner1 As Spinner Private Label2 As Label Dim fara As Farakhani Dim cur1 As Cursor End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("Layout1") If File.Exists(File.DirInternal,"test.db")= False Then File.Copy(File.DirAssets,"test.db",File.DirInternal,"test.db") End If If s.IsInitialized=False Then s.Initialize(File.DirInternal,"test.db",False) End If ' json.Initialize(File.ReadString(File.DirAssets,"test.txt")) Dim m As Map m=json.NextObject Dim bas As List bas=m.Get("basic4android.org") For i=0 To bas.Size-1 m=bas.Get(i) Label1.Text=(m.Get("name")) Label2.Text=(m.Get("family")) Next s.ExecNonQuery("INSERT INTO tbl1 (onvan,matn) VALUES ('"& Label1.Text &"','"& Label2.Text &"')") ListView1.Clear cur1 = s.ExecQuery("SELECT * FROM tbl1") For i = 0 To cur1.RowCount-1 cur1.Position = i fara.SingleLineTitr("test.db",s,cur1,"SELECT * FROM tbl1 ",ListView1,"onvan","id") Next End Subلینک ارسال
