Private EditText1 As EditText
Private Label1 As Label
Private Label2 As Label
Dim a As String
Dim time As Timer
Activity.LoadLayout("ma")
time.Enabled = True
time.Initialize("time",500)
If File.Exists(File.DirInternal,"text.txt") = False Then
File.Copy(File.DirAssets,"text.txt",File.DirInternal,"text.txt")
a = File.ReadString(File.DirInternal,"text.txt")
Label1.Text = a
Sub Activity_Resume
Sub time_Tick
File.WriteString(File.DirInternal,"text.txt",EditText1.Text)
Label2.Text = EditText1.Text
وقتی برنامه رو اجرا میکنم یه ایرادی میگیرده در موبایل
alaghemand 82
مشکل این کد کجاست که ایذاد میگیرد ؟؟؟
Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private EditText1 As EditText Private Label1 As Label Private Label2 As Label Dim a As String Dim time As Timer End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("ma") time.Enabled = True time.Initialize("time",500) If File.Exists(File.DirInternal,"text.txt") = False Then File.Copy(File.DirAssets,"text.txt",File.DirInternal,"text.txt") End If a = File.ReadString(File.DirInternal,"text.txt") Label1.Text = a End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub time_Tick File.WriteString(File.DirInternal,"text.txt",EditText1.Text) Label2.Text = EditText1.Text End Subوقتی برنامه رو اجرا میکنم یه ایرادی میگیرده در موبایل
