زمانی که در کد زیر xx را عددی زیر ۸ می زارم برنامه کار میکند ولی هنگامی که عددی بین ۸ تا ۱۱ قرار می دهم کار نکرده و برنامه را می بندد.
چرا؟؟؟؟
Private TH1 As TabHost
Private SV As ScrollView
Private Panel1 As Panel
Private L1 As Label
Private L3 As Label
Private IV2 As ImageView
Private IV1 As ImageView
Private L2 As Label
Private SV2 As ScrollView
Private Panel2 As Panel
Private IV8 As ImageView
Private IV7 As ImageView
Private L4 As Label
Private L5 As Label
Private L6 As Label
Activity.LoadLayout("TAPHOST")
Dim a(11) As String
a=Array As String("غیبت","عصبانیت","تهمت","تکبر","قضاشدننماز","حسد","حق الناس","اتلافوقت","پیمانشکنی","پرخوری","بداخلاقی","اسراف")
TH1.AddTab("بد","sv.bal")
TH1.AddTab("نیک","svv.bal")
TH1.SetLayout(0,0,100%x,100%y)
Dim up,xx As Int
up=0
For i=0 To xx
Dim pan,pan2 As Panel
pan.Initialize("")
SV.Panel.AddView(pan,0,up,100%x,500dip)
pan2.Initialize("")
SV2.Panel.AddView(pan2,0,up,100%x,500dip)
up=up+90dip
pan.LoadLayout("GONAH")
pan2.LoadLayout("savaab")
L1.Text=a(i)
L2.Text="." & i
L4.Text=a(i)
L5.Text="." & i
arf 30
چرا؟؟؟؟
Sub Globals Private TH1 As TabHost Private SV As ScrollView Private Panel1 As Panel Private L1 As Label Private L3 As Label Private IV2 As ImageView Private IV1 As ImageView Private L2 As Label Private SV2 As ScrollView Private Panel2 As Panel Private IV8 As ImageView Private IV7 As ImageView Private L4 As Label Private L5 As Label Private L6 As Label End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("TAPHOST") Dim a(11) As String a=Array As String("غیبت","عصبانیت","تهمت","تکبر","قضاشدننماز","حسد","حق الناس","اتلافوقت","پیمانشکنی","پرخوری","بداخلاقی","اسراف") TH1.AddTab("بد","sv.bal") TH1.AddTab("نیک","svv.bal") TH1.SetLayout(0,0,100%x,100%y) Dim up,xx As Int up=0 For i=0 To xx Dim pan,pan2 As Panel pan.Initialize("") SV.Panel.AddView(pan,0,up,100%x,500dip) pan2.Initialize("") SV2.Panel.AddView(pan2,0,up,100%x,500dip) up=up+90dip pan.LoadLayout("GONAH") pan2.LoadLayout("savaab") L1.Text=a(i) L2.Text="." & i L4.Text=a(i) L5.Text="." & i Next End Subلینک ارسال
