دوستان مشکلم در کوءری درستش رو به من بگین لطفا ممنون
Activity.LoadLayout("search1")
Activity.Color=Colors.White
If File.Exists(File.DirInternal,"a.db")=False Then
File.Copy(File.DirAssets,"a.db",File.DirInternal,"a.db")
If Act_Matlab.sq.IsInitialized=False Then
Act_Matlab.sq.Initialize(File.DirInternal,"a.db",False)
EditText1.Color=Colors.Transparent
Sub Activity_Resume
Sub btn_click
Dim b As Button
b=Sender
id=b.Tag
StartActivity(N1)
Sub btn1_Click
Dim text As String = EditText1.text
Dim d As String
If text = "" Then
d = "لطفا یک کلمه برای جستجو وارد کنید"
Msgbox2(d, "توجه", "تایید", "", "", LoadBitmap(File.DirAssets, "error.png"))
Return
Dim cur1 As Cursor
cur1=Act_Matlab.sq.ExecQuery("select * From Tbl WHERE fasl LIKE '%"&EditText1.text&"%' OR fasl LIKE '%"&EditText1.text&"%'")
If cur1.RowCount = 0 Then
d = "هیچ موردی یافت نشد!"
Return
Dim cur As Cursor
cur=Act_Matlab.sq.ExecQuery("select * From Tbl WHERE fasl LIKE '%"&EditText1.text&"%' OR fasl LIKE '%"&EditText1.text&"%'")
Dim h As Int
h=8%y
For i = 0 To cur.RowCount-1
cur.Position=i
Dim btn As Button
btn.Initialize("btn")
btn.text=cur.GetString("fasl")
btn.Tag=cur.GetInt("id")
btn.TextSize=16
btn.TextColor=Colors.White
If cur.GetInt("fav")=0 Then
Dim im As BitmapDrawable
im.Initialize(LoadBitmap(File.DirAssets,"B.png"))
btn.Background=im
btn.Background=im
ScrollView1.Panel.AddView(btn,0,h,100%x,13%Y)
ScrollView1.Panel.Height=(cur.RowCount)*13.5%y
h=h+13%Y
حسینh 50
Activity.LoadLayout("search1") Activity.Color=Colors.White If File.Exists(File.DirInternal,"a.db")=False Then File.Copy(File.DirAssets,"a.db",File.DirInternal,"a.db") End If If Act_Matlab.sq.IsInitialized=False Then Act_Matlab.sq.Initialize(File.DirInternal,"a.db",False) End If EditText1.Color=Colors.Transparent End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub btn_click Dim b As Button b=Sender id=b.Tag StartActivity(N1) End Sub Sub btn1_Click Dim text As String = EditText1.text Dim d As String If text = "" Then d = "لطفا یک کلمه برای جستجو وارد کنید" Msgbox2(d, "توجه", "تایید", "", "", LoadBitmap(File.DirAssets, "error.png")) Return Else '\/\/\/\/\/\/\/\//\/\ Dim cur1 As Cursor cur1=Act_Matlab.sq.ExecQuery("select * From Tbl WHERE fasl LIKE '%"&EditText1.text&"%' OR fasl LIKE '%"&EditText1.text&"%'") If cur1.RowCount = 0 Then d = "هیچ موردی یافت نشد!" Msgbox2(d, "توجه", "تایید", "", "", LoadBitmap(File.DirAssets, "error.png")) Return End If '/\/\/\/\/\//\/\/\/\/\/\ Dim cur As Cursor cur=Act_Matlab.sq.ExecQuery("select * From Tbl WHERE fasl LIKE '%"&EditText1.text&"%' OR fasl LIKE '%"&EditText1.text&"%'") Dim h As Int h=8%y For i = 0 To cur.RowCount-1 cur.Position=i '******* Dim btn As Button btn.Initialize("btn") btn.text=cur.GetString("fasl") btn.Tag=cur.GetInt("id") btn.TextSize=16 btn.TextColor=Colors.White If cur.GetInt("fav")=0 Then Dim im As BitmapDrawable im.Initialize(LoadBitmap(File.DirAssets,"B.png")) btn.Background=im Else Dim im As BitmapDrawable im.Initialize(LoadBitmap(File.DirAssets,"B.png")) btn.Background=im End If ScrollView1.Panel.AddView(btn,0,h,100%x,13%Y) ScrollView1.Panel.Height=(cur.RowCount)*13.5%y h=h+13%Y Next End If End Subعکس اررور را هم قرار دادم
