سلام دوستان من این کد رو نوشتم و ارور زیر رو دارم حین کامپایل لطفا کمک کنید.
#Region Project Attributes
#VersionCode: 1
#VersionName:
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim arc As ArcMenu
'Activity.LoadLayout("Layout1")
arc.Initialize(Activity,Me,"arc1",LoadBitmap(File.DirAssets,"circle_up.png"),Null,50%x,50%y)
Sub Activity_Resume
amirsafari 116
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim arc As ArcMenu End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: 'Activity.LoadLayout("Layout1") arc.Initialize(Activity,Me,"arc1",LoadBitmap(File.DirAssets,"circle_up.png"),Null,50%x,50%y) End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subاینم ارور
