yadgar 5 ارسال شده در 18 آذر، 2015 اشتراک گذاری ارسال شده در 18 آذر، 2015 B4A version: 5.02 Parsing code. Error Error parsing program. Error description: Unknown type: colorpickerdialog Are you missing a library reference? Occurred on line: 24 Dim dlColor As ColorPickerDialog دوستان این ارور مربوزط به چیه؟ من تا حالا به همچین اروری بر نخوردم اینم صفحه ی مربوط به همون اروره #Region Activity Attributes #FullScreen: True #IncludeTitle: False #End Region Sub Process_Globals End Sub Sub Globals Private ScrollView1 As ScrollView Private Button1 As Button Private Button2 As Button Private Button3 As Button Dim Cur As Cursor Dim int1 As Int Dim int2 As Int Dim su As StringUtils Dim l As Label Private Button4 As Button Private Panel2 As Panel Dim dlColor As ColorPickerDialog Dim ln As LNsetting End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("Khandan") ln.Initialize Dim p As PhoneWakeState p.KeepAlive(True) If File.Exists(File.DirInternal,"book.db") = False Then File.Copy(File.DirAssets,"book.db",File.DirInternal,"book.db") End If If Fehrest.Sql1.IsInitialized = False Then Fehrest.Sql1.Initialize(File.DirInternal,"book.db",False) End If Cur = Fehrest.Sql1.ExecQuery("select * from book where Name = '"& Fehrest.khandan &"'") For i = 0 To Cur.RowCount-1 Cur.Position=i l.Initialize("") l.Text = Cur.GetString("Matn") l.TextColor = Colors.Black l.Gravity = Gravity.CENTER l.TextSize = 22 l.Tag = i ScrollView1.Panel.AddView(l,0,0,ScrollView1.Width,ScrollView1.Height) Try l.TextColor = ln.get("n","Color") l.TextSize= ln.get("n","Size") l.Typeface = Typeface.LoadFromAssets(ln.get("n","Font")) Catch End Try int1 = su.MeasureMultilineTextHeight(l,l.Text) int2 = int1 + 2%y l.Height = int2 ScrollView1.Panel.Height = int2 Fehrest.khandan = 0 Next Try Dim b1 As Bitmap b1.Initialize(File.DirAssets,"fave"&Cur.GetString("Fav")&".png") Button1.SetBackgroundImage(b1) Catch End Try End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
yadgar 5 ارسال شده در 19 آذر، 2015 سازنده اشتراک گذاری ارسال شده در 19 آذر، 2015 دوست عزیز خیلیی ممنونم از راهنمایی هات مشکلم حل شد تشکر دوباره لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
yadgar 5 ارسال شده در 19 آذر، 2015 سازنده اشتراک گذاری ارسال شده در 19 آذر، 2015 دوست عزیز شما باید تمتم کتابخانه های مورد نیاز پروژه خود را در پوشه Libraries محل نصب بیسیک 4 اندروید خود بریزید تا با این دسته ارور ها مواجه فرمایش شما صحیح اما من سیستممو عوض کردم ومتاسفانه نتونستم ارشیو کتابخانه هامو حفظ کنم و این سورس متعلق به پروزه ی قبلیم بود که میخواستم اپدیتش کنم ولی در هر خال تشکر بابت تذکرت لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MahdiHD 1,748 ارسال شده در 18 آذر، 2015 اشتراک گذاری ارسال شده در 18 آذر، 2015 لطف کنید کد ها را در تگ کد قرار دهید تا خوب خوانده شود! لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ali2 115 ارسال شده در 18 آذر، 2015 اشتراک گذاری ارسال شده در 18 آذر، 2015 سلام مربوط به کتابخونه Dialogs این کتابخونه رو دانلود و درون پوشه بیسیک بریزید و تیک اونو بزنید لینک دانلود کتابخونه لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
yadgar 5 ارسال شده در 18 آذر، 2015 سازنده اشتراک گذاری ارسال شده در 18 آذر، 2015 با تشکر از راهنمایی هاتون خطای اولیه رفع و این خطا عن.ان می شو.د B4A version: 5.02 Parsing code. Error Error parsing program. Error description: Unknown type: lnsetting Are you missing a library reference? Occurred on line: 25 Dim ln As LNsetting لطفا راهنمایی کنید با تشکر دوباره لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
abbas2142 557 ارسال شده در 18 آذر، 2015 اشتراک گذاری ارسال شده در 18 آذر، 2015 این ارور هم مثل اینکه مربوط به کتابخونه LNsetting هستش که توی فروشگاه موجوده لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
MahdiHD 1,748 ارسال شده در 19 آذر، 2015 اشتراک گذاری ارسال شده در 19 آذر، 2015 دوست عزیز شما باید تمتم کتابخانه های مورد نیاز پروژه خود را در پوشه Libraries محل نصب بیسیک 4 اندروید خود بریزید تا با این دسته ارور ها مواجه نشوید! لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
yadgar 5
