سلام من 3 تا پنل دارم p1 -p2 - p3 میخام بزارم تو یه اسکرول ویو
تو این پنلها یه لیبل هست که متن رو از دیتابیس میگیره و اندازه متن متغییر هست
من هر کاری میکنم نمیشه
Dim m2 As Label
m2.Initialize("m2")
m2.Text=lb3.Text&" end"
Dim p1 ,p2 ,p3 As Panel
p3.Initialize("p3")
p2.Initialize("p2")
p1.Initialize("p1")
p1.Color=Colors.White
p3.AddView(m2,3%x,0%y,85%x,98%y)
p2.Color=Colors.RGB(230,210,210)
Dim stop As Int = 50%y
p1.AddView(lb3,3%x,0%y,85%x,98%y)
p2.AddView(p1,2%x,2%y,96%x,0)
Dim end1 As Int = 98%y
ScrollView1.Panel.AddView(p2,1%y,stop,100%x,end1)
end1=p2.Height+10%y
ScrollView1.Panel.AddView(p3,0,p2.Height+10%y,100%x,end1)
Dim s As AutoSizeScroll
s.set(lb3,ScrollView1)
s.set(m2,ScrollView1)
ScrollView1.Panel.Height=lb3.Height+m2.Height+stop
p1.Height=ScrollView1.Panel.Height
p2.Height=-2
p3.Height=p2.Height
majid08 266
Dim m2 As Label m2.Initialize("m2") m2.Text=lb3.Text&" end" Dim p1 ,p2 ,p3 As Panel p3.Initialize("p3") p2.Initialize("p2") p1.Initialize("p1") p1.Color=Colors.White p3.AddView(m2,3%x,0%y,85%x,98%y) p2.Color=Colors.RGB(230,210,210) Dim stop As Int = 50%y p1.AddView(lb3,3%x,0%y,85%x,98%y) p2.AddView(p1,2%x,2%y,96%x,0) Dim end1 As Int = 98%y ScrollView1.Panel.AddView(p2,1%y,stop,100%x,end1) end1=p2.Height+10%y ScrollView1.Panel.AddView(p3,0,p2.Height+10%y,100%x,end1) Dim s As AutoSizeScroll s.set(lb3,ScrollView1) s.set(m2,ScrollView1) ScrollView1.Panel.Height=lb3.Height+m2.Height+stop p1.Height=ScrollView1.Panel.Height p2.Height=-2 p3.Height=p2.Heightلینک ارسال
