دوستان توی یه کتاب در قسمت لیست مورد علاقه می خوام وقتی روی گزینه هاش کلیک شد بره به اون مطلب ولی وقتی این رو مینویسم ارور میده. ممنون میشم از دوستان کمک کنند:
Private ListView1 As ListView
Activity.LoadLayout("FavLayout")
If File.Exists(File.DirInternal,"mydb.db")=False Then
File.Copy(File.DirAssets,"mydb.db",File.DirInternal,"mydb.db")
If Tuts.s.IsInitialized=False Then
Tuts.s.Initialize(File.DirInternal,"mydb.db",False)
Dim cur As Cursor
cur=Tuts.s.ExecQuery("SELECT * FROM Tbl1 WHERE Neshan=1")
For i=0 To cur.RowCount-1
cur.Position=i
ListView1.AddSingleLine(cur.GetString("Onvan"))
ListView1.SingleLineLayout.Label.TextSize = 24
ListView1.SingleLineLayout.Label.Typeface = Typeface.LoadFromAssets("byekan.ttf")
ListView1.SingleLineLayout.Label.TextColor = Colors.Black
Dim back As BitmapDrawable
back.Initialize(LoadBitmap(File.DirAssets,"buttonnewnormal.png"))
ListView1.SingleLineLayout.Label.Background = back
ListView1.SingleLineLayout.Label.Gravity = Gravity.CENTER
ListView1.SingleLineLayout.ItemHeight = 13%y
Sub Activity_Resume
Tuts.Fasl=Value
StartActivity(Act_Matlab)
kavehshahedi 16
Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private ListView1 As ListView End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("FavLayout") If File.Exists(File.DirInternal,"mydb.db")=False Then File.Copy(File.DirAssets,"mydb.db",File.DirInternal,"mydb.db") End If If Tuts.s.IsInitialized=False Then Tuts.s.Initialize(File.DirInternal,"mydb.db",False) End If Dim cur As Cursor cur=Tuts.s.ExecQuery("SELECT * FROM Tbl1 WHERE Neshan=1") For i=0 To cur.RowCount-1 cur.Position=i ListView1.AddSingleLine(cur.GetString("Onvan")) ListView1.SingleLineLayout.Label.TextSize = 24 ListView1.SingleLineLayout.Label.Typeface = Typeface.LoadFromAssets("byekan.ttf") ListView1.SingleLineLayout.Label.TextColor = Colors.Black Dim back As BitmapDrawable back.Initialize(LoadBitmap(File.DirAssets,"buttonnewnormal.png")) ListView1.SingleLineLayout.Label.Background = back ListView1.SingleLineLayout.Label.Gravity = Gravity.CENTER ListView1.SingleLineLayout.ItemHeight = 13%y Next End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub ListView1_ItemClick (Position As Int, Value As Object) Tuts.Fasl=Value StartActivity(Act_Matlab) End Subبا تشکر
