مشکل با مولتی پنل
davood1382
سلام من یک مولتی پنل ساختم اما وقتی مخواهد برنامه بالا بیاد این ارور رو میده و ناقص میشه مولتی پنلpost-3816-0-34877600-1444487192_thumb.png
Activity.LoadLayout("layout")
If File.Exists(File.DirInternal,"multipanel.db") = False Then
File.Copy(File.DirAssets,"multipanel.db",File.DirInternal,"multipanel.db")
sql.Initialize(File.DirInternal,"multipanel.db",False)
cur1 = sql.ExecQuery("SELECT *FROM TBL")
myfont = Typeface.LoadFromAssets("BTraffic.ttf")
For i=0 To cur1.RowCount-1
cur1.Position=i
text= cur1.GetString("SMS")
ScrollView1.Panel.Color = Colors.Transparent
Dim p1 As Panel
p1.Initialize("")
p1.LoadLayout("sms")
ScrollView1.Panel.AddView(p1,0,PanelHeight,100%x,100dip)
ht=art(text,Label1,myfont,20)
Label1.TextColor=Colors.White
p1.Height=ht+70dip
PanelHeight=PanelHeight+ht+70dip
ScrollView1.Panel.Height=PanelHeight
Sub art(txt As String,leb As Label,font As Typeface,size As Int) As Float
Dim before,after As Float
Dim Obj1 As Reflector
leb.text=txt
leb.TextSize=size
leb.Gravity=Gravity.CENTER
leb.Left=leb.Left
leb.Typeface=font
ht = StrUtil.MeasureMultilineTextHeight(leb , txt)
Obj1.Target = leb
before = Obj1.RunMethod("getLineHeight")
Obj1.Target = leb
Obj1.RunMethod3("setLineSpacing", .10, "java.lang.float", 1.5, "java.lang.float")
Obj1.Target = leb
after = Obj1.RunMethod("getLineHeight")
ht = ((after * ht)/before)
leb.Height = ht
Return ht
