ایمان سعیدی 48 ارسال شده در 5 آذر، 2014 اشتراک گذاری ارسال شده در 5 آذر، 2014 توضیحات تو خود سورس http://s5.picofile.com/file/8138981650/anim.rar.html #Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim a1 As Animation Private Button1 As Button Private Button2 As Button Private Button3 As Button Private Button4 As Button Private Button5 As Button Private Button6 As Button End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("1") End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub Button1_Click a1.InitializeScaleCenter("",1,1,0,0,Button1) a1.Duration = 1000 ' in mesle timer amal mikone a1.RepeatCount = 1' in tekrareshe a1.RepeatMode = a1.REPEAT_REVERSE ' in yani bargasht be halate aval a1.Start(Button1) End Sub Sub Button2_Click a1.InitializeAlpha("a1",1,0) a1.Duration = 1000 ' in mesle timer amal mikone a1.RepeatCount = 1' in tekrareshe a1.RepeatMode = a1.REPEAT_REVERSE ' in yani bargasht be halate aval a1.Start(Button2) End Sub Sub Button3_Click a1.InitializeScale("",1,1,0,0) a1.Duration = 1000 ' in mesle timer amal mikone a1.RepeatCount = 1' in tekrareshe a1.RepeatMode = a1.REPEAT_REVERSE ' in yani bargasht be halate aval a1.Start(Button3) End Sub Sub Button4_Click a1.InitializeRotateCenter("",0,180,Button4) a1.Duration = 1000 ' in mesle timer amal mikone a1.RepeatCount = 1' in tekrareshe a1.RepeatMode = a1.REPEAT_REVERSE ' in yani bargasht be halate aval a1.Start(Button4) End Sub Sub Button5_Click a1.InitializeRotate("",0,180) a1.Duration = 1000 ' in mesle timer amal mikone a1.RepeatCount = 1' in tekrareshe a1.RepeatMode = a1.REPEAT_REVERSE ' in yani bargasht be halate aval a1.Start(Button5) End Sub Sub Button6_Click a1.InitializeTranslate("a1",0,0,0,100) a1.Duration = 1000 ' in mesle timer amal mikone a1.RepeatCount = 1' in tekrareshe a1.RepeatMode = a1.REPEAT_REVERSE ' in yani bargasht be halate aval a1.Start(Button6) End Sub ' age Sub Button6_Click in bashe ' a1.InitializeTranslate("a1",0,0,0,100) ' a1.Duration = 1000 ' a1.Start(Button6) 'End Sub 'va 'Sub a1_AnimationEnd 'Button6.Top = Button6.Top+100 'End Sub 'tasvir dg barnemigarde لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ارمین رمضانی دلیجانی 381 ارسال شده در 5 آذر، 2014 اشتراک گذاری ارسال شده در 5 آذر، 2014 سلام ممنون عالی بود اما توضیحاتی توش ندیدم :| یه خورده بگو در مورد کار با انیمیشن لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
ایمان سعیدی 48 ارسال شده در 5 آذر، 2014 سازنده اشتراک گذاری ارسال شده در 5 آذر، 2014 تاپیک update شد لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
مهران محمودی 778 ارسال شده در 5 آذر، 2014 اشتراک گذاری ارسال شده در 5 آذر، 2014 با عرض سلام، ایمان ممنون بابت سورس ولی: 1- سورس کد رو باید پیوست میکردی. 2- توضیحات باید بدی در مورد کارت تا قبل از دانلود کاربر بدونه به چه دردی میخوره این سورس. 3- این تاپیک 4- تو که کد قرار دادی، چپ چین میکردی که از سمت چپ نوشته بشن، اینطوری خیلی بد شده و ناجور. میدونم زحمت کشیدی، ولی ما دوست داریم هممون بهترین کار رو ارائه بدیم. موفق باشی. لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
kiyan 11 ارسال شده در 10 آذر، 2014 اشتراک گذاری ارسال شده در 10 آذر، 2014 با عرض سلام،ایمان ممنون بابت سورس ولی: 1- سورس کد رو باید پیوست میکردی. 2- توضیحات باید بدی در مورد کارت تا قبل از دانلود کاربر بدونه به چه دردی میخوره این سورس. 3- این تاپیک 4- تو که کد قرار دادی، چپ چین میکردی که از سمت چپ نوشته بشن، اینطوری خیلی بد شده و ناجور. میدونم زحمت کشیدی، ولی ما دوست داریم هممون بهترین کار رو ارائه بدیم. موفق باشی. من خودم مدیر سایتم میدونم دقیقا حس مدیر سایت رو .. شما ک قوی هستید بر اساس قوانین عمل کنید .. تا نظم بهتری روی سایت حاکم باشه مرسی از مدیریت لینک ارسال به اشتراک گذاری در سایت های دیگر تنظیمات بیشتر اشتراک گذاری ...
