سلام دوستان. من یه سورس انیمیشن دارم ولی هر کاری میکنم نمیتونم کد موردنظرم رو بیرون بکشم. من میخوام انیمیشن باتن 3 رو در سورس روی یک باتن دیگر به اسم star اجرا کنم.
به این صورت که تایمر هر 5 ثانیه این انیمیشن رو اجرا کنه.
#Region Module Attributes
#FullScreen: False
#IncludeTitle: True
#ApplicationLabel: Animation Example
#VersionCode: 1
#VersionName:
#End Region
'Activity module
Dim Button1 As Button
Dim Button2 As Button
Dim Button3 As Button
Dim Button4 As Button
Dim Button5 As Button
Dim Button6 As Button
Dim Button7 As Button
Dim Button8 As Button
Dim Button9 As Button
Dim a6, a7, a8, a9 As Animation
Dim a1, a2, a3, a4, a5 As Animation
Activity.LoadLayout("1")
a1.InitializeAlpha("", 1, 0)
Button1.Tag = a1
a2.InitializeRotate("", 0, 180)
Button2.Tag = a2
a3.InitializeRotateCenter("", 0, 180, Button3)
Button3.Tag = a3
a4.InitializeScale("", 1, 1, 0, 5)
Button4.Tag = a4
a5.InitializeScaleCenter("", 1, 1, 0, 0, Button4)
Button5.Tag = a5
Dim animations() As Animation
animations = Array As Animation(a1, a2, a3, a4, a5)
For i = 0 To animations.Length - 1
animations(i).Duration = 1000
animations(i).RepeatCount = 1
animations(i).RepeatMode = animations(i).REPEAT_REVERSE
a6.InitializeTranslate("Animation", 0, 0, 0dip, 200dip) 'we want to catch the AnimationEnd event for these animations
a7.InitializeTranslate("Animation", 0dip, 200dip, -200dip, 200dip)
a8.InitializeTranslate("Animation", -200dip, 200dip, -200dip, 0dip)
a9.InitializeTranslate("Animation", -200dip, 0dip, 0dip, 0dip)
Button6.Tag = a6
animations = Array As Animation(a6, a7, a8, a9)
animations(i).Duration = 500
Sub Animation_AnimationEnd
If Sender = a6 Then
a7.Start(Button6)
Else If Sender = a7 Then
a8.Start(Button6)
Else If Sender = a8 Then
a9.Start(Button6)
Sub Button_Click
Dim b As Button
b = Sender
'Safety check. Not really required in this case.
If Not(b.Tag Is Animation) Then Return
Dim a As Animation
a = b.Tag
a.Start(b)
طاها 480
