سلام دوستان بنده سورس کدی دارم که برای ارتباط به دیتابیس mysql استفاده میشه ولی طریقه استفادش رو نمیدونم دوستان کسی اگه میدونه برای دانلود اطلاعات دیتابیس(تیبل) در این سورس کد چه کنم راهنمائی کنند
Dim mh1 As MysqlHandler
Dim rs1 As ResultSet
Dim sv1 As ScrollView
Dim lv1 As ListView
Dim hsv1 As HorizontalScrollView
mh1.Initialize("lcl:port","dbname","user","pass!")
If mh1.isConnected = False Then
Msgbox(mh1.SQLError, "Connection Error:")
Return
rs1 = mh1.Query("SELECT * FROM order")
If rs1.IsInitialized = False Then
Msgbox("ResultSet is empty" & CRLF & mh1.SQLError, "Warning")
Return
hsv1.Initialize(rs1.ColumnCount * 150dip,0)
Activity.AddView(hsv1,0,0,100%x,100%y)
sv1.Initialize(rs1.RowCount * 30dip)
hsv1.Panel.AddView(sv1,0,0,rs1.ColumnCount*150dip,100%y)
Dim l As Label
For i=0 To rs1.RowCount - 1
rs1.Position = i
For j=0 To rs1.ColumnCount - 1
l.Initialize("label" & j)
l.Text = rs1.GetString(j)
l.TextColor = Colors.Black
l.Color = Colors.White
sv1.Panel.AddView(l,j*150dip,i*30dip,149dip,29dip)
mh1.Close
sourse 82
Sub Globals Dim mh1 As MysqlHandler Dim rs1 As ResultSet Dim sv1 As ScrollView Dim lv1 As ListView Dim hsv1 As HorizontalScrollView End Sub Sub Activity_Create(FirstTime As Boolean) mh1.Initialize("lcl:port","dbname","user","pass!") If mh1.isConnected = False Then Msgbox(mh1.SQLError, "Connection Error:") Return End If rs1 = mh1.Query("SELECT * FROM order") If rs1.IsInitialized = False Then Msgbox("ResultSet is empty" & CRLF & mh1.SQLError, "Warning") Return End If hsv1.Initialize(rs1.ColumnCount * 150dip,0) Activity.AddView(hsv1,0,0,100%x,100%y) sv1.Initialize(rs1.RowCount * 30dip) hsv1.Panel.AddView(sv1,0,0,rs1.ColumnCount*150dip,100%y) Dim l As Label For i=0 To rs1.RowCount - 1 rs1.Position = i For j=0 To rs1.ColumnCount - 1 l.Initialize("label" & j) l.Text = rs1.GetString(j) l.TextColor = Colors.Black l.Color = Colors.White sv1.Panel.AddView(l,j*150dip,i*30dip,149dip,29dip) Next Next mh1.Close End Subلینک ارسال
