سلام به همه اساتید عزیز ممکنه من رو راهنمایی کنید که در این ساب دقیقا دستور map چی کار میکنه اصلا کار دستور و پارامتر map چی هست
Sub EncryptTableField(TableName As String, Fieldname As String, PrimaryKey As String)
Dim i, u, pk As Int
Dim s As String
Dim m As Map: m.Initialize
cur = db.ExecQuery("Select " & PrimaryKey & ", " & Fieldname & " FROM " & TableName)
u = cur.RowCount-1
For i = 0 To u
cur.Position=i
k = cur.getInt(PrimaryKey)
s = cur.GetString(Fieldname)
m.Put(k,s)
cur.Close
db.BeginTransaction
For i = 0 To u
pk = m.GetKeyAt(i)
s = m.GetValueAt(i)
s = Crypt.Encrypt(s)' <--
db.ExecNonQuery("UPDATE " & TableName & " SET " & Fieldname & " = '" & s & "' WHERE " & PrimaryKey & " = " & pk)
db.TransactionSuccessful
db.EndTransaction
arastooms 1,046
Sub EncryptTableField(TableName As String, Fieldname As String, PrimaryKey As String) Dim i, u, pk As Int Dim s As String Dim m As Map: m.Initialize cur = db.ExecQuery("Select " & PrimaryKey & ", " & Fieldname & " FROM " & TableName) u = cur.RowCount-1 For i = 0 To u cur.Position=i k = cur.getInt(PrimaryKey) s = cur.GetString(Fieldname) m.Put(k,s) Next cur.Close db.BeginTransaction For i = 0 To u pk = m.GetKeyAt(i) s = m.GetValueAt(i) s = Crypt.Encrypt(s)' <-- db.ExecNonQuery("UPDATE " & TableName & " SET " & Fieldname & " = '" & s & "' WHERE " & PrimaryKey & " = " & pk) Next db.TransactionSuccessful db.EndTransaction End Subلینک ارسال
