راهنمایی در نوشتن این کد
vahidhosseini
سلام این کد من هست
[color=#333333][font=Tahoma]#Region Project Attributes [/font][/color]
[color=#333333][font=Tahoma]#ApplicationLabel: cloob-kermanshah[/font][/color]
[color=#333333][font=Tahoma]#VersionCode: 1[/font][/color]
[color=#333333][font=Tahoma]#VersionName: [/font][/color]
[color=#333333][font=Tahoma]'SupportedOrientations possible values: unspecified, landscape or portrait.[/font][/color]
[color=#333333][font=Tahoma]#SupportedOrientations: unspecified[/font][/color]
[color=#333333][font=Tahoma]#CanInstallToExternalStorage: False[/font][/color]
[color=#333333][font=Tahoma]#End Region[/font][/color]
[color=#333333][font=Tahoma]#Region Activity Attributes [/font][/color]
[color=#333333][font=Tahoma]#FullScreen: False[/font][/color]
[color=#333333][font=Tahoma]#IncludeTitle: True[/font][/color]
[color=#333333][font=Tahoma]Sub Process_Globals[/font][/color]
[color=#333333][font=Tahoma]'These global variables will be declared once when the application starts.[/font][/color]
[color=#333333][font=Tahoma]'These variables can be accessed from all modules.[/font][/color]
[color=#333333][font=Tahoma]End Sub[/font][/color]
[color=#333333][font=Tahoma]Sub Globals[/font][/color]
[color=#333333][font=Tahoma]'These global variables will be redeclared each time the activity is created.[/font][/color]
[color=#333333][font=Tahoma]'These variables can only be accessed from this module.[/font][/color]
[color=#333333][font=Tahoma]Dim timer1 As Timer[/font][/color]
[color=#333333][font=Tahoma]Dim WebView2 As WebView[/font][/color]
[color=#333333][font=Tahoma]Sub Activity_Create(FirstTime As Boolean)[/font][/color]
[color=#333333][font=Tahoma]'Do not forget to load the layout file created with the visual designer. For example:[/font][/color]
[color=#333333][font=Tahoma]Activity.LoadLayout("splash")[/font][/color]
[color=#333333][font=Tahoma]timer1.Initialize("timer1",1500)[/font][/color]
[color=#333333][font=Tahoma]timer1.Enabled=True[/font][/color]
[color=#333333][font=Tahoma]Msgbox("به کلوب کرمانشاه خوش آمدید","message")[/font][/color]
[color=#333333][font=Tahoma]Sub Activity_Resume[/font][/color]
[color=#333333][font=Tahoma]Sub Activity_Pause (UserClosed As Boolean)[/font][/color]
[color=#333333][font=Tahoma]Sub web[/font][/color]
[color=#333333][font=Tahoma]Dim myw As WebView[/font][/color]
[color=#333333][font=Tahoma]myw.Initialize("myw")[/font][/color]
[color=#333333][font=Tahoma]Activity.AddView(myw, 0, 0, 100%x, 100%y) 'Your options for size here[/font][/color]
[color=#333333][font=Tahoma]myw.LoadUrl("http://www.cloob-kermanshah.ir/m")[/font][/color]
[color=#333333][font=Tahoma]Sub timer1_tick[/font][/color]
[color=#333333][font=Tahoma]Activity.LoadLayout("web")[/font][/color]
می خوام بعد از اجرای splash screen صفحه layout که برای وب انتخاب کردم آدرسشو فراخوانی لطفا راهنمایی کنید و اینکه در صورت متصل نبودن اینترنت به کاربر خطا بدهد ممنون میشم راهنمایی کنید
