بچه ها یه به این کدا یه نگاه بندازید ببنید کجا مشکل داره که بعضی لینک های فیلما نشون نمیده ارور عدم پخش میده میخوام هرلینک فیلمی که دادم پخش کنه .
Sub Class_Globals
Private ht As HttpJob
Private sFileName As String
Private VideoView1 As VideoView
Private Url As String
Dim dier As String
#Region Initialize Video Stream
'Play Video if it is cache and if not cache then download it
'and show in videoView
Public Sub Initialize(sUrl As String,VideoViews As VideoView)
dier = File.DirRootExternal& "/ehsan"
sFileName = sUrl.SubString(sUrl.LastIndexOf("/")+1)
VideoView1 = VideoViews
'If File.Exists(File.DirRootExternal,sFileName) = False Then
If File.Exists(dier,sFileName) = False Then
If checkInternet = False Then
ToastMessageShow("فایل موجود نمی باشد",True)
ToastMessageShow("لطفا اینترنت را فعال کنید",True)
Return
Url = sUrl
initHttp
Httputils.Download("downloadFile",sUrl)
'VideoViews.LoadVideo(File.DirRootExternal,sFileName)
VideoViews.LoadVideo(dier,sFileName)
VideoViews.Play
Sub initHttp
Httputils.CallbackActivity = "actDownload"
Httputils.CallbackJobDoneSub = "JobDone"
Httputils.CallbackUrlDoneSub = "UrlDone"
Httputils.CallbackProgressSub="ProgressHTTP"
#End Region
Private Sub JobDone (Job As String)
Select Job
Case "downloadFile"
If Httputils.IsSuccess(Url) Then
'HttpUtils.SaveFile(Url,File.DirRootExternal,sFileName)
Httputils.SaveFile(Url,dier,sFileName)
'VideoView1.LoadVideo(File.DirRootExternal,sFileName)
VideoView1.LoadVideo(dier,sFileName)
VideoView1.Play
End Select
Httputils.Complete = False
Sub checkInternet As Boolean
Dim p As Phone
Dim connected As Boolean
connected = False
If (p.GetDataState == "CONNECTED") Then
connected = True
If (p.GetSettings ("wifi_on") == 1) Then
connected = True
Return connected
'Version 1.04
Dim Tasks As List 'List of URLs to fetch.
'A map that holds the successful links.
'The links are stored as keys. The values are not used.
Dim SuccessfulUrls As Map
Dim Working As Boolean 'True when a job is still running
Dim Complete As Boolean 'True after a job has completer
Dim Job As String 'Name of the current running Job
Dim CallbackActivity As String 'Name of Activity that handles the callbacks.
Dim CallbackJobDoneSub As String 'Name of the JobDone callback sub.
Dim CallbackUrlDoneSub As String 'Name of the UrlDone callback sub.
Dim CallbackProgressSub As String 'download progress of file
Type ProgressStatus(Downloaded As Long,Total As Long)
'Download a single resource (GET method).
Sub Download(JobName As String, URL As String)
DownloadList(JobName, Array As String(URL))
'Downloads a list of resources (GET method).
Sub DownloadList(JobName As String, URLs As List)
If internalCheckIfCanStart(JobName) = False Then Return
Tasks = URLs
HttputilsService.Post = False
StartService(HttputilsService)
'Sends a POST request with the given string as the post data
Sub PostString(JobName As String, URL As String, Text As String)
PostBytes(JobName, URL, Text.GetBytes("UTF8"))
'Sends a POST request with the given file send as the post data.
Sub PostFile(JobName As String, URL As String, Dir As String, FileName As String)
Dim length As Int
If Dir = File.DirAssets Then
Log("Cannot send files from the assets folder.")
Return
length = File.Size(Dir, FileName)
Dim In As InputStream
In = File.OpenInput(Dir, FileName)
If length < 1000000 Then '1mb
'There are advantages for sending the file as bytes array. It allows the Http library to resend the data
'if it failed in the first time.
Dim out As OutputStream
out.InitializeToBytesArray(length)
File.Copy2(In, out)
HttputilsService.PostInputStream = Null
HttputilsService.PostBytes = out.ToBytesArray
HttputilsService.PostInputStream = In
HttputilsService.PostLength = length
Tasks = Array As String(URL)
HttputilsService.Post = True
'Sends a POST request with the given data as the post data.
Sub PostBytes(JobName As String, URL As String, Data() As Byte)
HttputilsService.PostBytes = Data
Sub internalCheckIfCanStart(JobName As String) As Boolean
If Working Then
Log("Already working. Request ignored (" & JobName & ")")
Return False
Log("Starting Job: " & JobName)
Job = JobName
Working = True
Complete = False
SuccessfulUrls.Initialize
Return True
Sub IsSuccess(URL As String) As Boolean
Return SuccessfulUrls.ContainsKey(URL)
'Get methods should be called only after the JobDone event or the UrlDone event.
Sub GetString(URL As String) As String
If IsSuccess(URL) = False Then
Log("Task not completed successfully.")
Return ""
Return File.GetText(HttputilsService.TempFolder, SuccessfulUrls.Get(URL))
Sub GetBitmap(URL As String) As Bitmap
Dim b As Bitmap
Return b
b = LoadBitmap(HttputilsService.TempFolder, SuccessfulUrls.Get(URL))
Return b
Sub SaveFile(URL As String, LocalPath As String,Fname As String)
File.Copy(HttputilsService.TempFolder, SuccessfulUrls.Get(URL),LocalPath,Fname)
Sub GetInputStream(URL As String) As InputStream
Return In
In = File.OpenInput(HttputilsService.TempFolder, SuccessfulUrls.Get(URL))
Return In
naser sahami 90
Sub Class_Globals Private ht As HttpJob Private sFileName As String Private VideoView1 As VideoView Private Url As String Dim dier As String End Sub #Region Initialize Video Stream 'Play Video if it is cache and if not cache then download it 'and show in videoView Public Sub Initialize(sUrl As String,VideoViews As VideoView) dier = File.DirRootExternal& "/ehsan" sFileName = sUrl.SubString(sUrl.LastIndexOf("/")+1) VideoView1 = VideoViews 'If File.Exists(File.DirRootExternal,sFileName) = False Then If File.Exists(dier,sFileName) = False Then If checkInternet = False Then ToastMessageShow("فایل موجود نمی باشد",True) ToastMessageShow("لطفا اینترنت را فعال کنید",True) Return End If Url = sUrl initHttp Httputils.Download("downloadFile",sUrl) Else 'VideoViews.LoadVideo(File.DirRootExternal,sFileName) VideoViews.LoadVideo(dier,sFileName) VideoViews.Play End If End Sub Sub initHttp Httputils.CallbackActivity = "actDownload" Httputils.CallbackJobDoneSub = "JobDone" Httputils.CallbackUrlDoneSub = "UrlDone" Httputils.CallbackProgressSub="ProgressHTTP" End Sub #End Region Private Sub JobDone (Job As String) dier = File.DirRootExternal& "/ehsan" Select Job Case "downloadFile" If Httputils.IsSuccess(Url) Then 'HttpUtils.SaveFile(Url,File.DirRootExternal,sFileName) Httputils.SaveFile(Url,dier,sFileName) 'VideoView1.LoadVideo(File.DirRootExternal,sFileName) VideoView1.LoadVideo(dier,sFileName) VideoView1.Play End If End Select Httputils.Complete = False End Sub Sub checkInternet As Boolean Dim p As Phone Dim connected As Boolean connected = False If (p.GetDataState == "CONNECTED") Then connected = True End If If (p.GetSettings ("wifi_on") == 1) Then connected = True End If Return connected End Sub'Version 1.04 Sub Process_Globals Dim Tasks As List 'List of URLs to fetch. 'A map that holds the successful links. 'The links are stored as keys. The values are not used. Dim SuccessfulUrls As Map Dim Working As Boolean 'True when a job is still running Dim Complete As Boolean 'True after a job has completer Dim Job As String 'Name of the current running Job Dim CallbackActivity As String 'Name of Activity that handles the callbacks. Dim CallbackJobDoneSub As String 'Name of the JobDone callback sub. Dim CallbackUrlDoneSub As String 'Name of the UrlDone callback sub. Dim CallbackProgressSub As String 'download progress of file Type ProgressStatus(Downloaded As Long,Total As Long) End Sub 'Download a single resource (GET method). Sub Download(JobName As String, URL As String) DownloadList(JobName, Array As String(URL)) End Sub 'Downloads a list of resources (GET method). Sub DownloadList(JobName As String, URLs As List) If internalCheckIfCanStart(JobName) = False Then Return Tasks = URLs HttputilsService.Post = False StartService(HttputilsService) End Sub 'Sends a POST request with the given string as the post data Sub PostString(JobName As String, URL As String, Text As String) PostBytes(JobName, URL, Text.GetBytes("UTF8")) End Sub 'Sends a POST request with the given file send as the post data. Sub PostFile(JobName As String, URL As String, Dir As String, FileName As String) If internalCheckIfCanStart(JobName) = False Then Return Dim length As Int If Dir = File.DirAssets Then Log("Cannot send files from the assets folder.") Return End If length = File.Size(Dir, FileName) Dim In As InputStream In = File.OpenInput(Dir, FileName) If length < 1000000 Then '1mb 'There are advantages for sending the file as bytes array. It allows the Http library to resend the data 'if it failed in the first time. Dim out As OutputStream out.InitializeToBytesArray(length) File.Copy2(In, out) HttputilsService.PostInputStream = Null HttputilsService.PostBytes = out.ToBytesArray Else HttputilsService.PostInputStream = In HttputilsService.PostLength = length End If Tasks = Array As String(URL) HttputilsService.Post = True StartService(HttputilsService) End Sub 'Sends a POST request with the given data as the post data. Sub PostBytes(JobName As String, URL As String, Data() As Byte) If internalCheckIfCanStart(JobName) = False Then Return HttputilsService.PostInputStream = Null HttputilsService.PostBytes = Data Tasks = Array As String(URL) HttputilsService.Post = True StartService(HttputilsService) End Sub Sub internalCheckIfCanStart(JobName As String) As Boolean If Working Then Log("Already working. Request ignored (" & JobName & ")") Return False End If Log("Starting Job: " & JobName) Job = JobName Working = True Complete = False SuccessfulUrls.Initialize Return True End Sub Sub IsSuccess(URL As String) As Boolean Return SuccessfulUrls.ContainsKey(URL) End Sub 'Get methods should be called only after the JobDone event or the UrlDone event. Sub GetString(URL As String) As String If IsSuccess(URL) = False Then Log("Task not completed successfully.") Return "" End If Return File.GetText(HttputilsService.TempFolder, SuccessfulUrls.Get(URL)) End Sub Sub GetBitmap(URL As String) As Bitmap Dim b As Bitmap If IsSuccess(URL) = False Then Log("Task not completed successfully.") Return b End If b = LoadBitmap(HttputilsService.TempFolder, SuccessfulUrls.Get(URL)) Return b End Sub Sub SaveFile(URL As String, LocalPath As String,Fname As String) If IsSuccess(URL) = False Then Log("Task not completed successfully.") End If File.Copy(HttputilsService.TempFolder, SuccessfulUrls.Get(URL),LocalPath,Fname) End Sub Sub GetInputStream(URL As String) As InputStream Dim In As InputStream If IsSuccess(URL) = False Then Log("Task not completed successfully.") Return In End If In = File.OpenInput(HttputilsService.TempFolder, SuccessfulUrls.Get(URL)) Return In End Subلینک ارسال
