سلام خیلی ممنونم
بفرمایین
java.lang.IllegalStateException: Couldn't read row 0, col -1 from CursorWindow.  Make sure the Cursor is initialized correctly before accessing data from it.
	at android.database.CursorWindow.nativeGetString(Native Method)
	at android.database.CursorWindow.getString(CursorWindow.java:434)
	at android.database.AbstractWindowedCursor.getString(AbstractWindowedCursor.java:51)
	at aria.gp.listview.array.adapter.DataBaseArrayAdapter.getView(DataBaseArrayAdapter.java:91)
	at android.widget.AbsListView.obtainView(AbsListView.java:2267)
	at android.widget.ListView.makeAndAddView(ListView.java:1769)
	at android.widget.ListView.fillDown(ListView.java:672)
	at android.widget.ListView.fillFromTop(ListView.java:733)
	at android.widget.ListView.layoutChildren(ListView.java:1622)
	at android.widget.AbsListView.onLayout(AbsListView.java:2102)
	at android.view.View.layout(View.java:13754)
	at android.view.ViewGroup.layout(ViewGroup.java:4362)
	at anywheresoftware.b4a.BALayout.onLayout(BALayout.java:43)
	at android.widget.FrameLayout.onLayout(FrameLayout.java:448)
	at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1649)
	at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1507)
	at android.widget.LinearLayout.onLayout(LinearLayout.java:1420)
	at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:1866)
	at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1687)
	at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:998)
	at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:4212)
	at android.view.Choreographer$CallbackRecord.run(Choreographer.java:725)
	at android.view.Choreographer.doCallbacks(Choreographer.java:555)
	at android.view.Choreographer.doFrame(Choreographer.java:525)
	at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:711)
	at android.os.Handler.handleCallback(Handler.java:615)
	at android.os.Handler.dispatchMessage(Handler.java:92)
	at android.os.Looper.loop(Looper.java:137)
	at android.app.ActivityThread.main(ActivityThread.java:4745)
	at java.lang.reflect.Method.invoke(Method.java:511)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
  • پاسخ 1.1k
  • ایجاد شده
  • آخرین پاسخ
بیشترین ارسال‌ها در این موضوع
ارسال‌های محبوب
تصاویر ارسال شده
LogCat connected to: emulator-5554
ParseApplication.onCreate xml Id = 2130968576
data null
data1 MTYVUtmRlQSzkHnpIYBUkfeDYkIeGY2xoq4TDOHf
data2 6ToH14QeJDeAZjwbtSAWS7HthAgOf0UAZOOzU7s8
** Service (notifyservice) Create **
** Service (notifyservice) Start **
** Service (starter) Create **
** Service (starter) Start **
** Activity (main) Resume **
java.lang.ClassCastException: android.widget.FrameLayout cannot be cast to android.widget.RelativeLayout
at aria.gp.listview.array.adapter.CustomArrayAdapter.getView(CustomArrayAdapter.java:82)
at android.widget.AbsListView.obtainView(AbsListView.java:2033)
at android.widget.ListView.makeAndAddView(ListView.java:1772)
at android.widget.ListView.fillFromTop(ListView.java:732)
at android.widget.ListView.layoutChildren(ListView.java:1625)
at android.widget.AbsListView.onLayout(AbsListView.java:1863)
at android.view.View.layout(View.java:11180)
at android.view.ViewGroup.layout(ViewGroup.java:4203)
at android.widget.FrameLayout.onLayout(FrameLayout.java:431)
at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1628)
at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1486)
at android.widget.LinearLayout.onLayout(LinearLayout.java:1399)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1468)
at android.view.ViewRootImpl.handleMessage(ViewRootImpl.java:2418)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.app.ActivityThread.main(ActivityThread.java:4340)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
نسیم جام مشکل شما از دیتابیس هستش ، querry ها و ... رو چک کنید ببینید مشکل از کجاست
_____________________________________________________
حمید جان مشکل شما هم از ناهماهنگ بودن ورژن کتابخونه و ریسورس هاس ، از آخرین ریسورس ها و آخرین ورژن کتابخونه استفاده کنید ، لیوت اصلی شما FrameLayout هستش که مربوط به ریسورس های قدیمی هستش و ادپتر میگه نمیتونه اون رو به RelativeLayout تبدیل کنه
LogCat connected to: B4A-Bridge: samsung SM-J500H-354748078011331
--------- beginning of main
--------- beginning of system
** Service (service1) Create **
** Service (service1) Start **
Connected to B4A-Bridge (Wifi)
	at android.widget.AbsListView.obtainView(AbsListView.java:2402)
	at android.widget.ListView.makeAndAddView(ListView.java:1891)
	at android.widget.ListView.fillDown(ListView.java:713)
	at android.widget.ListView.fillFromTop(ListView.java:779)
	at android.widget.ListView.layoutChildren(ListView.java:1699)
	at android.widget.AbsListView.onLayout(AbsListView.java:2206)
	at android.view.View.layout(View.java:16075)
	at android.view.ViewGroup.layout(ViewGroup.java:5300)
	at android.widget.FrameLayout.layoutChildren(FrameLayout.java:579)
	at android.widget.FrameLayout.onLayout(FrameLayout.java:514)
	at com.android.internal.widget.ActionBarOverlayLayout.onLayout(ActionBarOverlayLayout.java:494)
	at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:2119)
	at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1873)
	at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1073)
	at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:5988)
	at android.view.Choreographer$CallbackRecord.run(Choreographer.java:767)
	at android.view.Choreographer.doCallbacks(Choreographer.java:580)
	at android.view.Choreographer.doFrame(Choreographer.java:550)
	at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:753)
	at android.os.Handler.handleCallback(Handler.java:739)
	at android.os.Looper.loop(Looper.java:135)
	at android.app.ActivityThread.main(ActivityThread.java:5910)
	at java.lang.reflect.Method.invoke(Method.java:372)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1405)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1200)
این مشکل چیه؟
این مشکل چیه؟
تو پست قبلی خود امین همینو برای آقای زارع جواب داده
سلام اقای شاهدی خسته نباشید
من یک مشکلی توی دیتابیس داشتم و این بود که دیتابیس من 7 تا موضوع داره ک دو تا از موضوع ها هر کدوم لیستشون 1000 تایی هست
و توی برنامه وقتی روی موضوعش کلیک میکنم ی چند ثانیه ای تاخیر داره تا باز بشه
یکی از دوستان گفتن با کتابخونه شما این مشکل رفع میشه و منم کتابخونه رو خریدم
حالا وقتی لیست ویو رو تعریف میکنم ارور میده
حالا اگر شما راهنماییم کنین ممنون میشم
فک کنمداداش شما آموزشای اقای شاهدی روندیدین...
تو هموناایناروتوضیحو آموزش داده
ممنون از انتخابتون ولی به نظرتون فقط با گفتن اینکه ارور میده چه کمکی میتونم بکنم؟ یه توضیح کوچیک بدین و متن کامل ارور لاگ و تکه کدی که استفاده میکنین ... اینجوری خودتون هم راحت تر مشکلتون حل میشه
س دوستان برای تغییر فونت اینجا باید چیکار کرد
چون مثل لیست ویو معمولی تایپ فیس نداره
دوست عزیز اگه آموزش ها رو ببینید همه اینارو توضیح دادم !
از متد SetFont ادپتر استفاده کنید ، setfont1 برای تکست اول و setfont2 برای تکست دوم
AriaAdapter.SetFont1(Typeface.LoadFromAssets("felan.ttf"))
AriaAdapter.SetFont2(Typeface.LoadFromAssets("felan.ttf"))
مرسی امین جان
مشکلاتم رفع شد
حالا من توی کدنویسی ک برای لیست ویو معمولی میزاشتم میتونستم با کلیک روی هر ایتم با استفاده از value متن واسش لود کنم اما اینجا value نداریم
برای ساخت جستجو از این کد استفاده میکردم الان باید چطوری استفاده کنم
Dim cur As Cursor
cur = sql1.ExecQuery("SELECT * FROM drugs WHERE farsi LIKE '%" & EditText1.Text & "%'")
listview1.Clear
For i = 0 To cur.RowCount-1
cur.Position = i
listview1.AddSingleLine2(cur.GetString("farsi"),cur.GetInt("id"))
cur.Close
اینو چیکارش کنم داش
مرسی امین جان
مشکلاتم رفع شد
Dim cur As Cursor
listview1.Clear
cur.Position = i
cur.Close
اینو چیکارش کنم داش
دوست عزیز اون همه آموزش ظبط کردم واسه چی پس ؟
شما یه لیست اضافی بساز مثلا به اسم values و بزارش توی حلقه و مقداری که میخوای به صورت values لیست ویو داشته باشی  رو بریز توی این لیست ، خب حالا یه لیست از values داری که هرجایی میتونی استفاده کنی !
Sub list_select (ParentEventName As String,position As Int)
ToastMessageShow( values.Get(position) ,False)
، راه دیگه هم اینه : میتونی متن های نمایش داده شده توی هر آیتم لیست رو هم به این صورت بگیری :
	Log( AriaListView.GetLabelTextbyID("text1",position) )
	Log( AriaListView.GetLabelTextbyID("text2",position) )
شما یه لیست اضافی بساز مثلا به اسم values و بزارش توی حلقه و cur.GetInt("id") رو بریز توی این لیست ، خب حالا یه لیست از values داری که هرجایی میتونی استفاده کنی !
، میتونی متن های نمایش داده شده توی هر آیتم لیست رو هم به این صورت بگیری :
داداش حقیقتا کلا گیج شدم من توی دیتابیس id ساختم
حالا اگر اینایی ک لطف کردی و گفتی رو بصورت کد بنویس واسم
یه ایرادی که الان بنظرم اومد اینکه وقتی از متد Aadapterimage.SetColor استفاده میکنم افکت کلیک شدن از کار میفته و جایی که کلیک شده رو نشون نمیده ،منظورم فقط افکت ریپل نیستا کلا هیچ افکتی نداره!!!
سلامی دوباره به استاد شاهدی عزیز
یه سوال
میشه برای گالری  ویو از دیتابیس استفاده کرد من نتونستم ، اگر این قابلیت و نداره لطف کنید تو ورژن بعدی اضافه کنید چون فکر میکنم نیاز باشه که بشه عکسارو از طریق دیتابیس آپدیت کنیم
تشکر و سپاس فراوان   :41:
با این کار بکگراند رو عوض میکنید دیگه خب طبیعتا ریپل از بین میره ، اگه میخواین ریپل بمونه باید با xml رنگ هارو تغییر بدین
یه سوال
گالری میتونین bitmap بدین ولی خب چشم ورژن بعد قابلیت اینکه بتونین بایت هم بهش بدین رو اضافه میکنم تا مستقیم Cursor.getblob("test") I  رو بهش بدین
س دوستان من یه دیتابیس دارم با 7 موضوع و توی دیزاینر 7 تا پنل ساختم و گفتم اگر روشون کلیک شد برن اکتیویتی دیگر و اونجا با استفاده از دستور
select  دیتابیس رو لود کنن با توجه به اونی ک کلیک شد
البته من از کتابخونه اریا لیست ویو استفاده میکنم
وقتی روی ایتم مورد نظر کلیک میکنم صفحه خالی میاد و لیست مطالب لود نمیشن
س اقای شاهدی لطفا جواب بدین خدایی کتابخونه رو خریدم واسه همین کار و گرنه اینقدر نمی پرسیدم
دوست عزیز، استاد شاهدی احتمالا انلاین نشدن که جواب نمیدن دیگه،
شما فکر میکنم مشکلت دیتابیس هست و ربطی به کتابخونه نداره
تا زمانی که استاد شاهدی تشریف بیارن منتظر باشید...
تاپیک رو هم اگر تا 12 ساعت جواب نگرفتید بروز کنید، نه هر 4-5 ساعت...
موفق باشید...
ارسال پاسخ به این موضوع ...
