مجوز های اندروید همراه با توضیح
کاربر ناشناس
AddPermission(android.permission.ACCESS_CHECKIN_PROPERTIES)
' Allows read/write access to the "properties" table in the checkin database, to change values that get uploaded.
AddPermission(android.permission.ACCESS_COARSE_LOCATION)
' Allows an app to access approximate location derived from network location sources such as cell towers and Wi-Fi.
AddPermission(android.permission.ACCESS_FINE_LOCATION)
' Allows an app to access precise location from location sources such as GPS, cell towers, and Wi-Fi.
AddPermission(android.permission.ACCESS_LOCATION_EXTRA_COMMANDS)
' Allows an application to access extra location provider commands.
AddPermission(android.permission.ACCESS_MOCK_LOCATION)
' Allows an application to create mock location providers for testing.
AddPermission(android.permission.ACCESS_NETWORK_STATE)
' Allows applications to access information about networks.
AddPermission(android.permission.ACCESS_SURFACE_FLINGER)
' Allows an application to use SurfaceFlinger's low level features.
AddPermission(android.permission.ACCESS_WIFI_STATE)
' Allows applications to access information about Wi-Fi networks.
AddPermission(android.permission.ACCOUNT_MANAGER)
' Allows applications to call into AccountAuthenticators.
AddPermission(android.permission.ADD_VOICEMAIL)
' Allows an application to add voicemails into the system.
AddPermission(android.permission.AUTHENTICATE_ACCOUNTS)
' Allows an application to act as an AccountAuthenticator for the AccountManager.
AddPermission(android.permission.BATTERY_STATS)
' Allows an application to collect battery statistics.
AddPermission(android.permission.BIND_ACCESSIBILITY_SERVICE)
' Must be required by an AccessibilityService, to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_APPWIDGET)
' Allows an application to tell the AppWidget service which application can access AppWidget's data.
AddPermission(android.permission.BIND_DEVICE_ADMIN)
' Must be required by device administration receiver, to ensure that only the system can interact with it.
AddPermission(android.permission.BIND_INPUT_METHOD)
' Must be required by an InputMethodService, to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_NFC_SERVICE)
' Must be required by a HostApduService or OffHostApduService to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_NOTIFICATION_LISTENER_SERVICE)
' Must be required by an NotificationListenerService, to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_PRINT_SERVICE)
' Must be required by a PrintService, to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_REMOTEVIEWS)
' Must be required by a RemoteViewsService, to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_TEXT_SERVICE)
' Must be required by a TextService (e.g.
AddPermission(android.permission.BIND_VPN_SERVICE)
' Must be required by a VpnService, to ensure that only the system can bind to it.
AddPermission(android.permission.BIND_WALLPAPER)
' Must be required by a WallpaperService, to ensure that only the system can bind to it.
AddPermission(android.permission.BLUETOOTH)
' Allows applications to connect to paired bluetooth devices.
AddPermission(android.permission.BLUETOOTH_ADMIN)
' Allows applications to discover and pair bluetooth devices.
AddPermission(android.permission.BLUETOOTH_PRIVILEGED)
' Allows applications to pair bluetooth devices without user interaction.
AddPermission(android.permission.BRICK)
' Required to be able to disable the device (very dangerous!).
AddPermission(android.permission.BROADCAST_PACKAGE_REMOVED)
' Allows an application to broadcast a notification that an application package has been removed.
AddPermission(android.permission.BROADCAST_SMS)
' Allows an application to broadcast an SMS receipt notification.
AddPermission(android.permission.BROADCAST_STICKY)
' Allows an application to broadcast sticky intents.
AddPermission(android.permission.BROADCAST_WAP_PUSH)
' Allows an application to broadcast a WAP PUSH receipt notification.
AddPermission(android.permission.CALL_PHONE)
' Allows an application to initiate a phone call without going through the Dialer user interface for the user to confirm the call being placed.
AddPermission(android.permission.CALL_PRIVILEGED)
' Allows an application to call any phone number, including emergency numbers, without going through the Dialer user interface for the user to confirm the call being placed.
AddPermission(android.permission.CAMERA)
' Required to be able to access the camera device.
AddPermission(android.permission.CAPTURE_AUDIO_OUTPUT)
' Allows an application to capture audio output.
AddPermission(android.permission.CAPTURE_SECURE_VIDEO_OUTPUT)
' Allows an application to capture secure video output.
AddPermission(android.permission.CAPTURE_VIDEO_OUTPUT)
' Allows an application to capture video output.
AddPermission(android.permission.CHANGE_COMPONENT_ENABLED_STATE)
' Allows an application to change whether an application component (other than its own) is enabled or not.
AddPermission(android.permission.CHANGE_CONFIGURATION)
' Allows an application to modify the current configuration, such as locale.
AddPermission(android.permission.CHANGE_NETWORK_STATE)
' Allows applications to change network connectivity state.
AddPermission(android.permission.CHANGE_WIFI_MULTICAST_STATE)
' Allows applications to enter Wi-Fi Multicast mode.
AddPermission(android.permission.CHANGE_WIFI_STATE)
' Allows applications to change Wi-Fi connectivity state.
AddPermission(android.permission.CLEAR_APP_CACHE)
' Allows an application to clear the caches of all installed applications on the device.
AddPermission(android.permission.CLEAR_APP_USER_DATA)
' Allows an application to clear user data.
AddPermission(android.permission.CONTROL_LOCATION_UPDATES)
' Allows enabling/disabling location update notifications from the radio.
AddPermission(android.permission.DELETE_CACHE_FILES)
' Allows an application to delete cache files.
AddPermission(android.permission.DELETE_PACKAGES)
' Allows an application to delete packages.
AddPermission(android.permission.DEVICE_POWER)
' Allows low-level access to power management.
AddPermission(android.permission.DIAGNOSTIC)
' Allows applications to RW to diagnostic resources.
AddPermission(android.permission.DISABLE_KEYGUARD)
' Allows applications to disable the keyguard.
AddPermission(android.permission.DUMP)
' Allows an application to retrieve state dump information from system services.
AddPermission(android.permission.EXPAND_STATUS_BAR)
' Allows an application to expand or collapse the status bar.
AddPermission(android.permission.FACTORY_TEST)
' Run as a manufacturer test application, running as the root user.
AddPermission(android.permission.FLASHLIGHT)
' Allows access to the flashlight.
AddPermission(android.permission.FORCE_BACK)
' Allows an application to force a BACK operation on whatever is the top activity.
AddPermission(android.permission.GET_ACCOUNTS)
' Allows access to the list of accounts in the Accounts Service.
AddPermission(android.permission.GET_PACKAGE_SIZE)
' Allows an application to find out the space used by any package.
AddPermission(android.permission.GET_TASKS)
' Allows an application to get information about the currently or recently running tasks.
AddPermission(android.permission.GET_TOP_ACTIVITY_INFO)
' Allows an application to retrieve private information about the current top activity, such as any assist context it can provide.
AddPermission(android.permission.GLOBAL_SEARCH)
' This permission can be used on content providers to allow the global search system to access their data.
AddPermission(android.permission.HARDWARE_TEST)
' Allows access to hardware peripherals.
AddPermission(android.permission.INJECT_EVENTS)
' Allows an application to inject user events (keys, touch, trackball) into the event stream and deliver them to ANY window.
AddPermission(android.permission.INSTALL_LOCATION_PROVIDER)
' Allows an application to install a location provider into the Location Manager.
AddPermission(android.permission.INSTALL_PACKAGES)
' Allows an application to install packages.
AddPermission(android.permission.INSTALL_SHORTCUT)
' Allows an application to install a shortcut in Launcher.
AddPermission(android.permission.INTERNAL_SYSTEM_WINDOW)
' Allows an application to open windows that are for use by parts of the system user interface.
AddPermission(android.permission.INTERNET)
' Allows applications to open network sockets.
AddPermission(android.permission.KILL_BACKGROUND_PROCESSES)
' Allows an application to call killBackgroundProcesses(String).
AddPermission(android.permission.LOCATION_HARDWARE)
' Allows an application to use location features in hardware, such as the geofencing api.
AddPermission(android.permission.MANAGE_ACCOUNTS)
' Allows an application to manage the list of accounts in the AccountManager.
AddPermission(android.permission.MANAGE_APP_TOKENS)
' Allows an application to manage (create, destroy, Z-order) application tokens in the window manager.
AddPermission(android.permission.MANAGE_DOCUMENTS)
' Allows an application to manage access to documents, usually as part of a document picker.
AddPermission(android.permission.MASTER_CLEAR)
' Not for use by third-party applications.
AddPermission(android.permission.MEDIA_CONTENT_CONTROL)
' Allows an application to know what content is playing and control its playback.
AddPermission(android.permission.MODIFY_AUDIO_SETTINGS)
' Allows an application to modify global audio settings.
AddPermission(android.permission.MODIFY_PHONE_STATE)
' Allows modification of the telephony state - power on, mmi, etc.
AddPermission(android.permission.MOUNT_FORMAT_FILESYSTEMS)
' Allows formatting file systems for removable storage.
AddPermission(android.permission.MOUNT_UNMOUNT_FILESYSTEMS)
' Allows mounting and unmounting file systems for removable storage.
AddPermission(android.permission.NFC)
' Allows applications to perform I/O operations over NFC.
AddPermission(android.permission.PERSISTENT_ACTIVITY)
' This constant was deprecated in API level 9. This functionality will be removed in the future; please do not use. Allow an application to make its activities persistent.
AddPermission(android.permission.PROCESS_OUTGOING_CALLS)
' Allows an application to see the number being dialed during an outgoing call with the option to redirect the call to a different number or abort the call altogether.
AddPermission(android.permission.READ_CALENDAR)
' Allows an application to read the user's calendar data.
AddPermission(android.permission.READ_CALL_LOG)
' Allows an application to read the user's call log.
AddPermission(android.permission.READ_CONTACTS)
' Allows an application to read the user's contacts data.
AddPermission(android.permission.READ_EXTERNAL_STORAGE)
' Allows an application to read from external storage.
AddPermission(android.permission.READ_FRAME_BUFFER)
' Allows an application to take screen shots and more generally get access to the frame buffer data.
AddPermission(android.permission.READ_HISTORY_BOOKMARKS)
' Allows an application to read (but not write) the user's browsing history and bookmarks.
AddPermission(android.permission.READ_INPUT_STATE)
' This constant was deprecated in API level 16. The API that used this permission has been removed.
AddPermission(android.permission.READ_LOGS)
' Allows an application to read the low-level system log files.
AddPermission(android.permission.READ_PHONE_STATE)
' Allows read only access to phone state.
AddPermission(android.permission.READ_PROFILE)
' Allows an application to read the user's personal profile data.
AddPermission(android.permission.READ_SMS)
' Allows an application to read SMS messages.
AddPermission(android.permission.READ_SOCIAL_STREAM)
' Allows an application to read from the user's social stream.
AddPermission(android.permission.READ_SYNC_SETTINGS)
' Allows applications to read the sync settings.
AddPermission(android.permission.READ_SYNC_STATS)
' Allows applications to read the sync stats.
AddPermission(android.permission.READ_USER_DICTIONARY)
' Allows an application to read the user dictionary.
AddPermission(android.permission.REBOOT)
' Required to be able to reboot the device.
AddPermission(android.permission.RECEIVE_BOOT_COMPLETED)
' Allows an application to receive the ACTION_BOOT_COMPLETED that is broadcast after the system finishes booting.
AddPermission(android.permission.RECEIVE_MMS)
' Allows an application to monitor incoming MMS messages, to record or perform processing on them.
AddPermission(android.permission.RECEIVE_SMS)
' Allows an application to monitor incoming SMS messages, to record or perform processing on them.
AddPermission(android.permission.RECEIVE_WAP_PUSH)
' Allows an application to monitor incoming WAP push messages.
AddPermission(android.permission.RECORD_AUDIO)
' Allows an application to record audio.
AddPermission(android.permission.REORDER_TASKS)
' Allows an application to change the Z-order of tasks.
AddPermission(android.permission.RESTART_PACKAGES)
' This constant was deprecated in API level 8. The restartPackage(String) API is no longer supported.
AddPermission(android.permission.SEND_RESPOND_VIA_MESSAGE)
' Allows an application (Phone) to send a request to other applications to handle the respond-via-message action during incoming calls.
AddPermission(android.permission.SEND_SMS)
' Allows an application to send SMS messages.
AddPermission(android.permission.SET_ACTIVITY_WATCHER)
' Allows an application to watch and control how activities are started globally in the system.
AddPermission(android.permission.SET_ALARM)
' Allows an application to broadcast an Intent to set an alarm for the user.
AddPermission(android.permission.SET_ALWAYS_FINISH)
' Allows an application to control whether activities are immediately finished when put in the background.
AddPermission(android.permission.SET_ANIMATION_SCALE)
' Modify the global animation scaling factor.
AddPermission(android.permission.SET_DEBUG_APP)
' Configure an application for debugging.
AddPermission(android.permission.SET_ORIENTATION)
' Allows low-level access to setting the orientation (actually rotation) of the screen.
AddPermission(android.permission.SET_POINTER_SPEED)
' Allows low-level access to setting the pointer speed.
AddPermission(android.permission.SET_PREFERRED_APPLICATIONS)
' This constant was deprecated in API level 7. No longer useful, see addPackageToPreferred(String) for details.
AddPermission(android.permission.SET_PROCESS_LIMIT)
' Allows an application to set the maximum number of (not needed) application processes that can be running.
AddPermission(android.permission.SET_TIME)
' Allows applications to set the system time.
AddPermission(android.permission.SET_TIME_ZONE)
' Allows applications to set the system time zone.
AddPermission(android.permission.SET_WALLPAPER)
' Allows applications to set the wallpaper.
AddPermission(android.permission.SET_WALLPAPER_HINTS)
' Allows applications to set the wallpaper hints.
AddPermission(android.permission.SIGNAL_PERSISTENT_PROCESSES)
' Allow an application to request that a signal be sent to all persistent processes.
AddPermission(android.permission.STATUS_BAR)
' Allows an application to open, close, or disable the status bar and its icons.
AddPermission(android.permission.SUBSCRIBED_FEEDS_READ)
' Allows an application to allow read access the subscribed feeds ContentProvider.
AddPermission(android.permission.SUBSCRIBED_FEEDS_WRITE)
' Allows an application to allow write access the subscribed feeds ContentProvider.
AddPermission(android.permission.SYSTEM_ALERT_WINDOW)
' Allows an application to open windows using the type TYPE_SYSTEM_ALERT, shown on top of all other applications.
AddPermission(android.permission.TRANSMIT_IR ALLOWS)
' Allows using the device's IR transmitter, if available.
AddPermission(android.permission.UNINSTALL_SHORTCUT)
' Allows an application to uninstall a shortcut in Launcher.
AddPermission(android.permission.UPDATE_DEVICE_STATS)
' Allows an application to update device statistics.
AddPermission(android.permission.USE_CREDENTIALS)
' Allows an application to request authtokens from the AccountManager.
AddPermission(android.permission.USE_SIP)
' Allows an application to use SIP service.
AddPermission(android.permission.VIBRATE)
' Allows access to the vibrator.
AddPermission(android.permission.WAKE_LOCK)
' Allows using PowerManager WakeLocks to keep processor from sleeping or screen from dimming.
AddPermission(android.permission.WRITE_APN_SETTINGS)
' Allows applications to write the apn settings.
AddPermission(android.permission.WRITE_CALENDAR)
' Allows an application to write (but not read) the user's calendar data.
AddPermission(android.permission.WRITE_CALL_LOG)
' Allows an application to write (but not read) the user's contacts data.
AddPermission(android.permission.WRITE_CONTACTS)
AddPermission(android.permission.WRITE_EXTERNAL_STORAGE)
' Allows an application to write to external storage.
AddPermission(android.permission.WRITE_GSERVICES)
' Allows an application to modify the Google service map.
AddPermission(android.permission.WRITE_HISTORY_BOOKMARKS)
' Allows an application to write (but not read) the user's browsing history and bookmarks.
AddPermission(android.permission.WRITE_PROFILE)
' Allows an application to write (but not read) the user's personal profile data.
AddPermission(android.permission.WRITE_SECURE_SETTINGS)
' Allows an application to read or write the secure system settings.
AddPermission(android.permission.WRITE_SETTINGS)
' Allows an application to read or write the system settings.
AddPermission(android.permission.WRITE_SMS)
' Allows an application to write SMS messages.
AddPermission(android.permission.WRITE_SOCIAL_STREAM)
' Allows an application to write (but not read) the user's social stream data.
AddPermission(android.permission.WRITE_SYNC_SETTINGS)
' Allows applications to write the sync settings.
AddPermission(android.permission.WRITE_USER_DICTIONARY)
' Allows an application to write to the user dictionary.
