با سلام . قبلا نمیتونستم از بانک لود کنم . الان برای نمایش مشکل دارم . آخرین داده از دیتا بیس رو نشون میده در صورتی که میخوام مثل آرایه به ترتیب نشون بده کجای این کد باید اصلاح بشه ؟
Dim cur1 As Cursor
Dim bit1 As Bitmap
Dim sql1 As SQL
sql1.Initialize(File.DirInternal,"ganjdb.db",False)
cur1 = sql1.ExecQuery("SELECT * from tbl_list order by num1 desc")
For i = 0 To cur1.RowCount-1
cur1.Position = i
Dim Buffer() As Byte
Buffer = cur1.GetBlob("pic1")
Dim InputStream1 As InputStream
InputStream1.InitializeFromBytesArray(Buffer,0, Buffer.Length)
bit1.Initialize2(InputStream1)
InputStream1.Close
gpimage.SetBackgroundImage(bit1)
Dim cur2 As Cursor
cur2 = sql1.ExecQuery("select answer1 from tbl_list")
For i = 0 To cur2.RowCount-1
cur2.Position = i
sword = cur2.GetString("answer1")
mamad20 18
Dim cur1 As Cursor Dim bit1 As Bitmap Dim sql1 As SQL sql1.Initialize(File.DirInternal,"ganjdb.db",False) cur1 = sql1.ExecQuery("SELECT * from tbl_list order by num1 desc") For i = 0 To cur1.RowCount-1 cur1.Position = i Dim Buffer() As Byte Buffer = cur1.GetBlob("pic1") Dim InputStream1 As InputStream InputStream1.InitializeFromBytesArray(Buffer,0, Buffer.Length) bit1.Initialize2(InputStream1) InputStream1.Close gpimage.SetBackgroundImage(bit1) Next Dim cur2 As Cursor cur2 = sql1.ExecQuery("select answer1 from tbl_list") For i = 0 To cur2.RowCount-1 cur2.Position = i sword = cur2.GetString("answer1") Nextلینک ارسال
