کمک در مورد خارج کردن تب ها از حلقه فور
Negan
سلام دوستان من ی سورس دارم ک تب ها به این شکل هستش و میخوام از حلقه خارج بشه و با کلیک رو هر کدوم یه لایوت رو لود کنه!
'This example shows how to use a custom xml layout for the tabs. Here we use icon and text which are aligned
'vertically as described in the material design guidelines. If you just add icon and text both will be aligned
'horizontally which is not styleguide conform. Maybe Google will change this behavior in the future.
'This example uses AHViewPager library, AppCompat library, DesignSupport library, XmlLayoutBuilder library,
'XmlViewEx class/library. Search for them on the forum.
#Region  Project Attributes
	#ApplicationLabel: Custom View for tabs
	#VersionCode: 1
	#VersionName: 1.0
#End Region
#AdditionalRes: ..\resource
#AdditionalRes: E:\tool\Basic4android\b4a_appcompat, de.amberhome.objects.appcompat
#AdditionalRes: E:\tool\sdk\support\v7\recyclerview\res, android.support.v7.recyclerview
#AdditionalRes: E:\tool\sdk\support\v7\appcompat\res, android.support.v7.appcompat
#AdditionalRes: E:\tool\sdk\support\design\res, android.support.design
#Extends: android.support.v7.app.AppCompatActivity
#CustomBuildAction: 1, c:\windows\system32\attrib.exe, +r res\*.* /s
#Region  Activity Attributes
	#FullScreen: False
	#IncludeTitle: True
#End Region
Sub Size
    Dim xx,yy As Double
        xx = ((100%x)/320) / Density
        yy = ((100%y)/480) / Density
        For Each View As View In Activity.GetAllViewsRecursive
            View.Width=(View.Width) * xx
            View.Left=(View.left) * xx
            View.Height=(View.Height) * yy
            View.top=(View.top) * yy
	Private VP As AHViewPager
	Private PC As AHPageContainer
	Private TabLayout As DSTabLayout
	Private ToolBar As ACToolBarLight
	Dim titles(3) As String = Array As String ("تب 3", "تب 2", "تب1 ")
 	Dim icons(3) As String = Array As String ("lock_outline_white_24dp", "lock_open_white_24dp", "info_outline_white_24dp")
	Activity.LoadLayout("layout1")
	'Initialize the Toolbar and set a title
	ToolBar.SetAsActionBar
	ToolBar.Title = "تایتل"
	Dim xml As XmlLayoutBuilder
	'Initialize a PageContainer Object with 3 pages. Each page contains a panel with different random color
	PC.Initialize
	For i = 0 To 2
		Dim p As Panel
		p.Initialize("")
'		p.Color = Colors.RGB(Rnd(0,256), Rnd(0,256), Rnd(0,256))
		'Don't add a title here
		PC.AddPage(p, "")
	'Set the PageContainer for the ViewPager
VP.PageContainer = PC
	'Set the Elevation for the Toolbar
	Dim ac As AppCompat
	ac.SetElevation(ToolBar, 4dip)
	ac.SetElevation(TabLayout, 4dip)
	'Set the tabmode to fixed and the gravity to fill
	TabLayout.TabGravity = TabLayout.GRAVITY_FILL
	TabLayout.TabMode = TabLayout.MODE_FIXED
	'Set colors. The indicator color defaults to "colorAccent"
	TabLayout.Color = ac.GetThemeAttribute("colorPrimary")
	TabLayout.TabIndicatorColor = Colors.White
	'Connect the TabLayout with the Viewpager.
	'This will create the tabs and will keep tabs and pages
	'in sync and creates a nice indicator animation.
	TabLayout.SetViewPager(VP)
	'Do the magic stuff for the custom tabs.
	' - First we load an XML Layout file from the resources folder.
	' - Then set the text and the icon drawable in this xml layout.
	For i = 0 To 2
		Dim v As View
		v = XmlViewEx.InflateXmlLayout("tab_icon")
		TabLayout.SetTabCustomView(i, v)
		XmlViewEx.SetXmlViewText(XmlViewEx.FindView(v, "tabText"), titles(i).ToUpperCase)
	XmlViewEx.SetXmlViewImage(XmlViewEx.FindView(v, "tabIcon"), xml.GetDrawable(icons(i)))
	'XmlViewEx.SetXmlViewTextColor(XmlViewEx.FindView(v, "tabText"), Colors.Green)
Sub Activity_Resume
سلام منظورت رو متوجه نشدم؟ :wacko1:
خخخخخ
مشکلی نیست عزیزم میخوام واس هر تب یه لایوت رو فراخوانی کنه ک نتونسم :(
خب داداش این کد رو ببین من از این سورس استفاده کردم اما خب هرکاری کردم بلد نبودم اینکارو بکنم
این قسمت از کد رو ببینید :
	For i = 0 To 2
		Dim v As View
شما کافیه حلقه for  رو پاک کنید و در کد TabLayout.SetTabCustomView به جای i  شماره تب رو دستی وارد کنید که شما 3تا تب ساختید و از 0 شروع میشه تا 2 ( شماره تب ها )
	For i = 0 To 2
		Dim v As View
همه i هارو ریپلیس کنم ؟
عاقا یه دنیا ممنون دمتون گرررررررررررررررررررررررررررررررررررررررررررم
ببخشید میشه سورس رو بهتون بردم اگ زحمتی نیس برام انکارو بکنین ؟  :DD:  :oops:
اخه تعداد حلقه های داخل سورس زیاده نمیدونم اون یکیارو چیکار کنم
می تونم بپرسم دلیل اینکه نمیخوایید از حلقه استفاده کنید چیه ؟
خب عزیز جان بلد نیستم توی پنل زیرش با توجه به کلیک سدن روی تب لایوت مخصوص به خودشو لود کنم
اینم سورس
http://s7.picofile.com/file/8246773784/FixedTabsIconText.zip.html
اول یه Panel توی Main Layout تعریف کن
بعد برای لود هر لایوت این کد رو اجرا کن تو حلقه یا هر جای دیگه
Sub LoadLayout_InTab(Name As String)
Panel.LoadLayout(Name)
این کار رو انجام بده ببین کارت راه میفته :DD:
والا هنو نه خخخخخخخخخخخ
منظورم اینه به جای customview از پنل استفاده کن بعد Layout ها رو توی اون لود کن
داداش اگ زحمتت نمیشه میشه سورس رو برام ویرایش کنی ؟ بخشید البته توی پیاما بالا سورس رو قرار دادم
