سلام دوستان کسی می تونه به برنامه لیمیت بده سورس پایین می زارم
#Region Project Attributes
#ApplicationLabel: پیامک کده
#VersionCode: 1
#VersionName:
#AdditionalRes:C:\Users\hassanmohammadi\Desktop\New folder\Google play service-low size\google-play-services-base-7.5.0\res, com.google.android.gms
#AdditionalRes:C:\Users\hassanmohammadi\Desktop\New folder\Google play service-low size\google-play-services-gcm-7.5.0\res, com.google.android.gms
#AdditionalRes:C:\Users\hassanmohammadi\Desktop\New folder\res, co.ronash.pushe
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: False
#End Region
Dim sql1 As SQL
Dim timer1 As Timer
Dim sm As SlidingMenu
Private listFeh As ListView
Private lblhead As Label
Private imgpc As ImageView
Private Btnlike As ImageView
Private btncopy As Button
Private btnShare As Button
Private lblpayamaktest As Label
Private pnlpayamak As Panel
Dim lv As CustomListView
Dim su As StringUtils
Dim cb As BClipboard
Private lblsample As Label
Dim pagenume As Int=1
Dim p As Pushe
Activity.LoadLayout("lsplash")
If File.Exists(File.DirInternal,"pm.db")=False Then
File.Copy(File.DirAssets,"pm.db",File.DirInternal,"pm.db")
sql1.Initialize(File.DirInternal,"pm.db",True)
timer1.Initialize("timer1",2000)
timer1.Enabled=True
p.initialize(True)
Sub timer1_Tick
Activity.RemoveAllViews
Activity.LoadLayout("lmain")
timer1.Enabled=False
Sub Activity_Resume
Sub img1_Click
Activity.LoadLayout("bankpayamak")
pagenume=2
Dim imgback As BitmapDrawable
imgback.Initialize(LoadBitmap(File.DirAssets,"item.png"))
listFeh.SingleLineLayout.Background=imgback
listFeh.SingleLineLayout.ItemHeight=10%y
listFeh.SingleLineLayout.Label.Gravity=Gravity.CENTER
listFeh.SingleLineLayout.Label.TextSize=15
listFeh.SingleLineLayout.Label.TextColor=Colors.White
listFeh.SingleLineLayout.Label.Typeface=Typeface.LoadFromAssets("BYekan.ttf")
Dim cur As Cursor
cur=sql1.ExecQuery("SELECT * FROM Tblfehrest ")
Dim i As Int
For i=0 To cur.RowCount-1
cur.Position=i
listFeh.AddSingleLine2(cur.GetString("Name"),cur.GetString("ID"))
Sub listFeh_ItemClick (Position As Int, Value As Object)
Activity.LoadLayout("payamak")
pagenume=3
Dim cur As Cursor
cur=sql1.ExecQuery2("SELECT *FROM Tblfehrest Where ID=?",Array As String(Value))
cur.Position=0
lblhead.Text=cur.GetString("Name")
imgpc.SetBackgroundImage(LoadBitmapSample(File.DirAssets,cur.GetString("Ax"),imgpc.Width,imgpc.Height))
lv.Initialize(Me,"lv")
Activity.AddView(lv.AsView,1%X,16%Y,98%X,80%Y)
Dim cur As Cursor
cur=sql1.ExecQuery2("SELECT * FROM Tblpayamak WHERE FehID=?",Array As String(Value))
Dim i As Int
For i=6 To cur.RowCount-1
cur.Position=i
Dim pl As Panel
pl.Initialize("pl")
lblsample.Text=cur.GetString("Matn")
lv.Add(pl,su.MeasureMultilineTextHeight(lblsample,lblsample.Text)+70dip,"")
pl.LoadLayout("temp")
pnlpayamak.Height=su.MeasureMultilineTextHeight(lblsample,lblsample.Text)+btncopy.Height+30dip
lblpayamaktest.Text=cur.GetString("Matn")
lblpayamaktest.Height=su.MeasureMultilineTextHeight(lblpayamaktest,lblpayamaktest.Text)
lblpayamaktest.Top=pnlpayamak.Top+10dip
btncopy.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip
btnShare.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip
Btnlike.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip
btnShare.Tag=cur.GetString("Matn")
btncopy.Tag=cur.GetString("Matn")
Btnlike.Tag=cur.GetString("ID")
If checkalaqe(cur.GetString("ID"))=False Then
Btnlike.SetBackgroundImage(LoadBitmap(File.DirAssets,"like.png"))
Btnlike.SetBackgroundImage(LoadBitmap(File.DirAssets,"like - copy.png"))
Sub BtnShare_Click
Dim obj As View
obj=Sender
Dim share As Intent
share.Initialize(share.ACTION_SEND,"")
share.SetType("text/plain")
share.PutExtra("android.intent.extra.TEXT",obj.Tag)
share.WrapAsIntentChooser("متن از چه طریقی ارسال شود؟")
StartActivity(share)
Sub btncopy_Click
Dim obj As View
obj=Sender
cb.setText(obj.Tag)
ToastMessageShow("متن پیامک در حافظه موقت کپی شد",False)
Sub Btnlike_Click
Dim obj As View
obj=Sender
If checkalaqe(obj.Tag)=False Then
sql1.ExecNonQuery2("UPDATE Tblpayamak SET alaqe=1 WHERE ID=?",Array As String (obj.Tag))
obj.SetBackgroundImage(LoadBitmap(File.DirAssets,"like - copy.png"))
ToastMessageShow("پیامک مورد نظر شما به علاقه مندی ها اضافه شد",False)
sql1.ExecNonQuery2("UPDATE Tblpayamak SET alaqe=0 WHERE ID=?",Array As String (obj.Tag))
obj.SetBackgroundImage(LoadBitmap(File.DirAssets,"like.png"))
ToastMessageShow("پیامک مورد نظر شما از لیست علاقمندی حذف شد",False)
Sub checkalaqe (PayamakID As Int)As Boolean
Dim cur As Cursor
cur=sql1.ExecQuery2("SELECT * FROM Tblpayamak WHERE ID=?",Array As String(PayamakID))
cur.Position=0
If cur.GetString("alaqe")=1 Then
Return True
Return False
Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
If KeyCode=KeyCodes.KEYCODE_BACK Then
Select pagenume
Case 1
If Msgbox2("آیا از خروج اطمینان دارید؟","خروج","بله","خیر","",Null)=DialogResponse.POSITIVE Then
ExitApplication
Return True
Case 2
pagenume=1
Return True
Case 3
img1_Click
Return True
End Select
Sub img2_Click
pagenume=2
lblhead.Text="لیست علاقه مندی ها"
imgpc.SetBackgroundImage(LoadBitmapSample(File.DirAssets,"cool.png",imgpc.Width,imgpc.Height))
Dim cur As Cursor
cur=sql1.ExecQuery("SELECT *FROM Tblpayamak WHERE alaqe=1")
Dim i As Int
cur.Position=i
Dim pl As Panel
pl.Initialize("pl")
Sub img3_Click
Dim cafebazar As Intent
cafebazar.Initialize(cafebazar.Action_edit,"bazaar://details?id=com.mobilestudio.payamakbank")
StartActivity(cafebazar)
Sub img4_Click
Msgbox2("ایمیل پشتیبانی:mobilestudio415@gmail.com"& CRLF&"کانال تلگرام:telegram.me/mobilestudio415","ارتباط با ما","باشه","","",Null)
Sub img5_Click
Msgbox2("کاری از گروه برنامه نویسی موبایل استودیو"& CRLF&"برنامه نویس:حسن محمدی","درباره ما","باشه","","",Null)
Sub btnUpdate_Click
Dim ht As HttpJob
ht.Initialize("update",Me)
ProgressDialogShow("updating")
ht.Download("")
Sub JobDone(Job As HttpJob)
ProgressDialogHide
If Job.Success Then
If Job.JobName = "update" Then
Dim ou As OutputStream
File.Delete(File.DirInternal,"pm.db")
ou = File.OpenOutput(File.DirInternal,"pm.db",False)
File.Copy2(Job.GetInputStream,ou)
ou.Close
ToastMessageShow("بانک پیامک اپدیت شد لطلفا برنامه را ببندید ودوباره اجرا کنید",False)
hassan543 2
#Region Project Attributes #ApplicationLabel: پیامک کده #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #AdditionalRes:C:\Users\hassanmohammadi\Desktop\New folder\Google play service-low size\google-play-services-base-7.5.0\res, com.google.android.gms #AdditionalRes:C:\Users\hassanmohammadi\Desktop\New folder\Google play service-low size\google-play-services-gcm-7.5.0\res, com.google.android.gms #AdditionalRes:C:\Users\hassanmohammadi\Desktop\New folder\res, co.ronash.pushe #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: False #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. Dim sql1 As SQL End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Dim timer1 As Timer Dim sm As SlidingMenu Private listFeh As ListView Private lblhead As Label Private imgpc As ImageView Private Btnlike As ImageView Private btncopy As Button Private btnShare As Button Private lblpayamaktest As Label Private pnlpayamak As Panel Dim lv As CustomListView Dim su As StringUtils Dim cb As BClipboard Private lblsample As Label Dim pagenume As Int=1 Dim p As Pushe End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("lsplash") If File.Exists(File.DirInternal,"pm.db")=False Then File.Copy(File.DirAssets,"pm.db",File.DirInternal,"pm.db") End If sql1.Initialize(File.DirInternal,"pm.db",True) timer1.Initialize("timer1",2000) timer1.Enabled=True p.initialize(True) End Sub Sub timer1_Tick Activity.RemoveAllViews Activity.LoadLayout("lmain") timer1.Enabled=False End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub img1_Click Activity.RemoveAllViews Activity.LoadLayout("bankpayamak") pagenume=2 Dim imgback As BitmapDrawable imgback.Initialize(LoadBitmap(File.DirAssets,"item.png")) listFeh.SingleLineLayout.Background=imgback listFeh.SingleLineLayout.ItemHeight=10%y listFeh.SingleLineLayout.Label.Gravity=Gravity.CENTER listFeh.SingleLineLayout.Label.TextSize=15 listFeh.SingleLineLayout.Label.TextColor=Colors.White listFeh.SingleLineLayout.Label.Typeface=Typeface.LoadFromAssets("BYekan.ttf") Dim cur As Cursor cur=sql1.ExecQuery("SELECT * FROM Tblfehrest ") Dim i As Int For i=0 To cur.RowCount-1 cur.Position=i listFeh.AddSingleLine2(cur.GetString("Name"),cur.GetString("ID")) Next End Sub Sub listFeh_ItemClick (Position As Int, Value As Object) Activity.RemoveAllViews Activity.LoadLayout("payamak") pagenume=3 Dim cur As Cursor cur=sql1.ExecQuery2("SELECT *FROM Tblfehrest Where ID=?",Array As String(Value)) cur.Position=0 lblhead.Text=cur.GetString("Name") imgpc.SetBackgroundImage(LoadBitmapSample(File.DirAssets,cur.GetString("Ax"),imgpc.Width,imgpc.Height)) lv.Initialize(Me,"lv") Activity.AddView(lv.AsView,1%X,16%Y,98%X,80%Y) Dim cur As Cursor cur=sql1.ExecQuery2("SELECT * FROM Tblpayamak WHERE FehID=?",Array As String(Value)) Dim i As Int For i=6 To cur.RowCount-1 cur.Position=i Dim pl As Panel pl.Initialize("pl") lblsample.Text=cur.GetString("Matn") lv.Add(pl,su.MeasureMultilineTextHeight(lblsample,lblsample.Text)+70dip,"") pl.LoadLayout("temp") pnlpayamak.Height=su.MeasureMultilineTextHeight(lblsample,lblsample.Text)+btncopy.Height+30dip lblpayamaktest.Text=cur.GetString("Matn") lblpayamaktest.Height=su.MeasureMultilineTextHeight(lblpayamaktest,lblpayamaktest.Text) lblpayamaktest.Top=pnlpayamak.Top+10dip btncopy.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip btnShare.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip Btnlike.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip btnShare.Tag=cur.GetString("Matn") btncopy.Tag=cur.GetString("Matn") Btnlike.Tag=cur.GetString("ID") If checkalaqe(cur.GetString("ID"))=False Then Btnlike.SetBackgroundImage(LoadBitmap(File.DirAssets,"like.png")) Else Btnlike.SetBackgroundImage(LoadBitmap(File.DirAssets,"like - copy.png")) End If Next End Sub Sub BtnShare_Click Dim obj As View obj=Sender Dim share As Intent share.Initialize(share.ACTION_SEND,"") share.SetType("text/plain") share.PutExtra("android.intent.extra.TEXT",obj.Tag) share.WrapAsIntentChooser("متن از چه طریقی ارسال شود؟") StartActivity(share) End Sub Sub btncopy_Click Dim obj As View obj=Sender cb.setText(obj.Tag) ToastMessageShow("متن پیامک در حافظه موقت کپی شد",False) End Sub Sub Btnlike_Click Dim obj As View obj=Sender If checkalaqe(obj.Tag)=False Then sql1.ExecNonQuery2("UPDATE Tblpayamak SET alaqe=1 WHERE ID=?",Array As String (obj.Tag)) obj.SetBackgroundImage(LoadBitmap(File.DirAssets,"like - copy.png")) ToastMessageShow("پیامک مورد نظر شما به علاقه مندی ها اضافه شد",False) Else sql1.ExecNonQuery2("UPDATE Tblpayamak SET alaqe=0 WHERE ID=?",Array As String (obj.Tag)) obj.SetBackgroundImage(LoadBitmap(File.DirAssets,"like.png")) ToastMessageShow("پیامک مورد نظر شما از لیست علاقمندی حذف شد",False) End If End Sub Sub checkalaqe (PayamakID As Int)As Boolean Dim cur As Cursor cur=sql1.ExecQuery2("SELECT * FROM Tblpayamak WHERE ID=?",Array As String(PayamakID)) cur.Position=0 If cur.GetString("alaqe")=1 Then Return True Else Return False End If End Sub Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event If KeyCode=KeyCodes.KEYCODE_BACK Then Select pagenume Case 1 If Msgbox2("آیا از خروج اطمینان دارید؟","خروج","بله","خیر","",Null)=DialogResponse.POSITIVE Then ExitApplication Else Return True End If Case 2 Activity.RemoveAllViews Activity.LoadLayout("lmain") pagenume=1 Return True Case 3 img1_Click Return True End Select End If End Sub Sub img2_Click Activity.RemoveAllViews Activity.LoadLayout("payamak") pagenume=2 lblhead.Text="لیست علاقه مندی ها" imgpc.SetBackgroundImage(LoadBitmapSample(File.DirAssets,"cool.png",imgpc.Width,imgpc.Height)) lv.Initialize(Me,"lv") Activity.AddView(lv.AsView,1%X,16%Y,98%X,80%Y) Dim cur As Cursor cur=sql1.ExecQuery("SELECT *FROM Tblpayamak WHERE alaqe=1") Dim i As Int For i=0 To cur.RowCount-1 cur.Position=i Dim pl As Panel pl.Initialize("pl") lblsample.Text=cur.GetString("Matn") lv.Add(pl,su.MeasureMultilineTextHeight(lblsample,lblsample.Text)+70dip,"") pl.LoadLayout("temp") pnlpayamak.Height=su.MeasureMultilineTextHeight(lblsample,lblsample.Text)+btncopy.Height+30dip lblpayamaktest.Text=cur.GetString("Matn") lblpayamaktest.Height=su.MeasureMultilineTextHeight(lblpayamaktest,lblpayamaktest.Text) lblpayamaktest.Top=pnlpayamak.Top+10dip btncopy.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip btnShare.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip Btnlike.Top=lblpayamaktest.Top+lblpayamaktest.Height+15dip btnShare.Tag=cur.GetString("Matn") btncopy.Tag=cur.GetString("Matn") Btnlike.Tag=cur.GetString("ID") If checkalaqe(cur.GetString("ID"))=False Then Btnlike.SetBackgroundImage(LoadBitmap(File.DirAssets,"like.png")) Else Btnlike.SetBackgroundImage(LoadBitmap(File.DirAssets,"like - copy.png")) End If Next End Sub Sub img3_Click Dim cafebazar As Intent cafebazar.Initialize(cafebazar.Action_edit,"bazaar://details?id=com.mobilestudio.payamakbank") StartActivity(cafebazar) End Sub Sub img4_Click Msgbox2("ایمیل پشتیبانی:mobilestudio415@gmail.com"& CRLF&"کانال تلگرام:telegram.me/mobilestudio415","ارتباط با ما","باشه","","",Null) End Sub Sub img5_Click Msgbox2("کاری از گروه برنامه نویسی موبایل استودیو"& CRLF&"برنامه نویس:حسن محمدی","درباره ما","باشه","","",Null) End Sub Sub btnUpdate_Click Dim ht As HttpJob ht.Initialize("update",Me) ProgressDialogShow("updating") ht.Download("") End Sub Sub JobDone(Job As HttpJob) ProgressDialogHide If Job.Success Then If Job.JobName = "update" Then Dim ou As OutputStream File.Delete(File.DirInternal,"pm.db") ou = File.OpenOutput(File.DirInternal,"pm.db",False) File.Copy2(Job.GetInputStream,ou) ou.Close ToastMessageShow("بانک پیامک اپدیت شد لطلفا برنامه را ببندید ودوباره اجرا کنید",False) End If End If End Subلینک ارسال
