وقتی پیام ارسال می کنم نمی تونم از deliver شدن با خبر بشم. (در ضمن شماره رو توی edittext گذاشتم و پیام بدون مشکل ارسال میشه)
کسی میدونه مشکل چیه؟
کد اکتیویتی من اینه :
#Region Project Attributes
#VersionCode: 1
#VersionName:
#CanInstallToExternalStorage: FALSE
#End Region
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Dim ps As PhoneSms
Dim pe As PhoneEvents
Dim si, sr As SmsInterceptor
Private Button1 As Button
Private EditText1 As EditText
Activity.LoadLayout("main")
pe.Initialize("PE")
'si outgoing messages
si.Initialize2("si",998)
si.ListenToOutgoingMessages
'incoming messages
sr.Initialize2("sr",999)
Sub sr_MessageReceived (From As String, Body As String) As Boolean
Log(From)
If From.Contains("198") Then
Msgbox ("merc","")
'Code of delete the message
Sub si_MessageSent (MessageId As Int)
Dim sm As SmsMessages
Dim res As List = sm.GetByMessageId(MessageId)
If res.Size > 0 Then
Dim msg As Sms
msg = res.Get(0)
Log(msg)
Msgbox(msg,"")
Sub Activity_Resume
Sub Button1_Click
ps.Send2(EditText1.Text,"سلام تست",True,True)
Sub SmsDelivered (PhoneNumber As String, Intent As Intent)
Msgbox("پذیرش انجام شد",PhoneNumber)
Sub SmsSentStatus (Success As Boolean, ErrorMessage As String, PhoneNumber As String, Intent As Intent)
If Success=True Then
Msgbox("ارسال موفق بود",PhoneNumber)
نکته: مانیفست من هم اینه:
'See this link for for more information: http://www.b4x.com/forum/showthread.php?p=78136
AddManifestText(
<uses-sdk android:minSdkVersion="5" android:targetSdkVersion="14"/>
android:normalScreens="true"
android:smallScreens="true"
android:anyDensity="true"/>)
SetApplicationAttribute(android:theme, "@android:style/Theme.Holo")
AddPermission(android.permission.SEND_SMS)
AddPermission(android.permission.WRITE_SMS)
AddPermission(android.permission.BROADCAST_SMS)
AddPermission(android.permission.group.MESSAGES)
AddPermission(android.permission.READ_SMS)
AddPermission(android.permission.RECEIVE_SMS)
'End of default text.
sajjad3011 29
من از کتابخانه Phone استفاده کردم.
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: FALSE #End Region #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. Dim ps As PhoneSms Dim pe As PhoneEvents Dim si, sr As SmsInterceptor End Sub Sub Globals Private Button1 As Button Private EditText1 As EditText End Sub Sub Activity_Create(FirstTime As Boolean) Activity.LoadLayout("main") pe.Initialize("PE") 'si outgoing messages si.Initialize2("si",998) si.ListenToOutgoingMessages 'incoming messages sr.Initialize2("sr",999) End Sub Sub sr_MessageReceived (From As String, Body As String) As Boolean Log(From) If From.Contains("198") Then Msgbox ("merc","") 'Code of delete the message End If End Sub Sub si_MessageSent (MessageId As Int) Dim sm As SmsMessages Dim res As List = sm.GetByMessageId(MessageId) If res.Size > 0 Then Dim msg As Sms msg = res.Get(0) Log(msg) Msgbox(msg,"") End If End Sub Sub Activity_Pause (UserClosed As Boolean) End Sub Sub Activity_Resume End Sub Sub Button1_Click ps.Send2(EditText1.Text,"سلام تست",True,True) End Sub Sub SmsDelivered (PhoneNumber As String, Intent As Intent) Msgbox("پذیرش انجام شد",PhoneNumber) End Sub Sub SmsSentStatus (Success As Boolean, ErrorMessage As String, PhoneNumber As String, Intent As Intent) If Success=True Then Msgbox("ارسال موفق بود",PhoneNumber) End If End Subنکته: مانیفست من هم اینه:
