خطای no such در هنگام اجرای برنامه
amirjun32
وقتی میخوام برناممو اجرا کنم همچین خطایی میده.بااینکه من توی دیتابیسم این ستون رو دارم،ولی بازم این خطا هی تکرار میشه.
ممنون میشم اگه کسی بتونه کمک کنه
این اکت دیتابیسم:
'Class module
Sub Class_Globals
Dim sql1 As SQL
Type tGroup(Sgroup As String,Simage As String)
Type fGroup(Sgroup1 As String,Simage1 As String)
Type tSMS(Sid As Int,Scontent As String,Sread As Int, Sstar As Int)
'Initializes the object. You can add parameters to this method if needed.
Public Sub Initialize
If File.Exists(File.DirInternal,"SMS.db")= False Then
File.Copy(File.DirAssets,"SMS.db",File.DirInternal,"SMS.db")
sql1.Initialize(File.DirInternal,"SMS.db",False)
Sub listGroup As List
Dim cur As Cursor
Dim list1 As List
list1.Initialize
cur = sql1.ExecQuery("SELECT Sgroup,(SELECT Simage FROM tblImage WHERE Sgroup = tblSMS.Sgroup) as Simage from tblSMS GROUP BY Sgroup")
For i=0 To cur.RowCount-1
cur.Position = i
Dim t1 As tGroup
t1.Initialize
t1.Sgroup = cur.GetString("Sgroup")
t1.Simage = cur.GetString("Simage")
list1.Add(t1)
Return list1
Sub listGroup12 As List
Dim cur As Cursor
Dim list12 As List
list12.Initialize
cur = sql1.ExecQuery("SELECT Sgroup1 from tblSMS GROUP BY Sgroup1")
cur.Position = i
Dim t1 As fGroup
t1.Initialize
t1.Sgroup1 = cur.GetString("Sgroup1")
t1.Simage1 = cur.GetString("Simage1")
list12.Add(t1)
Return list12
Sub listsubGroup(groupName As String) As List
Dim cur As Cursor
Dim list1 As List
Dim list12 As List
Dim cur2 As Cursor
list1.Initialize
cur = sql1.ExecQuery("SELECT * from tblSMS where Sgroup = '"&groupName&"'")
cur2 = sql1.ExecQuery("SELECT * from tblSMS where Sgroup1 = '"&groupName&"'")
cur.Position = i
Dim t1 As tSMS
t1.Initialize
t1.Sid = cur.GetInt("Sid")
t1.Scontent = cur.GetString("Scontent")
t1.Sread = cur.GetInt("Sread")
t1.Sstar = cur.GetInt("Sstar")
list1.Add(t1)
Return list1
Sub changeRead(Sid As String , Sread As Int) As Boolean
If Sid="" Then
Return False
sql1.ExecNonQuery2("update tblSMS set Sread = ? where Sid = ?",Array As String(Sread,Sid))
Return True
Sub changeStar(Sid As String , SRate As Int) As Boolean
If Sid="" Then
Return False
sql1.ExecNonQuery2("update tblSMS set Sstar = ? where Sid = ?",Array As String(SRate,Sid))
Return True
Sub getSMS(Sid As String) As tSMS
Dim cur As Cursor
cur = sql1.ExecQuery2("select * from tblSMS where Sid = ?",Array As String (Sid))
cur.Position = 0
Dim t1 As tSMS
t1.Initialize
Return t1
Sub searchItem(str As String) As List
Dim cur As Cursor
Dim list1 As List
list1.Initialize
cur = sql1.ExecQuery("select * from tblSMS where Scontent LIKE '%"&str&"%'")
For i =0 To cur.RowCount - 1
cur.Position = i
Dim t1 As tSMS
t1.Initialize
list1.Add(t1)
Return list1
Sub getSMSCount As String
Dim s1 As String
s1 = sql1.ExecQuerySingleResult("select COUNT(*) from tblSMS")
Return s1
اینم اکت گروهم:
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: False
#End Region
Dim db As myDB
Dim list12 As List
Dim scrol1 As CustomListView
Private pnlMain As Panel
Private imgGroup As ImageView
Private lblGroup As Label
Private btnSearch As Button
Private txtSearch As EditText
Private pnlSearch As Panel
Private lblMain As Label
Dim slide As SlidingMenu
Private Panel2 As Panel
Activity.LoadLayout("LMai")
myLibrary.createMenu(slide)
db.Initialize
list12.Initialize
list12 = db.listGroup12
scrol1.Initialize(Me,"scrol1Event")
pnlMain.AddView(scrol1.AsView,0,52dip, 100%x,100%y-Panel2.Height)
For i=0 To list12.Size - 1
Dim p1 As Panel
p1.Initialize("")
scrol1.Add(p1,140dip,"")
p1.LoadLayout("LPGroup1")
Dim t1 As fGroup
t1.Initialize
t1 = list12.Get(i)
lblGroup.Text = t1.Sgroup1
imgGroup.SetBackgroundImage(LoadBitmap(File.DirAssets,t1.Simage1))
lblGroup.Tag = t1.Sgroup1
imgGroup.Tag = t1.Sgroup1
Sub Activity_Resume
Sub subGroupShow_Click
Dim v1 As View
v1 = Sender
'Msgbox(v1.Tag,"")
actGroup.vGroupName = v1.Tag
StartActivity(actGroup)
Sub btnSearch_Click
lblMain.Visible = False
pnlSearch.Visible =True
Sub txtSearch_EnterPressed
If txtSearch.Text="" Then
ToastMessageShow("لطفا عبارت جستجو را وارد کنید",False)
Return
Dim l1 As List
l1.Initialize
l1 = db.searchItem(txtSearch.Text)
actGroup.search = l1
Sub Activity_KeyPress (KeyCode As Int) As Boolean 'Return True to consume the event
If KeyCode = KeyCodes.KEYCODE_MENU Then
If slide.Visible = False Then
slide.ShowMenu
slide.HideMenus
Return True
Sub panelMenu_ItemClick (Position As Int,Value As Object)
Select Value
Case "contact"
StartActivity(actContact)
Case "about"
Dim c1 As CustomDialog
Dim p1 As Panel
p1.Initialize("")
c1.AddView(p1,0,0,492,260)
p1.LoadLayout("Labout")
c1.Show("درباره ما","خب","","",Null)
Case "setting"
setting
Case "update"
updateApp
Case "idea"
myLibrary.OpenBazaarApp("com.mojtaba.daneshjooyar",True)
Case "product"
Dim ph As PhoneIntents
StartActivity(ph.OpenBrowser("http://cafebazar.ir/search/?1=&q=سپهر"))
Case "exit"
If Msgbox2("آیا می خواهید از برنامه خارج شوید؟","خروج","بله","خیر","",Null) = DialogResponse.POSITIVE Then
Activity.Finish
ExitApplication
End Select
Sub setting
Dim a1 As AHPreferenceScreen
a1.Initialize("تنظیمات","تنظیمات مربوط به نمایش")
a1.AddList("fontSize","اندازه قلم","حالت پیشفرض سایز قلم 18","18","",Array As String("20","21","22","28","36","40","52"))
a1.AddList("fontColor","رنگ قلم","رنگ پیشفرض قلم سیاه است","black","",Array As String("Red","Green","Blue","Yellow"))
a1.AddList("fontFamily","نوع قلم","","byekan.ttf","",Array As String("tahoma.ttf","bn.ttf"))
StartActivity(a1.CreateIntent)
Sub updateApp
If myLibrary.CheckInternet = False Then
ToastMessageShow("لطفا به اینترنت متصب شوید",False)
Return
Dim ht As HttpJob
ht.Initialize("update",Me)
ProgressDialogShow("در حال دانلود")
ht.Download("http://s5.picofile.com/file/8152747592/SMS.db.html")
Sub JobDone(Job As HttpJob)
ProgressDialogHide
If Job.Success = True Then
Dim out As OutputStream
Dim oldCount,newCount As String
Dim db1 As myDB
db1.Initialize
oldCount = db1.SMSCount
File.Delete(File.DirInternal,"SMS.db")
out = File.OpenOutput(File.DirInternal,"SMS.db",False)
File.Copy2(Job.GetInputStream,out)
out.Close
Dim db2 As myDB
db2.Initialize
newCount= db2.SMSCount
ToastMessageShow("برنامه با موفقیت بروزرسانی شد" &CRLF& "تعداد پیامک های جدید :" &(newCount - oldCount),False)
ToastMessageShow("خطا در برنامه",False)
دوست عزیز،منم این مشکل رو داشتم.
ببین،اگر برنامه ات را روی موبایل یا ایمولاتور تست می کنی،فرقی نمی کنه،اول برنامه ات را کامل از روشون حذف کن و دوباره اقدام به نصب کن،دلیل این خطا هم اینه که چون برنامه ات را قبلا نصب کرده بودی،داره از دیتابیس قبلی استفاده می کنه و دیتابیس جدیدی رو جایگزین نمی کند.
نمیتونه فیلد Sgroup1 رو پیدا کنه !
یا اسم رو داری اشتباه میدی یا دیتابیس مشکل داره !
