من وقتی تو حالت عادی برنامه رو کامپایل میکنم ارور نمی ده ولی رو حالت دیباگ ارور میده اینم ارور
B4A version: 5.80
Parsing code. (0.07s)
Compiling code. (0.17s)
Compiling layouts code. (0.01s)
Generating R file. (0.25s)
Compiling debugger engine code. (4.25s)
Compiling generated Java code. (7.30s)
Convert byte code - optimized dex. Error
UNEXPECTED TOP-LEVEL ERROR:
java.lang.OutOfMemoryError: GC overhead limit exceeded
at com.android.dx.cf.code.RopperMachine.run(RopperMachine.java:596)
at com.android.dx.cf.code.Simulator$SimVisitor.visitConstant(Simulator.java:691)
at com.android.dx.cf.code.BytecodeArray.parseInstruction(BytecodeArray.java:764)
at com.android.dx.cf.code.Simulator.simulate(Simulator.java:94)
at com.android.dx.cf.code.Ropper.processBlock(Ropper.java:782)
at com.android.dx.cf.code.Ropper.doit(Ropper.java:737)
at com.android.dx.cf.code.Ropper.convert(Ropper.java:346)
at com.android.dx.dex.cf.CfTranslator.processMethods(CfTranslator.java:282)
at com.android.dx.dex.cf.CfTranslator.translate0(CfTranslator.java:139)
at com.android.dx.dex.cf.CfTranslator.translate(CfTranslator.java:94)
at com.android.dx.command.dexer.Main.processClass(Main.java:613)
at com.android.dx.command.dexer.Main.processFileBytes(Main.java:570)
at com.android.dx.command.dexer.Main.access$2(Main.java:546)
at com.android.dx.command.dexer.Main$2.processFileBytes(Main.java:514)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:170)
at com.android.dx.cf.direct.ClassPathOpener.processDirectory(ClassPathOpener.java:229)
at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:158)
at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
at com.android.dx.command.dexer.Main.processOne(Main.java:537)
at com.android.dx.command.dexer.Main.processAllFiles(Main.java:449)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:236)
at com.android.dx.command.dexer.Main.run(Main.java:206)
at com.android.dx.command.dexer.Main.main(Main.java:179)
at com.android.dx.command.Main.main(Main.java:103)
ABOLFAZLLOTFI 15
با سلام و خسته نباسید
