سلام دوستان من یه سورس از سایت گرفتم که طرز کارش را نمی فهمم. اگر ممکن است آن را توضیح دهد.
سورس رو پیوست هم کردم
'Activity module
'This map maps between PhoneSensors and SensorData objects.
Dim SensorsMap As Map
Type SensorData (Name As String, ThreeValues As Boolean)
'This map maps between PhoneSensors and Labels.
Dim SensorsLabels As Map
' WWW.BASIC4ANDROID.ORG
' Producer : SH.KG
If FirstTime Then
SensorsMap.Initialize
Dim ps As PhoneSensors 'This object is only used to access the type constants.
AddSensor(ps.TYPE_ACCELEROMETER, "ACCELEROMETER", True)
AddSensor(ps.TYPE_GYROSCOPE, "GYROSCOPE", True)
AddSensor(ps.TYPE_LIGHT, "LIGHT", False)
AddSensor(ps.TYPE_MAGNETIC_FIELD, "MAGNETIC", True)
AddSensor(ps.TYPE_ORIENTATION, "ORIENTATION", True)
AddSensor(ps.TYPE_PRESSURE, "PRESSURE", False)
AddSensor(ps.TYPE_PROXIMITY, "PROXIMITY", False)
AddSensor(ps.TYPE_TEMPERATURE, "TEMPERATURE", False)
SensorsLabels.Initialize 'SensorsLabels is not a Process_Globals object so we need to create it each time
For i = 0 To SensorsMap.Size - 1
ps = SensorsMap.GetKeyAt(i)
Dim lbl As Label
lbl.Initialize("")
lbl.TextColor = Colors.White
Activity.AddView(lbl, 10dip, 10dip + 50dip * i, 100%x - 10dip, 45dip)
SensorsLabels.Put(ps, lbl)
Sub AddSensor(SensorType As Int, Name As String, ThreeValues As Boolean) As SensorData
Dim sd As SensorData
sd.Initialize
sd.Name = Name
sd.ThreeValues = ThreeValues
ps.Initialize(SensorType)
SensorsMap.Put(ps, sd)
Log(Name & " MaxValue = " & ps.MaxValue)
Sub Activity_Resume
'Here we start listening for SensorChanged events.
'By checking the return value we knoe if the sensor is supported.
Dim lbl As Label
sd = SensorsMap.GetValueAt(i)
lbl = SensorsLabels.Get(ps)
If ps.StartListening("Sensor") = False Then
lbl.Text = sd.Name & " is not supported."
Log(sd.Name & " is not supported.")
'Stop listening for events.
ps.StopListening
Sub Sensor_SensorChanged (Values() As Float)
Dim lbl As Label
'Get the PhoneSensors object that raised this event.
ps = Sender
sd = SensorsMap.Get(ps) 'Get the associated SensorData obejct
lbl = SensorsLabels.Get(ps) 'Get the associated Label.
If sd.ThreeValues Then
lbl.Text = sd.Name & " X=" & NumberFormat(Values(0), 0, 3) & ", Y=" & NumberFormat(Values(1), 0, 3) _
& ", Z=" & NumberFormat(Values(2), 0, 3)
lbl.Text = sd.Name & " = " & NumberFormat(Values(0), 0, 3)
arf 30
'Activity module Sub Process_Globals 'This map maps between PhoneSensors and SensorData objects. Dim SensorsMap As Map Type SensorData (Name As String, ThreeValues As Boolean) End Sub Sub Globals 'This map maps between PhoneSensors and Labels. Dim SensorsLabels As Map ' WWW.BASIC4ANDROID.ORG ' Producer : SH.KG End Sub Sub Activity_Create(FirstTime As Boolean) If FirstTime Then SensorsMap.Initialize Dim ps As PhoneSensors 'This object is only used to access the type constants. AddSensor(ps.TYPE_ACCELEROMETER, "ACCELEROMETER", True) AddSensor(ps.TYPE_GYROSCOPE, "GYROSCOPE", True) AddSensor(ps.TYPE_LIGHT, "LIGHT", False) AddSensor(ps.TYPE_MAGNETIC_FIELD, "MAGNETIC", True) AddSensor(ps.TYPE_ORIENTATION, "ORIENTATION", True) AddSensor(ps.TYPE_PRESSURE, "PRESSURE", False) AddSensor(ps.TYPE_PROXIMITY, "PROXIMITY", False) AddSensor(ps.TYPE_TEMPERATURE, "TEMPERATURE", False) End If SensorsLabels.Initialize 'SensorsLabels is not a Process_Globals object so we need to create it each time For i = 0 To SensorsMap.Size - 1 Dim ps As PhoneSensors ps = SensorsMap.GetKeyAt(i) Dim lbl As Label lbl.Initialize("") lbl.TextColor = Colors.White Activity.AddView(lbl, 10dip, 10dip + 50dip * i, 100%x - 10dip, 45dip) SensorsLabels.Put(ps, lbl) Next End Sub Sub AddSensor(SensorType As Int, Name As String, ThreeValues As Boolean) As SensorData Dim sd As SensorData sd.Initialize sd.Name = Name sd.ThreeValues = ThreeValues Dim ps As PhoneSensors ps.Initialize(SensorType) SensorsMap.Put(ps, sd) Log(Name & " MaxValue = " & ps.MaxValue) End Sub Sub Activity_Resume 'Here we start listening for SensorChanged events. 'By checking the return value we knoe if the sensor is supported. For i = 0 To SensorsMap.Size - 1 Dim ps As PhoneSensors Dim sd As SensorData Dim lbl As Label ps = SensorsMap.GetKeyAt(i) sd = SensorsMap.GetValueAt(i) lbl = SensorsLabels.Get(ps) If ps.StartListening("Sensor") = False Then lbl.Text = sd.Name & " is not supported." Log(sd.Name & " is not supported.") End If Next End Sub Sub Activity_Pause (UserClosed As Boolean) 'Stop listening for events. For i = 0 To SensorsMap.Size - 1 Dim ps As PhoneSensors ps = SensorsMap.GetKeyAt(i) ps.StopListening Next End Sub Sub Sensor_SensorChanged (Values() As Float) Dim ps As PhoneSensors Dim sd As SensorData Dim lbl As Label 'Get the PhoneSensors object that raised this event. ps = Sender sd = SensorsMap.Get(ps) 'Get the associated SensorData obejct lbl = SensorsLabels.Get(ps) 'Get the associated Label. If sd.ThreeValues Then lbl.Text = sd.Name & " X=" & NumberFormat(Values(0), 0, 3) & ", Y=" & NumberFormat(Values(1), 0, 3) _ & ", Z=" & NumberFormat(Values(2), 0, 3) Else lbl.Text = sd.Name & " = " & NumberFormat(Values(0), 0, 3) End If End SubSensors.zip
