توضیح در مورد سورس کار با سنسور ها
arf
دوستان من یه سورس از سایت گرفتم که طرز کارش را نمی فهمم. اگر ممکن است آن را توضیح دهد.
سورس رو پیوست هم کردم
'Activity module
Sub Process_Globals
	'This map maps between PhoneSensors and SensorData objects.
	Dim SensorsMap As Map
	Type SensorData (Name As String, ThreeValues As Boolean)
	'This map maps between PhoneSensors and Labels.
	Dim SensorsLabels As Map
				' WWW.BASIC4ANDROID.ORG
				' Producer : SH.KG
	If FirstTime Then
		SensorsMap.Initialize
		Dim ps As PhoneSensors 'This object is only used to access the type constants.
		AddSensor(ps.TYPE_ACCELEROMETER, "ACCELEROMETER", True)
		AddSensor(ps.TYPE_GYROSCOPE, "GYROSCOPE", True)
		AddSensor(ps.TYPE_LIGHT, "LIGHT", False)
		AddSensor(ps.TYPE_MAGNETIC_FIELD, "MAGNETIC", True)
		AddSensor(ps.TYPE_ORIENTATION, "ORIENTATION", True)
		AddSensor(ps.TYPE_PRESSURE, "PRESSURE", False)
		AddSensor(ps.TYPE_PROXIMITY, "PROXIMITY", False)
		AddSensor(ps.TYPE_TEMPERATURE, "TEMPERATURE", False)
	SensorsLabels.Initialize 'SensorsLabels is not a Process_Globals object so we need to create it each time
	For i = 0 To SensorsMap.Size - 1
		ps = SensorsMap.GetKeyAt(i)
		Dim lbl As Label
		lbl.Initialize("")
		lbl.TextColor = Colors.White
		Activity.AddView(lbl, 10dip, 10dip + 50dip * i, 100%x - 10dip, 45dip)
		SensorsLabels.Put(ps, lbl)
Sub AddSensor(SensorType As Int, Name As String, ThreeValues As Boolean) As SensorData
	Dim sd As SensorData
	sd.Initialize
	sd.Name = Name
	sd.ThreeValues = ThreeValues
	ps.Initialize(SensorType)
	SensorsMap.Put(ps, sd)
	Log(Name & " MaxValue = " & ps.MaxValue)
Sub Activity_Resume
	'Here we start listening for SensorChanged events.
	'By checking the return value we knoe if the sensor is supported.
		Dim lbl As Label
		sd = SensorsMap.GetValueAt(i)
		lbl = SensorsLabels.Get(ps)
		If ps.StartListening("Sensor") = False Then
			lbl.Text = sd.Name & " is not supported."
			Log(sd.Name & " is not supported.")
	'Stop listening for events.
		ps.StopListening
Sub Sensor_SensorChanged (Values() As Float)
	Dim lbl As Label
	'Get the PhoneSensors object that raised this event.
	ps = Sender
	sd = SensorsMap.Get(ps) 'Get the associated SensorData obejct
	lbl = SensorsLabels.Get(ps) 'Get the associated Label.
	If sd.ThreeValues Then
		lbl.Text = sd.Name & " X=" & NumberFormat(Values(0), 0, 3) & ", Y=" & NumberFormat(Values(1), 0, 3) _
			& ", Z=" & NumberFormat(Values(2), 0, 3)
		lbl.Text = sd.Name & " = " & NumberFormat(Values(0), 0, 3)
Sensors.zip
