موقعی که روی گوشی برنامه را اجرا میکنم وقتی روی لیست ویو کلیک میکنم که بره به قسمت مطالب این ارورا میده
اینم سورس قسمت مطلبم هست
#Region Activity Attributes
#FullScreen: true
#IncludeTitle: false
#End Region
Sub Process_Globals
Dim label1 As Label
Dim i1 As PhoneIntents
Dim intent1 As Intent
Dim list1 As List
Private Button1 As Button
Private Button2 As Button
Private Button12 As Button
Private Button11 As Button
Private Button5 As Button
Private Button4 As Button
Activity.LoadLayout("layout2")
If File.Exists(File.DirInternal,"bargh.db")=False Then
File.Copy(File.DirAssets,"bargh.db",File.DirInternal,"bargh.db")
If main2.sql1.IsInitialized=False Then
main2.sql1.Initialize(File.DirInternal,"bargh.db",False)
Dim cur As Cursor
cur=main2.sql1.ExecQuery("SELECT * FROM bargh1 WHERE id="&main2.fasl)
cur.Position=0
If cur.GetInt("fav")=0 Then
Dim Ba As BitmapDrawable
Ba.Initialize(LoadBitmap(File.DirAssets,"fav.png"))
Button2.Background=Ba
Ba.Initialize(LoadBitmap(File.DirAssets,"fav2.png"))
Dim h As Int
For i = 0 To 13
If cur.GetString("matn"&i) <> Null Then
label1.Initialize("Label1")
label1.Text=cur.GetString("matn"&i)
label1.TextColor=Colors.White
label1.TextSize=20
label1.Gravity=Gravity.RIGHT
ScrollView1.Panel.AddView(label1,0,h+2%y,ScrollView1.Width-10,ScrollView1.Height)
Dim su As StringUtils
label1.Height=su.MeasureMultilineTextHeight(label1,label1.Text)+10
h=h+su.MeasureMultilineTextHeight(label1,label1.Text)+30
ScrollView1.Panel.Height=h
If cur.GetString("aks"&i) <> Null Then
Dim ImageView1 As ImageView
ImageView1.Initialize("imageview")
ImageView1.Tag=cur.GetString("aks"&i)
ScrollView1.Panel.AddView(ImageView1,0,h,ScrollView1.Width,ScrollView1.Height)
ImageView1.Bitmap=Main.bitmap1(i)
If Main.bitmap1(i).width > 100%x Then
ImageView1.Width=100%x
ImageView1.Height=(ImageView1.Width/Main.bitmap1(i).width)*Main.bitmap1(i).Height
ImageView1.Gravity=Gravity.FILL
ImageView1.Width=Main.bitmap1(i).Width
ImageView1.Height=Main.bitmap1(i).Height
ImageView1.Left=(100%x-ImageView1.Width)/2
h=h+ImageView1.Height+30
Sub Activity_Resume
Sub Button1_Click
StartActivity(main2)
Activity.Finish
Sub Button2_Click
Dim cur As Cursor
For i=0 To cur.rowcount-1
cur.position=i
Dim f As Int
f = cur.GetInt("fav")
If f = 1 Then
main2.SQL1.ExecNonQuery("UPDATE bargh1 SET fav = 0 WHERE id = "&cur.GetInt("id"))
Dim bb As BitmapDrawable
bb.Initialize(LoadBitmap(File.DirAssets,"fav.png"))
Button2.Background=bb
ToastMessageShow("از لیست علاقه مندی ها حذف شد",False)
main2.SQL1.ExecNonQuery("UPDATE bargh1 SET fav = 1 WHERE id = "&cur.GetInt("id"))
bb.Initialize(LoadBitmap(File.DirAssets,"fav2.png"))
ToastMessageShow("به لیست علاقه مندی ها اضافه شد",False)
cur.close
hossein44 1
یه برنامه درست کردم که عکس و متن باهمه
کسی میدونه مشکل از چیه؟
