سلام خدمت انسرسنتری های من تو اولین مرحله متریال قسمت تولبار موندم وفرس کلوز میده ابنم کل کد پروژه
#Region Project Attributes
#VersionCode: 1
#VersionName:
#End Region
#AdditionalRes: ..\resource
#AdditionalRes: D:\b4a\Basic4android\Basic4android\b4a_appcompat, de.amberhome.objects.appcompat
#AdditionalRes: D:\sdk\support\v7\appcompat\res, android.support.v7.appcompat
#Extends: android.support.v7.app.ActionBarActivity
#Region Activity Attributes
#FullScreen: False
#IncludeTitle: True
#End Region
Private toolbar As ACToolBarLight
Private Panel1 As Panel
Activity.LoadLayout("L1")
toolbar.SetAsActionBar
Sub Activity_Resume
حتی سمپل اموزشی را هم ران میکنم فرس کلوز میده پس مشکل از کدنویسی نیست ب احتمال زیاد لطفا بگید دلیلش چی میتونه باش؟
mahdig502 27
ابنم کل کد پروژه
#Region Project Attributes #ApplicationLabel: B4A Example #VersionCode: 1 #VersionName: 'SupportedOrientations possible values: unspecified, landscape or portrait. #SupportedOrientations: unspecified #CanInstallToExternalStorage: False #End Region #AdditionalRes: ..\resource #AdditionalRes: D:\b4a\Basic4android\Basic4android\b4a_appcompat, de.amberhome.objects.appcompat #AdditionalRes: D:\sdk\support\v7\appcompat\res, android.support.v7.appcompat #Extends: android.support.v7.app.ActionBarActivity #Region Activity Attributes #FullScreen: False #IncludeTitle: True #End Region Sub Process_Globals 'These global variables will be declared once when the application starts. 'These variables can be accessed from all modules. End Sub Sub Globals 'These global variables will be redeclared each time the activity is created. 'These variables can only be accessed from this module. Private toolbar As ACToolBarLight Private Panel1 As Panel End Sub Sub Activity_Create(FirstTime As Boolean) 'Do not forget to load the layout file created with the visual designer. For example: Activity.LoadLayout("L1") toolbar.SetAsActionBar End Sub Sub Activity_Resume End Sub Sub Activity_Pause (UserClosed As Boolean) End Subحتی سمپل اموزشی را هم ران میکنم فرس کلوز میده پس مشکل از کدنویسی نیست ب احتمال زیاد
