گت المنت سایت (گرفتن لینک دانلود)
علی علایی
من کدهای html سایت با گت المنت میارم ولی لینک دانلود رو پیدا نمیکنم
کدهای که تو لاگ بر ام میاره
<html><head>
	<title>حاج محمود کریمی - عصر عاشورا محرم 94 - لبیک اللهم لبیک (زمینه)</title>
	<meta name='revisit-after' content='1 days'>
	<meta name='robots' content='all'>
	<meta name='googlebot' content='index, follow'>
	<meta name='msvalidate.01' content='7450277B66FBF6187B92201FEA6A2FE0'>
    <meta name='alexaVerifyID' content='YQg-8VGpVNe4i3Xg7oeZRAX9B30'>
	<link href='/_doc/sun.css' rel='stylesheet' type='text/css'>
    <link rel='stylesheet' type='text/css' href='/_doc/reset.css'>
	<link rel='alternate' type='application/rss+xml' title='آر اس اس' href='/rss/feed/media/8597/'>
	<link href='/_img/favicon.ico' rel='shortcut icon' type='image/ico'>
	<link href='/_doc/vtip.css' rel='Stylesheet' type='text/css'>
	<link href='/_doc/coin-slider-styles.css' rel='Stylesheet' type='text/css'>
	<link rel='sitemap' href='/sitemap/'>
    <link rel='stylesheet' type='text/css' href='/_doc/slider2.css'>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/jquery-1.8.2.min.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/jquery-ui-1.8.2.min.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/jquery.cookie.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/jquery-easing-1.3.pack.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/sun.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/shop.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/responsiveslides.min.js'></script>
    <script language='javascript' type='text/javascript' charset='utf-8' src='/_js/jquery.scrollbox.js'></script>
    <link rel='stylesheet' type='text/css' href='/_doc/home.css'>
	<link class='themeStyle' rel='stylesheet' type='text/css' href='/_doc/gray.css'>
    <link rel='stylesheet' type='text/css' href='/_doc/textOpinion.css'>
    <meta name='Description' content='دانلود مداحی های محرم 94 - دانلود مداحی های حاج محمود کریمی در عصر عاشورا  محرم 94 در هیئت رایت العباس (علیه السلام)
منبع: چادر خاکی
    <meta name='Keywords' content='دانلود مداحی های محرم 94 - دانلود مداحی های حاج محمود کریمی در عصر عاشورا  محرم 94 در هیئت رایت العباس (علیه السلام) منبع: چادر خاکی'>
    <!-- Seo Meta -->
    <link rel='canonical' href='http://rasekhoon.net/media/show/1116800/حاج محمود کریمی - عصر عاشورا محرم 94 - لبیک اللهم لبیک (زمینه)/'>
    <meta property='og:locale' content='fa_IR'>
    <meta property='og:type' content='media'>
    <meta property='og:title' content='حاج محمود کریمی - عصر عاشورا محرم 94 - لبیک اللهم لبیک (زمینه)'>
    <meta property='og:description' content='دانلود مداحی های محرم 94 - دانلود مداحی های حاج محمود کریمی در عصر عاشورا  محرم 94 در هیئت رایت العباس (علیه السلام)
منبع: چادر خاکی
    <meta property='og:url' content='http://rasekhoon.net/media/show/1116800/'>
    <meta property='og:site_name' content='راسخون'>
            <meta property='article:tag' content='دانلود مداحی های محرم 94 '>
            <meta property='article:tag' content=' دانلود مداحی های حاج محمود کریمی در عصر عاشورا  محرم 94 در هیئت رایت العباس (علیه السلام) منبع: چادر خاکی'>
    <meta property='article:published_time' content='11/01/2015 10:44:00 ق.ظ'>
            <meta property='og:image' content='http://rasekhoon.net/_files/images/catego
Message longer than Log limit (4000). Message was truncated.
اینم لینکش
ممنون میشم راهنمایی ام کنید
در در 1395/06/27, 22:27:07، advisor گفته است :
تو سایت مربوطه کد اجرای فایل صوتی  به این شکل نوشته شده
<video id="example_video_1_html5_api" class="vjs-tech" preload="none" poster="" data-setup="{}">
<source src="http://media.rasekhoon.net/006/Farsi/12/Karimi_Mahmoud/Moharam_94/12_karimi_Asr_Ashoora_94-03_(www.rasekhoon.net).mp3" type="audio/mpeg">
</video>
خب توی کد المنتی با آی دی   example_video_1_html5_api  رو  مشخص کرده و از بین المنت های زیر مجموعه اش المنتی از نوع source  رو گرفتم.
خاصیت src  این المنت آدرس فایل صوتی مورد نظره که بر گشت داده شده
getElementsByTagName  =>المنت هایی که از نوع مورد نظر که بخواین براتون به صورت آرایه میفرسته
getAttribute => برای گرفتن مقدار تخصیص داده شده به هر خاصیت هم از این متد استفاده میشه
توی این صفحه من میخوام بعد گرفتن ایدی کلس num dm رو هم بگیرم باید چه کدی بزنم
این کدو جایگزین کن
	WebViewExtras1.executeJavascript(WebView1,"B4A.CallSub('process_HTML',true,document.getElementById('example_video_1_html5_api').children(0).getAttribute('src'))")
متاسفانه با این هم کار نداد
تو لاگ اینو میاره
Uncaught TypeError: Property 'children' of object #<HTMLVideoElement> is not a function in  (Line: 1)
این کدم چک کن
	WebViewExtras1.executeJavascript(WebView1,"B4A.CallSub('process_HTML',true,document.getElementById('example_video_1_html5_api').getElementsByTagName('source')[0].getAttribute('src'))")
در 12 دقیقه قبل، amin.mn گفته است :
این کدم چک کن
عالی بود
ممنون دقیقا لینک نوحه اومد
شرمنده میشه یه توضیح کوچک بدی
اون تیکه اولشو فهمیدم ولی اینجاشو متوجه نشدم
</video>
اگ درست انجام بدید لینک معلومه اصلا
لینک دانلود اون موزیکه
حتما من جای رو اشتباه میرم
اینا کدهامه
Activity.LoadLayout("get")
	HttpJob1.Initialize("Myjob1" , Me)
	WebView1.Initialize("WebView1")
	WebViewExtras1.addJavascriptInterface(WebView1 , "B4A")
	WebViewExtras1.addWebChromeClient(WebView1 , "")
	WebView1.LoadUrl("http://rasekhoon.net/media/show/1116800/"&"حاج-محمود-کریمی-عصر-عاشورا-محرم-94-لبیک-اللهم-لبیک-(زمینه)/")
Sub WebView1_PageFinished(URL As String)
	WebViewExtras1.executeJavascript(WebView1,"B4A.CallSub('process_HTML',true,document.documentElement.outerHTML)")
Sub process_HTML(HTML As String)
	HTML = HTML.Replace("""" , "'")
	Log(HTML)
فک کنم چون اسکریپه  لینکو نمیاره
