اجرا نشدن design support
mr-edris
سلام خسته نباشید
هنگام اجرای سورس 2 تا ارور دارم
وقتی این خطا هستن
#AdditionalRes: D:\Edi\B4A\Basic4android\Libraries\b4a_appcompat,de.amberhome.objects.appcompat
#AdditionalRes: D:\Edi\B4A\sdk\support\v7\appcompat\res, android.support.v7.appcompat
#AdditionalRes: D:\Edi\B4A\sdk\support\design\res, android.support.design
این ارور رو میده
d:\edi\b4a\sdk\support\design\res\values\attrs.xml:27: error: Attribute "fabSize" already defined with incompatible format.
D:\Edi\B4A\sp\material\DesignSupport\1project_tabfix&Scroll\Objects\bin\extra\res3\res\values\values.xml:153: Original attribute defined here.
d:\edi\b4a\sdk\support\design\res\values\attrs.xml:76: error: Attribute "tabMode" already defined with incompatible format.
D:\Edi\B4A\sp\material\DesignSupport\1project_tabfix&Scroll\Objects\bin\extra\res3\res\values\values.xml:167: Original attribute defined here.
d:\edi\b4a\sdk\support\design\res\values\attrs.xml:81: error: Attribute "tabGravity" already defined with incompatible format.
زیاده همش ننوشتم
وقتی ورش میدارم
سورس  این ارور توی لاگ میاد
** Service (starter) Create **
** Service (starter) Start **
main_activity_create (java line: 342)
java.lang.RuntimeException: java.lang.NullPointerException
	at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:166)
	at anywheresoftware.b4a.objects.ActivityWrapper.LoadLayout(ActivityWrapper.java:209)
	at b4a.example.main._activity_create(main.java:342)
	at java.lang.reflect.Method.invoke(Method.java:515)
	at anywheresoftware.b4a.BA.raiseEvent2(BA.java:169)
	at b4a.example.main.afterFirstLayout(main.java:102)
	at b4a.example.main.access$000(main.java:17)
	at b4a.example.main$WaitForLayout.run(main.java:80)
	at android.os.Handler.handleCallback(Handler.java:733)
	at android.os.Looper.loop(Looper.java:136)
	at android.app.ActivityThread.main(ActivityThread.java:5045)
	at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
	at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
Caused by: java.lang.NullPointerException
	at de.amberhome.objects.TabLayoutWrapper.DesignerCreateView(TabLayoutWrapper.java:130)
	at anywheresoftware.b4a.objects.CustomViewWrapper.AfterDesignerScript(CustomViewWrapper.java:70)
	at anywheresoftware.b4a.keywords.LayoutBuilder.loadLayout(LayoutBuilder.java:158)
	... 17 more
** Activity (main) Resume **
سورستونو پیوست کنید ببینم مشکل از سورسو یا sdk
احتمالا شما اومدید داخل بیسیک 6 به بعد ادرس ریسورس از اس دی کی دادید شما نسخه ی جدید دیزاین ساپورت 2.1 رو استفاده کنید نیاز به ریسورس نداره با اپکامپت 3.3 که اون هم به همینجور فقط دو تا فایل aar هست که به پوشه ی کتابخونه ها اضاف میکنی
