#Region Activity Attributes
#FullScreen: True
#IncludeTitle: False
#End Region
Dim SQL1 As SQL
Dim cursur1 As Cursor
Private Panel1 As Panel
Private Label1 As Label
Private btnnumber As Button
Private btnshare As Button
Private btncopy As Button
Private Button1 As Button
Private Label4 As Label
Private Label5 As Label
Dim myfont As Typeface
Dim text As String
Dim ht As Float
Dim StrUtil As StringUtils
Dim PanelHeight As Int
If File.Exists(File.DirInternal,"smsa.db")=False Then
File.copy(File.DirAssets,"smsa.db",File.DirInternal,"smsa.db")
If SQL1.IsInitialized = False Then
SQL1.Initialize(File.DirInternal,"smsa.db",True)
cursur1 = SQL1.ExecQuery("SELECT sms FROM smstb")
ScrollView1.Typeface = Typeface.LoadFromAssets(File.ReadString(File.DirInternal,"FontType.txt")&".ttf")
Activity.LoadLayout("sv")
For i=0 To cursur1.RowCount-1
cursur1.Position=i
text= cursur1.GetString("sms")
ScrollView1.Panel.Color = Colors.Transparent
ممنون میشم بگن دوستان ایراد کجاست
یه اکتیویتی تنظیمات دارم ک فونتو طبق کد
Activity.LoadLayout("setting")
If File.Exists(File.DirInternal,"fontType.txt") = False Then
File.Copy(File.DirAssets,"fontType.txt",File.DirInternal,"FontType.txt")
If File.Exists(File.DirInternal,"fontSize.txt") = False Then
File.Copy(File.DirAssets,"fontSize.txt",File.DirInternal,"FontSize.txt")
If File.Exists(File.DirInternal,"color.txt") = False Then
File.Copy(File.DirAssets,"color.txt",File.DirInternal,"color.txt")
Label1.TextSize = fontsize.value
fonttype.AddAll(Array As String("انتخاب فونت","1","2","3","4","5","6","7"))
تو فایلی ذخیره میکنه و بعد تو کد بالا همینو لود کردم
bahman 165
#Region Activity Attributes #FullScreen: True #IncludeTitle: False #End Region Sub Process_Globals Dim SQL1 As SQL Dim cursur1 As Cursor End Sub Sub Globals Private Panel1 As Panel Private Label1 As Label Private btnnumber As Button Private btnshare As Button Private btncopy As Button Private ScrollView1 As ScrollView Private Button1 As Button Private Label4 As Label Private Label5 As Label Dim myfont As Typeface Dim text As String Dim ht As Float Dim StrUtil As StringUtils Dim PanelHeight As Int End Sub Sub Activity_Create(FirstTime As Boolean) If File.Exists(File.DirInternal,"smsa.db")=False Then File.copy(File.DirAssets,"smsa.db",File.DirInternal,"smsa.db") End If If SQL1.IsInitialized = False Then SQL1.Initialize(File.DirInternal,"smsa.db",True) End If cursur1 = SQL1.ExecQuery("SELECT sms FROM smstb") ScrollView1.Typeface = Typeface.LoadFromAssets(File.ReadString(File.DirInternal,"FontType.txt")&".ttf") Activity.LoadLayout("sv") For i=0 To cursur1.RowCount-1 cursur1.Position=i text= cursur1.GetString("sms") ScrollView1.Panel.Color = Colors.Transparentممنون میشم بگن دوستان ایراد کجاست
Activity.LoadLayout("setting") If File.Exists(File.DirInternal,"fontType.txt") = False Then File.Copy(File.DirAssets,"fontType.txt",File.DirInternal,"FontType.txt") End If If File.Exists(File.DirInternal,"fontSize.txt") = False Then File.Copy(File.DirAssets,"fontSize.txt",File.DirInternal,"FontSize.txt") End If If File.Exists(File.DirInternal,"color.txt") = False Then File.Copy(File.DirAssets,"color.txt",File.DirInternal,"color.txt") End If Label1.TextSize = fontsize.value fonttype.AddAll(Array As String("انتخاب فونت","1","2","3","4","5","6","7"))تو فایلی ذخیره میکنه و بعد تو کد بالا همینو لود کردم
