مشکل با ریسورس کارد ویو
ali-asadi
سلام و خسته نباشید! تازه میخواستم شروع کنم یکم کار با کارد ویو رو یاد بگیرم! که به این مشکل برخورد کردم!
ریسورس کارد ویو یه همچین چیزیه!
E:\android-sdk-windows\extras\android\support\v7\cardview\res
اما من فولدری با اسم res ندارم و این رو هم که میزارم ارور میگیره
D:\SDK\extras\android\m2repository\com\android\support\cardview-v7
اینم از ارور
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 21.0.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 21.0.2
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 21.0.3
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 22.0.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 22.1.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 22.1.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 22.2.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 22.2.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.0.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.0.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.1.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.1.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.2.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.2.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.3.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 23.4.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.0.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.0.0-alpha1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.0.0-alpha2
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.0.0-beta1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.1.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.1.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.2.0
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 24.2.1
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 maven-metadata.xml
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 maven-metadata.xml.md5
invalid resource directory name: d:\sdk\extras\android\m2repository\com\android\support\cardview-v7 maven-metadata.xml.sha1
توی سایت مرجع هم که دنبالش بودم روش رفع ارور رو این کد نوشته بود
#additionaljar: com.android.support:cardview-v7
ولی ارور جدید میده!
B4A version: 6.30
Parsing code.    (0.00s)
Compiling code.    (0.09s)
Compiling layouts code.    (0.00s)
Organizing libraries.    (0.04s)
Generating R file.    (0.32s)
Compiling debugger engine code.    (1.98s)
Compiling generated Java code.    (2.70s)
java.lang.IllegalArgumentException: already added: Landroid/support/v7/widget/CardViewJellybeanMr1;
	at com.android.dx.dex.file.ClassDefsSection.add(ClassDefsSection.java:122)
	at com.android.dx.dex.file.DexFile.add(DexFile.java:161)
	at com.android.dx.command.dexer.Main.processClass(Main.java:615)
	at com.android.dx.command.dexer.Main.processFileBytes(Main.java:570)
	at com.android.dx.command.dexer.Main.access$2(Main.java:546)
	at com.android.dx.command.dexer.Main$2.processFileBytes(Main.java:514)
	at com.android.dx.cf.direct.ClassPathOpener.processArchive(ClassPathOpener.java:284)
	at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:166)
	at com.android.dx.cf.direct.ClassPathOpener.process(ClassPathOpener.java:144)
	at com.android.dx.command.dexer.Main.processOne(Main.java:537)
	at com.android.dx.command.dexer.Main.processAllFiles(Main.java:449)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:236)
	at com.android.dx.command.dexer.Main.run(Main.java:206)
	at com.android.dx.command.dexer.Main.main(Main.java:179)
	at com.android.dx.command.Main.main(Main.java:103)
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R$attr;
	at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:170)
	at com.android.dx.cf.direct.ClassPathOpener.processDirectory(ClassPathOpener.java:229)
	at com.android.dx.cf.direct.ClassPathOpener.processOne(ClassPathOpener.java:158)
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R$color;
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R$dimen;
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R$drawable;
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R$style;
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R$styleable;
java.lang.IllegalArgumentException: already added: Landroid/support/v7/cardview/R;
8 errors; aborting
همه ی این ارورا موقع کامپایل هست!
دوستان راهی ندارند برای این ارور ها؟
این سومین سوالیه که میپرسم اما هیچکس جواب نمیده، مشکلی هست با بنده؟ اگه ایرادی هست خب بگید
عزیزم واسه پاسخ دادنا به اینکه چ کسی سوال پرسیده نگاه نمیکنیم که بخوایم با شما مشکلی داشته باشیم یا نه :|
پوشه ساپورت اس دی کات رو آپدیت کن
وقتی میگی چنین دایرکتوری نداری چطور انتظار داری ریسورهاشو کپی کنه واس پروژه اخه ؟
این تاپیکو ببین
در 29 دقیقه قبل، محمـد گفته است :
این تاپیکو ببین
دوست عزیز من چندین باره سوال میپرسم و هیشکی جواب نمیده نمونش هم همین پست و پست زیر
همش هم سعی کردم جوری رفتار کنم که اسپم به حساب نیاد!
در مورد این سوال هم باید بگم sdk من قسمت extera کاملا آپدیته! بازم عکس زیر رو میزارم شاید کمبودی داره که من بی خبرم! چون من داوم اپدیت میکردم!
یافتم!
sdk رو باز کنیم! توی قسمت packages بالا سمت چپ! 4تا تیک رو بزنید! و سپس reload
حالا android support library رو توی قسمت exteras میبینید! نصبش کنید! تمومه!
